ashleyman Posted January 4, 2017 Report Share Posted January 4, 2017 I'm trying to run an Auto-Scan of faults on my R but whenever it gets to 02-Auto Trans the software just hangs and won't continue. I've tried ignition on/off, engine on/off, restarted laptop, re-installed software and it's doing it all the time. If I go into 02-Auto Trans on the module screen then it will scan for faults but won't run the Auto-Scan. Any ideas? Quote Link to comment Share on other sites More sharing options...
Ferg_7R Posted January 4, 2017 Report Share Posted January 4, 2017 Strange. What version of VCDS are you using? I can try mine this evening. What happens if you try to select the transmission module itself instead of an autoscan? Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 4, 2017 Report Share Posted January 4, 2017 I ran autoscan on both mine and a friend's 2016 R's at the weekend and no issues. Try uninstalling and re-installing VCDS, also disable any anti-virus software Quote Link to comment Share on other sites More sharing options...
mustard Posted January 4, 2017 Report Share Posted January 4, 2017 Mine finds a fault with the rear camera and stops showing a separate window. In the Auto Scan Screen, there is a check box, that says "Display Freeze frame", it is ticked by default, if I untick it the scan runs all the way through. Might be worth trying that. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 4, 2017 Author Report Share Posted January 4, 2017 Strange. What version of VCDS are you using? I can try mine this evening. What happens if you try to select the transmission module itself instead of an autoscan? I'm trying with the most recent version of VCDS on a genuine cable. If I select the transmission module and scan for faults it finds one. But running an Auto-Scan of all the modules won't work. I ran autoscan on both mine and a friend's 2016 R's at the weekend and no issues. Try uninstalling and re-installing VCDS, also disable any anti-virus software No Anti-Virus on the machine but I'll try re-installing VCDS and see what happens. Mine finds a fault with the rear camera and stops showing a separate window. In the Auto Scan Screen, there is a check box, that says "Display Freeze frame", it is ticked by default, if I untick it the scan runs all the way through. Might be worth trying that. Good shout. I'll try this first as it's the easiest! Thanks. Quote Link to comment Share on other sites More sharing options...
dv52 Posted January 5, 2017 Report Share Posted January 5, 2017 Ashley : wow I just noticed your descriptor - "R Legend & all round God"! Should I refer to you as Mr Ashley? Anyhow, you could certainly try removing the freeze frame tick. The Display Freeze Frame Data checkbox adds Freeze Frame data for Fault Codes on control modules using the KWP-2000 protocols. I would have expected all the modules in your R to be compatible with this facility and generally removing this checkbox simply de-clutters the autoscan report. The other option that might be worth trying is to remove the tick from the UDS aggressive mode. This has the effect of more closely aligning the VCDS tool with the proprietary VW scanner - which might help (I'm guessing) Finally, another consideration might be to modify the MyAutoScan.txt file to include the hex address of the specific modules in your R (use this setup instead of the Auto-detect (CAN) option Don Quote Link to comment Share on other sites More sharing options...
Ferg_7R Posted January 16, 2017 Report Share Posted January 16, 2017 I'm trying to run an Auto-Scan of faults on my R but whenever it gets to 02-Auto Trans the software just hangs and won't continue. I've tried ignition on/off, engine on/off, restarted laptop, re-installed software and it's doing it all the time. If I go into 02-Auto Trans on the module screen then it will scan for faults but won't run the Auto-Scan. Any ideas? Did you get this sorted? I just tried on my car and no crashing issues. Tested VCDS 16.8.4 and 17.1.1 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 16, 2017 Author Report Share Posted January 16, 2017 Someone had a laptop and VCDS cable at the SE meetup and the Auto-Scan worked fine. So it's not the car. Must be my laptop or cable causing the fault so I've re-installed VCDS on my laptop but haven't had chance to go and re-test the car. Quote Link to comment Share on other sites More sharing options...
Ferg_7R Posted January 16, 2017 Report Share Posted January 16, 2017 Someone had a laptop and VCDS cable at the SE meetup and the Auto-Scan worked fine. So it's not the car. Must be my laptop or cable causing the fault so I've re-installed VCDS on my laptop but haven't had chance to go and re-test the car. Interesting perhaps something to try is when you uninstall VCDS go delete any remaining files manually from the directory if there are any. Other thing is the USB driver but when you install the software there is a check box checked by default to reinstall that so I would imagine that should fix that if it was a problem. I guess if you have no joy try another laptop with your cable to narrow it down. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 20, 2017 Author Report Share Posted January 20, 2017 Interesting perhaps something to try is when you uninstall VCDS go delete any remaining files manually from the directory if there are any. Other thing is the USB driver but when you install the software there is a check box checked by default to reinstall that so I would imagine that should fix that if it was a problem. I guess if you have no joy try another laptop with your cable to narrow it down. I've finally managed to sort this out now. All along I've been able to do tweaks and run individual module scans but it would always fail on an autoscan. I uninstalled everything and manually removed files and drivers and then re-installed using a fresh downloaded package of 16.8.4 from Ross-Tech website. It was working in exactly the same way before the re-install. Still crashing on Auto-Scan. At no point could I see 17.1.1 available for download on the website. I called Gendan who supplied the lead and explained the issue and they said I should try doing a firmware update on the lead. I could never get VCDS to recognise there was a new firmware though. I kept getting a time out error message when pressing 'check for update'. I managed to get VCDS to see there was an update to 17.1.1 with lots of restarts. Installed the copy of 17.1.1 over the top of 16.8.4. This seems to have fixed my autoscan issue. I haven't been able to get an updated firmware installed on the lead though. That shows time out errors the same as before. So my auto-scan issue is fixed. My VCDS is on 17.1.1 but my lead won't do a firmware update! Ferg_7R 1 Quote Link to comment Share on other sites More sharing options...
Stobsie Posted January 20, 2017 Report Share Posted January 20, 2017 I've finally managed to sort this out now. All along I've been able to do tweaks and run individual module scans but it would always fail on an autoscan. I uninstalled everything and manually removed files and drivers and then re-installed using a fresh downloaded package of 16.8.4 from Ross-Tech website. It was working in exactly the same way before the re-install. Still crashing on Auto-Scan. At no point could I see 17.1.1 available for download on the website. I called Gendan who supplied the lead and explained the issue and they said I should try doing a firmware update on the lead. I could never get VCDS to recognise there was a new firmware though. I kept getting a time out error message when pressing 'check for update'. I managed to get VCDS to see there was an update to 17.1.1 with lots of restarts. Installed the copy of 17.1.1 over the top of 16.8.4. This seems to have fixed my autoscan issue. I haven't been able to get an updated firmware installed on the lead though. That shows time out errors the same as before. So my auto-scan issue is fixed. My VCDS is on 17.1.1 but my lead won't do a firmware update! Glad to auto scan feature is resolved as for the lead mine just updated when I plugged it into the car. Quote Link to comment Share on other sites More sharing options...
ashleyman Posted January 20, 2017 Author Report Share Posted January 20, 2017 Glad to auto scan feature is resolved as for the lead mine just updated when I plugged it into the car. I think I need to have the laptop connected to the internet whilst the cable is plugged in to the car which I can't do due to my router being too far from the car! Not bothered now that it's working as I can finally clear my TPS fault! Quote Link to comment Share on other sites More sharing options...
Stobsie Posted January 20, 2017 Report Share Posted January 20, 2017 I think I need to have the laptop connected to the internet whilst the cable is plugged in to the car which I can't do due to my router being too far from the car! Not bothered now that it's working as I can finally clear my TPS fault! I'm sure mine said it needed the update but didn't need internet connection? Quote Link to comment Share on other sites More sharing options...
Rich_D Posted January 23, 2017 Report Share Posted January 23, 2017 VCDS 17.1.2 came out last week, another update so soon, which will be bug fixes Quote Link to comment Share on other sites More sharing options...
Ferg_7R Posted January 24, 2017 Report Share Posted January 24, 2017 VCDS 17.1.2 came out last week, another update so soon, which will be bug fixes Is there any changelogs on what these updates contain? Quote Link to comment Share on other sites More sharing options...
