Power consumption is high
Asa55
13 hours ago, PEHZY said:
Just an update if anyone has same problem as me. Start stop is back working although now I know why I disabled it.. Just changing the voltage in adaption back to 7.6 from 12 didn’t work for me but turning it on using the app option on OBDeleven did the trick.
Interesting this one, in that the S/S didn’t reactivate after you switching it back to 7.6v through obdeleven coding.  I have mine disabled via obdeleven through the voltage setting (so set at 12v to fool it) but when I was having a few battery issues (ages ago now), I had occasion to set it back to standard 7.6 a few times; and when I send it in for service I usually revert it to 7.6 and then swap back to 12v after. And every time it I’ve recoded back to 7.6 with obdeleven coding, it’s reactivated as you would expect. Wonder why that didn’t work in your case, and you had to use the app?
7 minutes ago, SpursMadDave said:
I've had mine turned off via the voltage method since I got my car a year ago with no problems whatsoever, but then I don't intend to turn it back on ever.
I have read about a device that once fitted reverses the button so instead of being on my default it is off by default and then a button press turns it on, sounds exactly what you are looking for.
I think it was@gregozedobe that had it fitted?
I believe that autowatch ghost offers that function to reverse the oem switch function, but think others have mocked up their own devices to do same.
Interesting this one, in that the S/S didn’t reactivate after you switching it back to 7.6v through obdeleven coding.  I have mine disabled via obdeleven through the voltage setting (so set at 12v to fool it) but when I was having a few battery issues I had occasion to set it back to standard 7.6 a few times, and when I send it in for service I usually revert it to 7.6 and then swap back to 12v after. And every time it I’ve recoded back to 7.6 it’s reactivated. Wonder why that didn’t work in (OPs) case, amd you had to use the app?
Yes a strange one, could be so many different things it's hard to pinpoint, the electric on these cars are probably more complicated than the early Apollo space rockets!
I have coded mine off the same way as you and if/when I get rid it's good to know that if I have an issue I can use a few credits to sort it.
Maybe there should be a 'back to factory' setting in OBDEleven, my car had several tweaks done when I got it, some Inwould have done anyway but some of the lighting ones were just stupid...
Not me (unfortunately) as that is the functionality I would prefer.  I have mine switched off all the time using a Kufatec plug-in module that switches auto stop/start from always on to always off.  If you plug it in again it reverses that (ie from always off to always on). Every time you plug it in it changes it again.  If it is off you can't switch it back on by pressing the button next to the gear lever.  The module is locked to your car the first time you use it, so you can't switch it off for all your mates with the one purchase.
There are four three ways to get the above default behaviour (that I know of, there may be more):
- Buy and install an electronics kit (from ebay) that modifies the action of the switch (sorry, don't have a link, but you have google)
- Make and install a similar kit as detailed by DV52 (Don the VW coding expert), this is very much a DIY proposition.
-  Get Autowatch Ghost
- Get an APR stage 1 tune (this is new functionality added recently)
Edited by gregozedobe
Added an extra method - thanks Bec
Cheers Greg, I was half right just thought your plug in device retained the use of the button
On 16/10/2019 at 21:44, SpursMadDave said:
Looks perfect, wouldn't be too much of a hassle to fit either I guess
Dave: most difficult part is removing the cover from the gear leaver - but here's a video of how to do it from a fellow Aussie (Mattaus)
