Power consumption is high
Asa55
Don’t know if this is a coincidence or someone else has had the same problem but when I used obdeleven to change my start stop battery voltage to 12v instead of 7.6v It had the desired affect and disabled start stop. The problem is when I switched it back to 7.6v the start stop no longer works. If my keys are in the ignition the system says start stop system is activated but as soon as I start the engine the message changes to power consumption is high and the start stop is disabled. The VW dongle says my battery is at 13.4v which seems fine to me? Appreciate any help or do I need to take it to the dealers. 78fc67569a9c9ffba73f04386542b9d0.jpg
If the engine is running and the alternator is charging shouldn't the voltage be 14.3 - 14.7V  ?
13.4V seems low to me (unless the BCM is doing something to increase fuel economy, like waiting for you to decelerate before charging the battery).
That was after a short 10 min drive with engine off. I’ll check it again with the engine running
2 hours ago, PEHZY said:
That was after a short 10 min drive with engine off. I’ll check it again with the engine running emoji106.png
Engine running or stopped makes a big difference to battery voltage.
Running: 14.3 - 14.8V (typically)
Stopped (after several hours off or run headlights for 30 seconds or so):  12.4 - 12.8V (shouldn't drop much below 12V when cranking starter motor)
Tried disconnecting the battery to reset the electrics but still showing the same error. Should point out the VW connect app wasn’t live it was from a few hundred miles ago and doesn’t seem to want to establish a new figure even though it says it’s connected. I have used my fluke voltage meter across the terminals and it was giving 12v without engine running and 13v with the engine running. Could this be down to the battery then? Do you think I should be getting above 14 like you said for stop start to work?
This behavior may be entirely normal depending on what else has been turned-on
After the ignition is turned-on and the engine is running, press the Stop Start message on the screen below (apology for the dusty pic):
You should then get a screen that looks like this:
What are the entries - these are the reasons why SS hasn't switched-on?
 Both those figures seem quite low to me, but what was after the decimal point ie 12.?  and 13.?
 I happened to check my T5 van this morning because I have just put a new battery in it.  It hasn't been used for 36 hours and the battery voltage was 12.6V.
Don, posted the same pic above as you. Nothing else is running and the engine temp was up to temp for it to kick in.
The fluke didn’t give decimal places it just rounded it up or down with it mainly used for AC. I’ll give the car a good motorway run on Friday and see what happens. Thanks for the input
  • 2 weeks later...
Just an update if anyone has same problem as me. Start stop is back working although now I know why I disabled it.. Just changing the voltage in adaption back to 7.6 from 12 didn’t work for me but turning it on using the app option on OBDeleven did the trick.
Just now, dv52 said:
marshy: hi. Both the "temperature" and "voltage" methods for disabling SS work by tricking the decision making algorithm.  For the "voltage" method, changing the setting to around 12 V (note: this is not referring to battery volts) fools the algorithm into thinking that there is insufficient capacity in the battery to restart the engine (once turned/OFF). So SS never turns-off the engine,
Both methods  WILL ALWAYS produce what I call the "SS disable  tell" when the car is stopped if the driver hasn't pushed the native SS disable button on the center console. The "SS disable tell"  is  the Power consumption high message  and the A symbol with a slash - which is displayed on the dashboard.
Thanks for your explanation.
I’d prefer a memory function that stored the last setting for stop start.
So turn it off day 1 and only turn it on when needed.
I've had mine turned off via the voltage method since I got my car a year ago with no problems whatsoever, but then I don't intend to turn it back on ever.
I have read about a device that once fitted reverses the button so instead of being on my default it is off by default and then a button press turns it on, sounds exactly what you are looking for.
I think it was@gregozedobe that had it fitted?
