Error Workshop !!
Hi folks ,got an error pop up 4 times today whilst pulling off after car had been stood for 30 mins or so .
it read.
ERROR WORKSHOP
ONLY LEAVE VEHICLE IN P POSITION
this stayed on only for seconds before i could take a snap.
the car has done 9k 66 plate .
the car seems to drive perfect.
no point in asking local stealers as next to useless.
any of you peeps had this before.
cheers.
Just scanned the car for error codes guess what it came up with the fault code B116229
just as mentioned it the TSB. car booked in for fault finding on the 11th june ..it does the error on screen daily now ,they wanted a photograph ,i said a bit hard when you are driving and its on the screen for a couple of seconds...
we shall see....
we shall see....
Should be able to get it up on the vehicle status page on head unit too for the sake of a pic
Nope no issues or adverse effects other than the error message
I should add that when I took my car in I mentioned about the TSB and root cause being shifter mechanism and even with that when I got a call to say it was sorted and ready to be picked up. When I arrived the service advisor went to get my car and hey presto the message popped up.
Turned out the mechanic working on the car plugged it in and seen the stored code and proceeded to replace the steering column , steering module ECM, ignition barrel and wiper stalk without looking for a service bulletin that corresponded to the code. Left the car with them and was sorted 2 days later with new shifter assembly
7 hours ago, xPETEZx said:
11th june?? Over a month away? That the best your local dealer can do?
If so, maybe worth finding another dealer?
Having that error everyday must get tiring. Does it cause any problems?
To be honest the dealer is pants  ! just local ,the reason for the delay is i need a loan car as its my work .that was the earliest they had !
been doing it for just over a week now but not casued any other issues.
