AndyDubbya Posted February 19, 2017 Report Share Posted February 19, 2017 I did this last week, and it works just as you'd expect, for me, so it's worth another try to make it work. Booth11 1 Quote Link to comment Share on other sites More sharing options...
Zaphire Posted February 19, 2017 Report Share Posted February 19, 2017 I've done that mod on mine and I can confirm that the lights stay on when leaving the car without messing around with the indicator stalk. I never even knew you had to mess around with it before doing it :I Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 19, 2017 Report Share Posted February 19, 2017 I did this last week, and it works just as you'd expect, for me, so it's worth another try to make it work. Thanks, good to know it's the right coding. Do they come on as soon as ignition is switched off? Will give it another go tomorrow. Quote Link to comment Share on other sites More sharing options...
JonnyG Posted February 19, 2017 Report Share Posted February 19, 2017 Just tried this, but hasn't worked for me, but only tried it the once. Found it all ok and changed from manual to automatic but lights did not come on when ignition off, exiting and locking the car. Will give it another go tomorrow. Let me know if it works for you when you try it. What settings have you in the cars normal menu setting for them (using the infotainment unit) ? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 19, 2017 Report Share Posted February 19, 2017 What settings have you in the cars normal menu setting for them (using the infotainment unit) ? Same as you - both CH and LH enabled and set to 20 secs. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
JonnyG Posted February 20, 2017 Report Share Posted February 20, 2017 OK I got curious ... just went out to try mine ! All coded and accepted fine. Locked the car and nothing, no lights at all ! Unlocked the car and again no lights at all ! .... what have I done I thought Then I realised I'd turned my light switch to off while I did the coding. Put the switch back to Auto and hey presto ... all working, in fact as soon as I opened the door all the lights came on ... even better than after locking. So the light switch needs to be on Auto for everything to work it seems .... I didn't realise that till now ! Check you didn't do the same as me Becs Booth11 1 Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted February 20, 2017 Report Share Posted February 20, 2017 only works if car was running/started and turned off and activates as soon as key is removed from ignition or door opened for set time it also has to be dark hope that helps i recall testing it and thinking it didnt work until i started it up and tested JonnyG and Booth11 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 20, 2017 Report Share Posted February 20, 2017 OK I got curious ... just went out to try mine ! All coded and accepted fine. Locked the car and nothing, no lights at all ! Unlocked the car and again no lights at all ! .... what have I done I thought Then I realised I'd turned my light switch to off while I did the coding. Put the switch back to Auto and hey presto ... all working, in fact as soon as I opened the door all the lights came on ... even better than after locking. So the light switch needs to be on Auto for everything to work. Check you didn't do the same as me Becs Lol, midnight coding! No Jonny, my lights are always on Auto, and I checked they were and didn't change them, so it's not that. Probably user error somewhere along the line, give it another go tomorrow night. JonnyG 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 20, 2017 Report Share Posted February 20, 2017 only works if car was running/started and turned off and activates as soon as key is removed from ignition or door opened for set time it also has to be dark hope that helps i recall testing it and thinking it didnt work until i started it up and tested That could be it. Do you mean engine has to have been running? I had ignition on to do the mod, then on to test it, but didn't start the engine (although the indicator stalk method works without engine having been run). It was dark, nearly 10pm. It's keyless so would have expected the lights to come on as soon as ignition stop/start button pressed or driver's door opened. Have to give it another shot, will get it working one way or another, lol. Quote Link to comment Share on other sites More sharing options...
JonnyG Posted February 20, 2017 Report Share Posted February 20, 2017 Another cheeky little tweak while I was out midnight coding upload I This is on the Mk 7 GTD btw. It goes something like this :- Select Control unit 17 (Dashboard) Control unit long coding look for 'replenish amount' and tick box to display It then displays as an extra screen when you scroll through the speed, oil temp etc..... MFD screens. Not much use really though Booth11 1 Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted February 20, 2017 Report Share Posted February 20, 2017 thats how i found it to work the car must of been running not just ignition on but cant recall if its taking the key out or opening the door that triggers the lights back on for set time i think its the door but not 100% you know your going to pop out in a min and test lol Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 20, 2017 Report Share Posted February 20, 2017 thats how i found it to work the car must of been running not just ignition on but cant recall if its taking the key out or opening the door that triggers the lights back on for set time i think its the door but not 100% you know your going to pop out in a min and test lol Engine on it is then. Lol, tempting as it is, I'm not leaving the warmth of my bed and starting up the car. HWMBO will think I'm doing a midnight flit. Although it's debatable if he'd even hear it over his own snoring, lol. Thanks for the help, much appreciated. Will report back either success or failure at the next nightfall. Sent from my iPad using Tapatalk baz2011uk 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 20, 2017 Report Share Posted February 20, 2017 Another cheeky little tweak while I was out midnight coding upload I This is on the Mk 7 GTD btw. It goes something like this :- Select Control unit 17 (Dashboard) Control unit long coding look for 'replenish amount' and tick box to display It then displays as an extra screen when you scroll through the speed, oil temp etc..... MFD screens. Not much use really though Completely useless and yet I'll be doing it tomorrow, lol. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
JonnyG Posted February 20, 2017 Report Share Posted February 20, 2017 That could be it. yes it could be this ... I did start the engine and then stop it. Our GTD is keyless and as soon as the door opened the lights came on Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 20, 2017 Report Share Posted February 20, 2017 yes it could be this ... I did start the engine and then stop it. Our GTD is keyless and as soon as the door opened the lights came on Right, I'm pinning all my hopes of literally 'seeing the light' on the roar of the engine tomorrow. Thanks Jonny. Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
