Reverse camera not working
Nathan3cx
Hi, My rear reverse camera  and boot opening latch have stopped working? I get parking sensors coming on and colour emblems on right of screen in dash. Ive checked fuse, reset head unit, scanned it with vcds no faults, checked wiring and plugs going into camera all look good??
Any ideas ? Would it be best just to replace camera and boot latch ?
Thanks in advance?
Checked it's definitely knackered? Ask someone to see if the badge is flipping up to expose her camera.
Try manually opening and closing the boot a few times, sometimes the badge latch that hides the camera gets stuck. Happened to me once, some road gunge had sort of caked it shut.
When this happens it doesn't pop out and the screen looks black with a slight film grain.
Badge is not flipping up to expose camera, boot doesn't open when you try it manually, only opens when u use key fob??
If the handle and the camera don't work then that would suggest a power issue and hopefully the camera is OK. Personally, I would check the power at the camera in the tailgate (red/yellow wire on the camera).  I have heard of some rare cases of the wiring breaking at the point where the loom leaves the tailgate and enters the car.
