Getting ready for winter
gazza5
So today took the opportunity to try and get ready for winter. Car has needed a wash for sometime, need to put another layer on.
So to start a little bit dirty
So obviously snow foamed first, mixed a bit too much water with the snow foam so was a bit wet.
Then worked on alloys after pressure washing the snow foam off.
Used bilberry mixed 1:4 as lots of brake dust, can see residue running away from alloys. Power washed off, then another quick spray and used my new wheel brush to get the rest off.
Next up washing the car, two bucket method, can see the difference between clean and dirty, can see alloy all cleaned.
Next up some super resin Polish.
Then used autoglym fast glass to do the glass
After that collinite 845, only applied one coat as knackered
End results
Time for a cup of tea. Altho just had a rain shower! Need to seal alloys, apply another lot of collinite 845. That will b another day.
Good job done.  Try some poorboys diamond white when the SRP runs out - much easier to apply and remove!
Colly is a good durable wax although if memory serves me the 476 is a harder wax.  I used to use that on my Octavia to good effect over the winter.
Get some Gyeon Q2 Rim for to seal the wheels.  It is a 'permanent' sealant and will last up to 12 months.  Can apply to just the faces or you can take the wheels off and do inside and out.  Applies and buffs off easily.  Just make sure you do the prep before applying to they are squeaky clean.
I thought it was a good idea at the time, got 1 litre of super resin Polish for price of 500ml. Slowly making my way through it. Might even do a proper detail on the missus car at some point to use more up.
Although the 845 smells bit like petrol I quite like it as it's easy to get on and off. No waxy residue either. I didn't leave it too long,maybe couple minutes max as the sun was trying to come out. Think I will need another coat at least, reapply over winter.
I ran out of time with the rain to do the wheels. That's for another weekend,I didn't use iron x this time but next wash wheels will get done properly.
Will have a look at gyeon stuff,heard good reviews on here for it. Trouble is keep buying new stuff all the time and not using what I got already!
