ashleyman Posted July 9, 2017 Report Share Posted July 9, 2017 Has anyone with a facelift Golf R tried to do any tweaks with the rear light clusters? On the pre-facelift we could do the extended brake light mod which made our cars look different. Is there anything similar thats been discovered for the facelift yet? Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 9, 2017 Report Share Posted July 9, 2017 Five light mod works. mickR and Rob2k68 1 1 Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 9, 2017 Author Report Share Posted July 9, 2017 1 minute ago, veneeringman said: Five light mod works. Have you got what it looks like stock? I'd like to see the difference Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 9, 2017 Report Share Posted July 9, 2017 Sorry never took any pictures I assume like the 7 in that it's just the outers that light up. Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 9, 2017 Report Share Posted July 9, 2017 This was DRL mod but with this you only get the 6 squares on the outer cluster as brake lights. Quote Link to comment Share on other sites More sharing options...
dv52 Posted July 10, 2017 Report Share Posted July 10, 2017 12 hours ago, ashleyman said: Has anyone with a facelift Golf R tried to do any tweaks with the rear light clusters? On the pre-facelift we could do the extended brake light mod which made our cars look different. Is there anything similar thats been discovered for the facelift yet? Ashley: If you make available the adaptation channel map for the BCM on your facelift Golf R, I promise to have a look at how compatible it is with previous models (and therefore compatible with previous tweaks). I'm keen to have a look anyway at what VW has done to the new model! If you agree - just post the .CSV file somewhere (i.e. dropbox for example) and post a link to the file here. Don Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 10, 2017 Author Report Share Posted July 10, 2017 6 minutes ago, dv52 said: Ashley: If you make available the adaptation channel map for the BCM on your facelift Golf R, I promise to have a look at how compatible it is with previous models (and therefore compatible with previous tweaks). I'm keen to have a look anyway at what VW has done to the new model! If you agree - just post the .CSV file somewhere (i.e. dropbox for example) and post a link to the file here. Don Hi Don, I don't actually have a facelift yet but was interested to know what tweaks would work in advance of taking delivery. @veneeringman might be able to post the map for you though. I'm not keen on the facelift lights, when you brake it turns some off, and turns others on, I was hoping to be able to make them look like this in all modes, then when you brake leave them in the same layout/position but just to make them brighter. Therefore emulating the current extended brake light mod. Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 10, 2017 Author Report Share Posted July 10, 2017 11 hours ago, veneeringman said: This was DRL mod but with this you only get the 6 squares on the outer cluster as brake lights. Thank you sir. Are you using the same tweaks as we've been using on the 7R or is there a place where the facelift tweaks are posted? 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 10, 2017 Report Share Posted July 10, 2017 Thank you sir. Are you using the same tweaks as we've been using on the 7R or is there a place where the facelift tweaks are posted?The same coding as the 7R......The only issue I've come across so far is I cannot have the rear lights as DRLs and have the inner clusters as extra brake lights, because the inner cluster doesn't alter its brightness setting, so basically anything above 0 is 'on' at the same level of brightness, am experimenting on this though so will report any findings. ashleyman 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 10, 2017 Report Share Posted July 10, 2017 Although thinking about this the R rear clusters are exactly the same as the RS3 FL ones I had on my 8V in the fact that only the outers light up upon braking(one big square on the RS vs 6 small squares as you can see in the above pictures) Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 10, 2017 Author Report Share Posted July 10, 2017 Just now, veneeringman said: Although thinking about this the R rear clusters are exactly the same as the RS3 FL ones I had on my 8V in the fact that only the outers light up upon braking(one big square on the RS vs 6 small squares as you can see in the above pictures) And that's what I don't like about the new lights. I hope we find a way to leave the lights as in the DRL photo you posted but then to light up the extra squares too. Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 10, 2017 Report Share Posted July 10, 2017 And that's what I don't like about the new lights. I hope we find a way to leave the lights as in the DRL photo you posted but then to light up the extra squares too.The squares can be assigned to a Leutche channel as DRL's , however there needs to be a way to make them brighter upon braking. Dr.R 1 Quote Link to comment Share on other sites More sharing options...
goRt Posted November 21, 2017 Report Share Posted November 21, 2017 On 7/10/2017 at 09:38, dv52 said: Ashley: If you make available the adaptation channel map for the BCM on your facelift Golf R, I promise to have a look at how compatible it is with previous models (and therefore compatible with previous tweaks). I'm keen to have a look anyway at what VW has done to the new model! If you agree - just post the .CSV file somewhere (i.e. dropbox for example) and post a link to the file here. Don Are you after the .csv - if so, how do I share it??? The existing values on my 7.5 do not match those of the 7.0 and I reluctant to just hack about (just yet) Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 21, 2017 Report Share Posted November 21, 2017 Gort: Send to my email - sent details via message Don Quote Link to comment Share on other sites More sharing options...
dv52 Posted November 22, 2017 Report Share Posted November 22, 2017 7 hours ago, goRt said: Are you after the .csv - if so, how do I share it??? The existing values on my 7.5 do not match those of the 7.0 and I reluctant to just hack about (just yet) David: Thanks for sending the . CSV admap file for the BCM. There appears to be some differences in the Leuchte-set assignments in the new Golf 7.5 - mainly in the way that the head-lights are managed. I suspect that it's the LED headlights that have caused this. The tails however look to be more like the traditional mk7 arrangement albeit Leuchte-set # 35 is odd. I assume that you car has the "progressive turn" indicators. Anyhow, if you want to take a look at how your tail-lights are structured, I've stripped-out the Leuchte-sets for the rear of the car from your admap and I've rearranged the adaption channels so that they can be read more easily. I've also taken a guess at the function of each of the Leutch-sets (in blue). Hope that you don't mind that I've put the information here - I've done this because there may be a general interest in the information, and there's nothing in my table that particularly identifies the car, or you as an individual. https://www.dropbox.com/s/psgvsockm1zyih4/Golf 7_5 Luchte_tails.xlsx?dl=0 Now - what would you like to do with the tails? Don Quote Link to comment Share on other sites More sharing options...
