Booo Posted April 5, 2020 Report Share Posted April 5, 2020 Hi,,, I've been going to through different threads/post all over the web to get a better understanding about OBDeleven and coding. But I'm finding conflicting info and having difficultly differentiate the right codes. I've managed to find two threads (see below) with a few codes and the rest are full of comments which I dont have time to go trough. Is there any website were I can find all the codes available in one plass? Thanks. https://forum.obdeleven.com/thread/1928/golf-mk7-facelift-coding-adaptions Exinferris 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 5, 2020 Report Share Posted April 5, 2020 1 hour ago, Booo said: Hi,,, I've been going to through different threads/post all over the web to get a better understanding about OBDeleven and coding. But I'm finding conflicting info and having difficultly differentiate the right codes. I've managed to find two threads (see below) with a few codes and the rest are full of comments which I dont have time to go trough. Is there any website were I can find all the codes available in one plass? Thanks. https://forum.obdeleven.com/thread/1928/golf-mk7-facelift-coding-adaptions In short, no there isn’t really a one stop shop where all the codes are set out neatly in one place. The link above to the OBDeleven forum is probably the most comprehensive website and the closest you’ll find to that. Some coding that works for mk7 doesn’t work on 7.5 so it can get a bit confusing. It might be a good idea if you post up a thread in this section stating which adaptations you’re interested in (if you know) and then I’m sure people will post up the coding of they know it. Yours is a 7.5 right? VWPL 1 Quote Link to comment Share on other sites More sharing options...
Booo Posted April 5, 2020 Author Report Share Posted April 5, 2020 1 hour ago, Booth11 said: In short, no there isn’t really a one stop shop where all the codes are set out neatly in one place. The link above to the OBDeleven forum is probably the most comprehensive website and the closest you’ll find to that. Some coding that works for mk7 doesn’t work on 7.5 so it can get a bit confusing. It might be a good idea if you post up a thread in this section stating which adaptations you’re interested in (if you know) and then I’m sure people will post up the coding of they know it. Yours is a 7.5 right? Yes, its a 7.5.. Here are a few things I would like to get done! 1.Central lock with IGN 2. Comfort turn signals. 3. Soundaktor OFF. 4. Headlight washer OFF. 5. Auto lock. 6. Alarm Chirp on lock/unlock. 7. Enable fan level display on auto. 8. Stop/Start disabled. 9. Battery charge level. 10. Reverse lights full brightness. VWPL 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 6, 2020 Report Share Posted April 6, 2020 8 hours ago, Booo said: Yes, its a 7.5.. Here are a few things I would like to get done! 1.Central lock with IGN 2. Comfort turn signals. In the 7.5 VWROC thread in your first post and first link below 3. Soundaktor OFF. See first thread linked below 4. Headlight washer OFF. See third link below dv52 post 5. Auto lock. see video link but this is on a 2018: 6. Alarm Chirp on lock/unlock. In the 7.5 VWROC thread in your first post and first link below 7. Enable fan level display on auto. In the 7.5 VWROC thread in your first post 8. Stop/Start disabled. See link below. However, I understand this adaptation might now have been disabled by VW. See the second link below. 9. Battery charge level. Not sure this is possible, it wasn’t on the mk7 10. Reverse lights full brightness. See first post linked below. They are apparently already set at full brightness on the 7.5 1) 2) 3) Headlight washers Booo and Exinferris 2 Quote Link to comment Share on other sites More sharing options...
Booo Posted April 6, 2020 Author Report Share Posted April 6, 2020 Appreciate the help😊 Thanks🙏 Quote Link to comment Share on other sites More sharing options...
Booo Posted April 6, 2020 Author Report Share Posted April 6, 2020 Managed to get a few coding done today. - Comfort turn signal ( 4 cycles) - Headlights washers (disable) - Offroad display - Driving school mode - Lock/unlock sound - Fan level display on auto - Retain heated seat - Amount of fuel fill up since the last fill up ( I not sure how this is of any use apart from if someone else was using the car and it would be helpful to see how much was filled up by someone else) Not sure if I got this to work; - Disable door open/ignition tone ( The beeping tone is still there when I open the door and the gear is in D) Coding Im going to try tomorrow; - Stop/start (Disable) - Central lock with ignition on - Soundaktor (Disable) - Exhaust flaps (Disable) Once I got the hang of it, it went pretty fast😊 Booth11 1 Quote Link to comment Share on other sites More sharing options...
Spades Posted April 7, 2020 Report Share Posted April 7, 2020 Anyone know if it is possible to set DRLs to any level other than off when indicating on the 7.5? Quote Link to comment Share on other sites More sharing options...
dv52 Posted April 11, 2020 Report Share Posted April 11, 2020 On 07/04/2020 at 17:17, Spades said: Anyone know if it is possible to set DRLs to any level other than off when indicating on the 7.5? Spades: Short answer is "no" if the particular version of your mk7.5 is equipped with LCMs (Light Control Modules). If your car has LCMs, they will likely be reported @ address hexD6 and hexD7 in the scan. Unfortunately, LCMs don't have a long-code string, or adaptation channels that can be accessed by OBD11 - so no changes to headlight functions is possible. Of course, if your version of mk7.5 has the more traditional form of lighting control (via the hex09 module) - the answer is "Yes" Don Quote Link to comment Share on other sites More sharing options...
Booo Posted April 11, 2020 Author Report Share Posted April 11, 2020 Hi @dv52, I would appreciate if you could help me out with this . Is it possible to turn my taillights ON along with my front LED DRLs while the headlight switch is set to Auto? Im also trying to find the coding for "Windows close automatically during rain". Thanks Quote Link to comment Share on other sites More sharing options...
Penguin Posted April 12, 2020 Report Share Posted April 12, 2020 14 hours ago, Booo said: Is it possible to turn my taillights ON along with my front LED DRLs while the headlight switch is set to Auto? Scandinavian rear DRL's should be doable. Try this: https://forum.obdeleven.com/thread/3178/rear-lights-drls-scandinavian Exinferris and Booo 2 Quote Link to comment Share on other sites More sharing options...
Booo Posted April 12, 2020 Author Report Share Posted April 12, 2020 6 hours ago, Penguin said: Scandinavian rear DRL's should be doable. Try this: https://forum.obdeleven.com/thread/3178/rear-lights-drls-scandinavian Thanks Penguin 😇 I found the coding right after I posted here. But I can't get the "Windows close automatically during rain" to work😪 The coding was accept and I even got the option in the head unit, but its still not working🤨 Quote Link to comment Share on other sites More sharing options...
Penguin Posted April 12, 2020 Report Share Posted April 12, 2020 1 hour ago, Booo said: Thanks Penguin 😇 I found the coding right after I posted here. But I can't get the "Windows close automatically during rain" to work😪 The coding was accept and I even got the option in the head unit, but its still not working🤨 Is there an option to enable via infotainment? Car > Settings > Opening & closing (or similar) It could just be a module/hardware limitation of your particular car/build week Quote Link to comment Share on other sites More sharing options...
Booo Posted April 12, 2020 Author Report Share Posted April 12, 2020 46 minutes ago, Penguin said: Is there an option to enable via infotainment? Car > Settings > Opening & closing (or similar) It could just be a module/hardware limitation of your particular car/build week Yes, I have the option on the infotainment and its ticked for closing when it starts to rain. I even have the wipers on auto. I think you are right that there is some kind of limitation😢 Quote Link to comment Share on other sites More sharing options...
Penguin Posted April 12, 2020 Report Share Posted April 12, 2020 43 minutes ago, Booo said: Yes, I have the option on the infotainment and its ticked for closing when it starts to rain. I even have the wipers on auto. I think you are right that there is some kind of limitation😢 IIRC it's been common across the MQB platform. Some cars work with the mod enabled, others don't. I've even seen posts where it will close the pano roof but not the windows. I'm sure someone with more knowledge of the modules and VCDS could give an exact explanation. Quote Link to comment Share on other sites More sharing options...
Penguin Posted April 12, 2020 Report Share Posted April 12, 2020 50 minutes ago, Booo said: Yes, I have the option on the infotainment and its ticked for closing when it starts to rain. I even have the wipers on auto. I think you are right that there is some kind of limitation😢 Googling around it appears, on some cars, to be a limitation of VCDS/OBD11 in that it can interrogate and modify the central electronics 09 module but it can't actually make the changes to the Rain Light and Humidity Sensor (RLFS). VCP (Vag Can Pro) may be the only way to actually get this working (?), or even dealer level kit such as ODIS. Borrowed this from another forum, have you met this criteria to test it? The windows only close automatically when:(1) You've enabled the feature in VCDS and in the car menu(2) The car is off(3) The doors are locked(4) The wiper stalk is in the Automatic position(5) The Rain/Light Sensor (RLS) detects rain OR if x hours pass with no rain or no-one interacts with the car. Usually this occurs overnight in my experience. Booo 1 Quote Link to comment Share on other sites More sharing options...
