ninja_geezer Posted January 2, 2017 Report Share Posted January 2, 2017 can anyone post the coding needed to delay the headlamp washers please for obdeleven. on a MY17 car bloody things are a pita. Quote Link to comment Share on other sites More sharing options...
Wookey Posted January 2, 2017 Report Share Posted January 2, 2017 If you turn your lights off it doesn't activate the headlight wash. A bit dodgy at night though! Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 2, 2017 Author Report Share Posted January 2, 2017 If you turn your lights off it doesn't activate the headlight wash. A bit dodgy at night though! yes lol ,,,, :grin: Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 2, 2017 Author Report Share Posted January 2, 2017 No worries i cheated and disabled them using OBDeleven with app instead of long code. Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted January 3, 2017 Report Share Posted January 3, 2017 No worries i cheated and disabled them using OBDeleven with app instead of long code. thats what i did just remember to enable when the MOT is due as it will be a fail if they dont work Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 3, 2017 Report Share Posted January 3, 2017 Set Headlight washer - Duration [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 6 change to e.g. 500 ________________________________________ Set Headlight washer - Cycles [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 26 change to e.g. 10 I had thought I'd completely disabled them but with the coding I used (above) it doesn't look to be permanent just seems to delay them. If anyone knows the code to completely disable headlight washers I'd also be grateful for it. Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted January 3, 2017 Author Report Share Posted January 3, 2017 Use the obdeleven app it's got a simple off or on 😊 Sent from my SM-N9005 using Tapatalk Quote Link to comment Share on other sites More sharing options...
MK7Rules Posted January 3, 2017 Report Share Posted January 3, 2017 thats what i did just remember to enable when the MOT is due as it will be a fail if they dont work Are there any other common tweaks that will cause you to fail unless you reset them? Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted January 4, 2017 Report Share Posted January 4, 2017 Are there any other common tweaks that will cause you to fail unless you reset them? not that i know of off the top of my head tweaking the lights may cause issue but that depends on what you do to them Quote Link to comment Share on other sites More sharing options...
dv52 Posted January 4, 2017 Report Share Posted January 4, 2017 Set Headlight washer - Duration [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 6 change to e.g. 500 ________________________________________ Set Headlight washer - Cycles [09 – Cent. Elect.] [security Access - 16] [Adaptation - 10] -> Channel 26 change to e.g. 10 I had thought I'd completely disabled them but with the coding I used (above) it doesn't look to be permanent just seems to delay them. If anyone knows the code to completely disable headlight washers I'd also be grateful for it. Ashley: OK if you want to entirely disable the headlight washer - then you need to tell the BCM that t doesn't support headlight washers (yes it's a lie- but it's only a little lie). This is done in the code string of the BCM by checking Byte 13, Bit 3 (see long-helper-screen below) Don ashleyman 1 Quote Link to comment Share on other sites More sharing options...
MK7Rules Posted January 4, 2017 Report Share Posted January 4, 2017 not that i know of off the top of my head tweaking the lights may cause issue but that depends on what you do to themGood to know, thanks! Quote Link to comment Share on other sites More sharing options...
dazie00 Posted January 6, 2017 Report Share Posted January 6, 2017 I had thought I'd completely disabled them but with the coding I used (above) it doesn't look to be permanent just seems to delay them. If anyone knows the code to completely disable headlight washers I'd also be grateful for it. Here you go me old fruit !! ashleyman and ninja_geezer 2 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 6, 2017 Report Share Posted January 6, 2017 Here you go me old fruit !! Thanks boss! Knew it'd be something simple. Quote Link to comment Share on other sites More sharing options...
