Facelift Light Question
ashleyman
5 minutes ago, dv52 said:
David: Thanks for sending the . CSV admap file for the BCM.
There appears to be some differences in the Leuchte-set assignments in the new Golf 7.5 - mainly in the way that the head-lights are managed.  I suspect that it's the LED headlights that have caused this. The tails however look to be more like the traditional mk7 arrangement albeit Leuchte-set # 35 is odd. I assume that your car has the "progressive turn" indicators.
Anyhow, if you want to take a look at how your tail-lights are structured, I've stripped-out the Leuchte-sets for the rear of the car from your admap and I've rearranged the adaption channels so that they can be read more easily. I've also taken a guess at the function of each of the Leutch-sets (in blue).
Hope that you don't mind that I've put the information here - I've done this  because  there may be a general interest in the information, and there's nothing in my table that particularly identifies the car, or you as an individual.
https://www.dropbox.com/s/psgvsockm1zyih4/Golf 7_5 Luchte_tails.xlsx?dl=0
Now - what would you like to do with the tails?
There appears to be some differences in the Leuchte-set assignments in the new Golf 7.5 - mainly in the way that the head-lights are managed.  I suspect that it's the LED headlights that have caused this. The tails however look to be more like the traditional mk7 arrangement albeit Leuchte-set # 35 is odd. I assume that you car has the "progressive turn" indicators.
Hi Don,
Happy to be able to help, thanks for the quick response.
I have led headlights with dynamic light assist, so that could be the cause of some of the changes.
In terms of the tails, yes in the UK the rear indicators sweep as standard.
I'm interested in using all rear brake lights as you can on the 7.0; turning the outer brake lights on when the tail is open and anything else that might be doable.
I'll look at your restructure when I get to my laptop.
Thanks again.
David: hm.... I don't think that it's too  difficult, but of course I can't test my  suggested changes
First: the inner lights as Brake lights ( as well as Parking Lights and Single Sided Parking Lights - which are currently programmed into these lamps):
Second: Outer Lights turn-on when tailgate is open:
Let me know how the tweaks work - please
23 minutes ago, veneeringman said:
I enabled the inner lights as brake lights on a 7.5
Works fine
However I wanted the Rears to be DRL lights so that meant losing the extra inner brake sets.
^^ Have you tried changing Außenlicht_Front-Fahrlicht bei Tag  in the BCM?
I don't have a screen shot using VCDS, but the OBDeleven picture below explains the options. The last setting gives Low-beams plus tail lights as DRLs - is this acceptable?
If not, there is no reason why you can't add the DRL leuchte command (Tagfahrlicht )  to the "Lichtfunktion G" channels in the 2 x inner lamps and use a lower "Dimmwert GH" setting to distinguish the DRL function from the Brake light function
Works fine
Can you show your coding of the rears as I guess it was the quick and dirty and not as just shown
I'd also like some minimal rear day time runners
Hi Don,
Implemented without issue (other than boot open is no in English as rear lid open and not the lovely German.
Would be interested in having the lower 6 rear LEDs as DRLs if possible
17 hours ago, BobbyT said:
Is there any coding for the estate facelift? I'm not keen on the uber small brake lights
I wish I knew, but here are the lights in 3 states (after applying your updates:
Braking
Lights on (showing the 6 I'd like)
Off
David- OK, so I suspect that lower 6 x LEDs on a Golf 7.5  have a dual purpose: The outer pairs (i.e. 4 xLEDs) appear to have higher brilliance Brake lights) and the 6 x LEDs appear to be lower brilliance Parking Lights (and SSPLs). Clearly there is an electronic ciruit in the fittings to provide the illumination difference (given that the "Dimmwert" setting is 127 for both functions in my table)........ interesting!
Anyhow, how about trying this:
So- the reason why I've put a ? in the "Dimmwert " box is because I don't know how bright to make the DRLs during daylight. If the tweak works, you might need to play with this value. The other "confounder" is how the priority conflict between the Brake function and DRL function is resolved in my suggestion - I don't have an answer to this because I don't have access to a 7.5.  But clearly you want the Brake light function to dominate during daylight hours (this isn't a problem at night-time) - so you want the illumination level of the DRLs to be noticeably lower than the Brake light - hope this males sense.
Alas, I think this tweak will need some experimentation
Interesting Don......
I'd experimented with mine once the DRL's (rear) were enabled, i tried to turn the DRL brightness down with a lower value than 127, nothing worked on my 7.5 they stayed at the same level no matter what value (except 0 of course)
The reason for turning the DRL's down was so i could add the five brake light tweak and thus it would be 'noticable' to those behind me.
I'm pretty sure there was no option with VCDS to do the fronts and rears combined Don........
And now i think about it in my post above with the picture of the Adaptations, I'm pretty sure only 2 of the 4 adaptations needed using to get all 4 clusters to light up as DRL's........which i remember at the time surprised me.
hmm........... OK, must be something that's changed in the 7.5.  As for the equivalent VCDS screen for Außenlicht_Front-Fahrlicht bei Tag  channel see below.
For front DRLs-  there are two "daytime running light" entries on both the channel options and on the possible settings for the Leuchte-command. The logic table in my screenshot below decodes these options - for a mk7.
The last entry in the channel screenshot should provide rear DRL- I think
