Briinthesky Posted July 5, 2019 Report Share Posted July 5, 2019 Hi I noticed recently that there is a rattle coming from the engine just after I start it (Golf R) and it seems to fade away after about five minutes when the oil has begun to warm up.This only started recently and it is almost 3 years old Should I be considered?? Bc Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Andygo Posted July 8, 2019 Report Share Posted July 8, 2019 Sounds like it is possibly a hydraulic cam follower. What did you want to be considered for? slickrick30 1 Quote Link to comment Share on other sites More sharing options...
Briinthesky Posted July 10, 2019 Author Report Share Posted July 10, 2019 Thanks for the infoI just wanted to know if it was anything I should get checked before the warranty runs out.As soon as the oil starts to get moving and it begins to warm up the rattle goes away.BcSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
GolfRWag Posted July 12, 2019 Report Share Posted July 12, 2019 Yeah, I have noticed a bit of ticky noise in cold start up, given its winter here now in Melbourne (lows of 7-8degrees C! I'm putting it down to the oil being a bit thicker and hydraulics not quite right until it warms enough. It goes away within less than a minute. My R is only 6 months/9000 km so probably run in now. Another thought was the pistons, being forged, means they can be a little noisy until warm so I understand, depending upon the compromises made during design to keep efficiency high: https://ls1tech.com/forums/generation-iii-internal-engine/372791-piston-slap-explaination-gm-engineer.html Quote Link to comment Share on other sites More sharing options...
Briinthesky Posted July 13, 2019 Author Report Share Posted July 13, 2019 Strangely when I put up the post the car was in individual drive Mode and most things on eco.I have since switched to normal mode and have yet to hear the rattle!BcSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
revster Posted July 14, 2019 Report Share Posted July 14, 2019 I don't think the pistons are forged. Crank yes, rods who knows. Quote Link to comment Share on other sites More sharing options...
dh6 Posted September 7, 2020 Report Share Posted September 7, 2020 On 05/07/2019 at 23:32, Briinthesky said: Hi I noticed recently that there is a rattle coming from the engine just after I start it (Golf R) and it seems to fade away after about five minutes when the oil has begun to warm up. This only started recently and it is almost 3 years old Should I be considered?? Bc Sent from my iPhone using Tapatalk Did you ever get to the bottom of this? I have similar on my two year old 7.5R Quote Link to comment Share on other sites More sharing options...
Miltons Posted February 1, 2022 Report Share Posted February 1, 2022 Anybody get to the bottom of this? On cold starts I get like a knock or lifter noise! After I've let the cold start cycle subside and I've started driving, I'll still hear the noise faintly (for about five minutes) as I'm accelerating away from a stop sign or whatnot. To me it definitely seems like irregular lifter tick coming From the left side of the engine. It never made the noise till after 100,000km were on the car. 2016 Mk7 R here btw. yes I'm posting on an older thread as this sounds close to what I'm dealing with. Quote Link to comment Share on other sites More sharing options...
fastandy Posted February 2, 2022 Report Share Posted February 2, 2022 I don't think I notice anything. 2016 R estate, 62k miles. You can hear the cam gear, tappets etc. more when engine oil is cold. Do you mean Left side when looking from front of car standing in front of grill? If so, that is where the camchain / tensioner gear is. A knock is different from a tick..... Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted February 3, 2022 Report Share Posted February 3, 2022 I have a very vague recollection of cold start noises being caused by something, but can't for the life of me remember what it was. maybe oil pump or fuel pump coming up to pressure ? Some have suggested that fuel injectors can be a bit noisy also. Quote Link to comment Share on other sites More sharing options...
