RichC Posted July 19, 2017 Report Share Posted July 19, 2017 4 hours ago, Privatedoc said: you cannot use the steering wheel buttons to choose phone numbers for example, spotify works well both B/T and wired but wired gets you album art also perhaps mine is a bit iffy as it seems I have a country code fault in a module...see my other posts re google earth display.... Also, an iphone 7plus is just a wee bit too big to fit in the space with the lid down ! .... and I hate trailing wires! I'm not too concerned about album artwork, the main thing for me would be controlling it via the car and not the phone. I use a Samsung S8+ so think I might have the same problem as you with it fitting anywhere. Quote Link to comment Share on other sites More sharing options...
Rjboodell Posted July 19, 2017 Report Share Posted July 19, 2017 2 hours ago, veneeringman said: I suppose not much in the grand scheme of things.... Although there are differences The pro displays the map on both screens being one...... Can you confirm that the map can be displayed in the active info display with the non pro system?! reading between the lines I presume it's not possible for the map to be on both screens at once, but individually. So not a problem if I want it on AID when driving, but the Mrs wants to control the music? Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted July 19, 2017 Report Share Posted July 19, 2017 A quick servicing question to get your thoughts guys When I purchased the car the servicing pack wasn't included and even though I enquired about it, because of the nature of the way I purchased, i.e. through a broker, the dealership wasn't prepared to give me even the option to purchase the service pack So I've made a few enquiries with my local stealer, Arnold Shark and they have quoted me the following figures 2 Year Service - £319.00 3 Year Service £419.00 includes 1st MOT 4 Year Service £539.00 includes 1st & 2nd MOT I probably tend to keep my cars for 4 years so would probably be swaying towards the 4 year plan. My question is do these costs seem reasonable? p.s. this is for a VW service pack and not an Arnold Clark Service Pack Cheers Craig Avoid the shark. Stick with independent VW franchises ( difficult but worth it)Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Slurms Posted July 19, 2017 Report Share Posted July 19, 2017 1 hour ago, Privatedoc said: have you got gracenotes in the 'defined services' then you have the same prob as me! ?country code prob How do I check..... Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted July 19, 2017 Report Share Posted July 19, 2017 Looks good value to MeSent from my SM-J320FN using Tapatalk Quote Link to comment Share on other sites More sharing options...
Privatedoc Posted July 19, 2017 Report Share Posted July 19, 2017 5 minutes ago, Slurms said: How do I check..... in settings....WLAN.....touch bar inform and guide and it will display services available Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 19, 2017 Report Share Posted July 19, 2017 Can you confirm that the map can be displayed in the active info display with the non pro system?! reading between the lines I presume it's not possible for the map to be on both screens at once, but individually. So not a problem if I want it on AID when driving, but the Mrs wants to control the music?Yes correct either in the Active info display or on nav but not on both at the same unless you have pro. Jon R306 1 Quote Link to comment Share on other sites More sharing options...
Rjboodell Posted July 19, 2017 Report Share Posted July 19, 2017 1 hour ago, veneeringman said: Yes correct either in the Active info display or on nav but not on both at the same unless you have pro. Phew! I was worried I was going to have to run down and change my order. out of interest, when using the map on the AID, do you have full functionality of the head unit, and what happens if you try and bring the sat nav to the stereo screen? 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted July 19, 2017 Report Share Posted July 19, 2017 Phew! I was worried I was going to have to run down and change my order. out of interest, when using the map on the AID, do you have full functionality of the head unit, and what happens if you try and bring the sat nav to the stereo screen?I have pro so not sure.......But I imagine if you have nav displaying in the AID you can use the head unit as normal. Same the other way so the AID will just revert to whatever you had previously displayed I.e radio, mpg, phone etc....I can on mine anyway. Quote Link to comment Share on other sites More sharing options...
CraigW Posted July 19, 2017 Author Report Share Posted July 19, 2017 23 minutes ago, veneeringman said: I have pro so not sure....... But I imagine if you have nav displaying in the AID you can use the head unit as normal. Same the other way so the AID will just revert to whatever you had previously displayed I.e radio, mpg, phone etc.... I can on mine anyway. Basically if you are displaying the map on the AID then when you select Nav on the media unit the AID switches to showing you that stupid compass feature of which way your pointing. You do have full functionality though of the AID to shift through all other features Quote Link to comment Share on other sites More sharing options...
shurcomb Posted July 19, 2017 Report Share Posted July 19, 2017 36 minutes ago, Rjboodell said: Phew! I was worried I was going to have to run down and change my order. out of interest, when using the map on the AID, do you have full functionality of the head unit, and what happens if you try and bring the sat nav to the stereo screen? Yes, you have usual control over the remaining infotainment system. The main point being that with the nav screen selected it is blank while the map is on the AID. The menu pops up when fingers approach the screen and you can flick the map back to the main screen if you want and the AID will display arrow guidance images if a route is planned or compass if no active route. The nav display also allows for a mini pop up window which can be used to display the media playing, which is nice as it allows basic controls to pause or skip fwd/bk a track, also displays album art, all in a small box while still seeing the map/route info. Quote Link to comment Share on other sites More sharing options...
Jon R306 Posted July 19, 2017 Report Share Posted July 19, 2017 On my non nav pro 7.5 is it supposed to be impossible to put in a postcode? Do I need to put my phone through to run nav?Sent from my SM-J320FN using Tapatalk Quote Link to comment Share on other sites More sharing options...
Shug Posted July 19, 2017 Report Share Posted July 19, 2017 5 hours ago, CraigW said: A quick servicing question to get your thoughts guys When I purchased the car the servicing pack wasn't included and even though I enquired about it, because of the nature of the way I purchased, i.e. through a broker, the dealership wasn't prepared to give me even the option to purchase the service pack So I've made a few enquiries with my local stealer, Arnold Shark and they have quoted me the following figures 2 Year Service - £319.00 3 Year Service £419.00 includes 1st MOT 4 Year Service £539.00 includes 1st & 2nd MOT I probably tend to keep my cars for 4 years so would probably be swaying towards the 4 year plan. My question is do these costs seem reasonable? p.s. this is for a VW service pack and not an Arnold Clark Service Pack Cheers Craig Doesn't seem too bad to me. My quote for three years VW deal, so can go to any VW dealer for it, includes two minor and one major service, and one a/c pollen filter change plus a brake fluid change, and the first MOT was about £30 more than your three year deal. Make sure the pollen filter and a brake fluid change are included. Otherwise you'll be hit for about £30 for the pollen filter and £80 for the brake fluid (based on my previous Audi costs) i was happy with my deal, as basically worked out as the same as three oil change services, and getting the extra work on the second year service, pollen filter change, bake fluid change and first MOT for free. Plus paying monthly via VWFS direct debit, so interest free and not bothered if costs increase in the next few years CraigW 1 Quote Link to comment Share on other sites More sharing options...
CraigW Posted July 19, 2017 Author Report Share Posted July 19, 2017 1 hour ago, Jon R306 said: On my non nav pro 7.5 is it supposed to be impossible to put in a postcode? Do I need to put my phone through to run nav? Sent from my SM-J320FN using Tapatalk If it's like the previous version if you select the street then on the next screen you should see a button for post code entry Quote Link to comment Share on other sites More sharing options...
PhilC22 Posted July 19, 2017 Report Share Posted July 19, 2017 1 hour ago, CraigW said: If it's like the previous version if you select the street then on the next screen you should see a button for post code entry Yep, the 'new destination' setup works exactly like the nav in the mk7. Its just that the pcd button is a bit hidden.. Quote Link to comment Share on other sites More sharing options...
