Rob2k68 Posted December 4, 2017 Report Share Posted December 4, 2017 On 24/11/2017 at 19:29, veneeringman said: Have sold the R now I’m sure I used this coding for the rear DRL’s. Thanks for this I'll give it a try. Struggling to get rear DRL's without the number plate illumination coming on. Was using ENG116593 Front Tagfahrlicht Dauerfahrlicht aktiviert zusaetzlich standlicht - which I suspect just puts the sidelights on. Quote Link to comment Share on other sites More sharing options...
goRt Posted December 11, 2017 Report Share Posted December 11, 2017 On 11/25/2017 at 21:45, dv52 said: hmm........... OK, must be something that's changed in the 7.5. As for the equivalent VCDS screen for Außenlicht_Front-Fahrlicht bei Tag channel see below. For front DRLs- there are two "daytime running light" entries on both the channel options and on the possible settings for the Leuchte-command. The logic table in my screenshot below decodes these options - for a mk7. The last entry in the channel screenshot should provide rear DRL- I think Don Hi Dan, Sorry for taking so long to come back to you, as others said on VCDS Tagfahrlicht isn't an option, I've tried the DRL 1A (can't actually see 1A displayed) and that lights the whole cluster not just the bottom light segment. Any suggestions? Thanks again Quote Link to comment Share on other sites More sharing options...
dv52 Posted December 12, 2017 Report Share Posted December 12, 2017 12 hours ago, goRt said: Hi Don, Sorry for taking so long to come back to you, as others said on VCDS Tagfahrlicht isn't an option, I've tried the DRL 1A (can't actually see 1A displayed) and that lights the whole cluster not just the bottom light segment. Any suggestions? Thanks again goRt: my apology - I guess that I didn't explain my picture sufficiently. there are no 1A, 2A, 1B, 2B entries on VCDS- these are just my reference label Try changing Außenlicht_Front-Fahrlicht bei Tag to Versehrtenlicht Quote Link to comment Share on other sites More sharing options...
goRt Posted December 12, 2017 Report Share Posted December 12, 2017 10 hours ago, dv52 said: goRt: my apology - I guess that I didn't explain my picture sufficiently. there are no 1A, 2A, 1B, 2B entries on VCDS- these are just my reference label Try changing Außenlicht_Front-Fahrlicht bei Tag to Versehrtenlicht Hi Dan, Thanks for clarifying. Doing that enables the whole rear cluster and all of the front LED headlights as DRLs. I had a play around and in hls10 the first DRL enables the whole rear cluster, the second one doesn't enable anything :-( Happy to keep playing if you have any suggestions Quote Link to comment Share on other sites More sharing options...
mixio60 Posted November 2, 2018 Report Share Posted November 2, 2018 Hello Don, do you think this adaptation can be valid for me, I am attaching my Admap, only different values than 7.5 posted are Fehlerort mittleres Byte DTC-DFCC 23 = 29 and Fehlerort mittleres Byte DTC-DFCC 24 = 2A https://www.Dropbox.com/s/b4ld5pk80qvjnra/ADMAP.xlsx?dl=0 Greetings Quote Link to comment Share on other sites More sharing options...
