Dave's Mega 7.5 OBDEleven Thread...
Idylla
I may have gone a bit overboard with my OBDEleven tweaks... - I've got a FL 7.5, picked up on March 8th!
Here's my Doc so far, each one has a status of whether it worked, or if I've had issues.
If anyone has any advice on these two annoyances that'd be lovely: (but please see below for what I've tried already)
"How long before the headlight washer jets activate"
"Don't dim DRL when indicating"
Tweaks:
Lights with Windscreen Wiper:
Can’t find
Go to [09] Central Electronics
Go into Security Access and enter 31347
Go to adaptation channels and set the following:
Type "Windshield wiper:"
Select "Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung"
Adjust value to preference (no of times you can operate the windscreen washer stalk before the headlight washer activate). so set it as 1 for every time.
Auto Coming Home Lights
Yes
09 Central Electronics
Adaptation
Select – Aussenlicht_Uebergreifend
Coming Home Verbaustatus - From manual to automatic
Off Road Display
Yes
5F - Information Electronics
Adaptation
Select - Car_Function_Adaptations_Gen2
menu_display_compass - set to active (default not active)
menu_display_compass_over_threshold_high - set to active (default not active)
Select - Car_Function_List_BAP_Gen2
compass_0x15 - set to active (default not active)
Reset the MIB unit - Press and hold the ON/OFF button on the infotainment unit for greater than 10 seconds.
Lock/Unlock Sound
Yes
Select - ACKNOWLEDGEMENT SIGNALS
Select ACTIVE for Akustische Rueckmeldung entriegen if you want acoustic feedback for unlock
Select YES for Akustische Rueckmeldung verriegeln if you want acoustic feedback for lock
Select ACTIVE for Menuesteuerung akustische Rueckmeldung (Acoustic lock menu)
In-car procedure:
Press the CAR button on the RHS of the infotainment screen
Select SETUP on the bottom RHS of the screen (looks like a cog)
Select Opening & closing panel
Place a tick in Acoustic confirmation box. The facility can be turned ON/OFF via this switch
Fan Level in AUTO
Yes
08 Air condition A/C
Coding
Select - Blower Display In Auto Operation – Set to Active
Scandinavian DRL
Yes
09 - Central Electrics
Adaptations
Select – Aussenlicht_Front- Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht – Set to Active
Avoid Dimming LED Lights when Blinking
Not working
Select Control unit 09 (Central Electrics)
Security access
Access Code 31347
Adaptation
(12)-Leuchte2SL VLB10-Lichtfunction E2
Select: not active
(12)-Leuchte3SL VRB21-Lichtfunction E3
Select: not active
Also tried: - not working
09 - Central Electronics
set these adaptation channels to Not Active:
(8)-Leuchte3SL VRB21-Lichtfunktion C 3Blinken rechts aktiv (beide Phasen)
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5Blinken rechts aktiv (beide Phasen)
(8)-Leuchte2SL VLB10-Lichtfunktion C 2Blinken links aktiv (beide Phasen)
(8)-Leuchte4TFL LB4-Lichtfunktion C 4Blinken links aktiv (beide Phasen)
DLR Only in Auto Mode
Can’t find
Security access
Access Code 31347
Adaptation
(9) - Select daytime running lights only in switch position auto
Value=Aktif
Mode button stay white when u select another than standard
Yes
Central Electronics
Adaptation
Button In Center Console
Zusatzcodierung Fahrprofiltaster hat keine LED - Change to "LED not installed"
Amount of fuel used since the last fill up
Yes
Go into Instruments
Long Coding
Go to Byte 10
Enable bit 4
This one is actually really useful. No idea why it’s not on by default!
Retain Heated Seat Setting
Yes
  1. Go to [08] Auto HVAC
  2. Go to adaptation and change the following:
  3. "retention of the seat heater level driver" to active
  4. "retention of the seat heater level passenger" to active
Disable Door Open/Ignition Tone
Yes
  1. 17 Instruments
  2. Adaptations
  3. Ignition active message; Trigger
  4. Change to "No display" (default value: driver's door)
German translation for this is.....
  1. STG 17 (Schalttafeleinsatz) auswählen
  2. STG Anpassung -> Funktion 10
  3. Zündung aktiv Meldung; Auslöser
  4. ändern auf "Keine Anzeige"
Change brightness of reverse lights
Already full on 7.5
9- Central Convenience
16-security code 31347
10-Adaptations
(6) Leuchte 28RFL LC11 dimming AB 28
(6) Leuchte 29RFL RA64 dimming AB 29
Adjust values to what you want.
This is the coding for the DRL brightness.
No - Already full
16 Security Access 31347
10 Adaptations
(10)-Light2SL VLB10-Dimming CD 2' from 26 to 100
(10)-Light3SL VRB21-Dimming CD 3' from 26 to 100
Disable Soundaktor
Yes
Disable the Soundaktor unit, which creates a fake engine sound when driving.
Select Structure Borne Sound
Adaptations
Select ‘Channel of Structure Bore Sound’
Change Value from 100% to any desired value, or 0%
Drive Profile Display in Cluster
Already Seems to be enabled on 7.5
This tweak will show the driver profile name in the cluster when switching modes.
Select Control unit 19
Control unit long coding
Byte 08
Bit 4 Activate
Disable Start / Stop (Voltage Method)
Yes
Disable engine Start / Stop functionality.
Adaptation
Start Stop Limit voltage
Value=12
Adjust Door Led Light Intensity
Already seem to be at max brightness
For vehicles fitted with LED Door lights, this tweak will increase the brightness.
Security access
Access Code 31347
Adaptation
(6)-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16
Select: max 127
(6)-Leuchte17TFLR SRB3TFL R SR KC3-Dimmwert AB 17
Select: max 127
Hide Optical Parking System Warning Line
DOES NOT WORK AND UPSETS DASH, LOTS!!!
Disables the ‘Please check surroundings’ message that appears on the headunit when parking.
Select Control unit 03 (Brakes)
Security access
Access code:71679
Control unit Coding
Byte 1
Bit 5 DeActivate
Tap to Indicate – Number of Blinks
Done - I thought this was on the MIB on the 7.0?
When tapping the indicator to turn, this tweak will change the number of times the indicator blinks.
Security access
Access Code 31347
Adaptation
Comfort Sinyal Sayısı (Cycles)
Value: 1-5 Value 3 (Standard – 3x blinking)
NOTE: You should reset the "Lighting" section to factory defaults in the MIB after doing this tweak. Set to 4, I wasn't giving enough indication with 3.
Drivers Reaction Adjustment (Car must be fitted with Camera)
Set to LATE
Adjusts the sensitivity in which the car will alert the driver due to lack of steering input.
Select Control unit A5 (camera)
Security access
Enter unlock code 20103
Adaptation
Select channel deactivation threshold driver activity
Value adjust accordingly Default: medium options: early, middle, late
Next to try this Easter weekend - changing the dials style!
I've uploaded a pic of the default on my 7.5/FL - (In reference to the different ones to pick from, ours seems to be 3)
Here are the different styles that someone has posted on the OBDEleven boards (note: Theirs doesn't look like a Golf R)
http://obdeleven.proboards.com/post/8711/thread
And here is the coding to do it:
http://obdeleven.proboards.com/post/8704/thread
Also, going to try this one that apparently stops the 'undertaking protection' that I've got on ACC now (which is very frustrating on managed motorways where lanes are designed to run independently)
ACC
long coding
byte 02 (bit 5 ticked)
overtaking_right_prevention set it from active to not active
  • 2 weeks later...
I forgot to upload my pictures! I've also settled on Variant 2 - I prefer having more numbers on my dials. Although I don't know why there isn't a version with the 30, 50, 70 in bold!
Variant 1 - zoomed in and zoomed out
Variant 1 - Zoomed in dials
Variant 1 - Zoomed Out Dials
Variant 2:
Variant 3 Zoomed In:
Variant 3 Zoomed Out:
Variant 4:
4 minutes ago, SIMK7.5 said:
Its a shame that all the other variants apart from default Variant 4 now lose the 200mph indication on the speedo though......found that really handy lol.
Ha! I got an indicated speed on the digital speedo on my old R of ~160mph in Germany. Not sure I'm making 200 anytime soon :D
  • 1 month later...
I only messed around with the dials for a week before reverting back to the default ones.....they are just clearer and better imho. I never really bothered with the 'Classic' view at all but it seemed fairly good at replicating analogue dials.
