Dr'R' Posted February 8, 2021 Author Report Share Posted February 8, 2021 I have success...... Deleted the app, reinstalled it...... It now seems to working....😊 Many thanks for all assistance.👍 Booth11 1 Quote Link to comment Share on other sites More sharing options...
Dr'R' Posted February 8, 2021 Author Report Share Posted February 8, 2021 On 06/02/2021 at 21:57, Chris7.5R said: Not too surprising, as we're up to iOS 14.4, but sometimes there's an old phone lying around ... Hang on, I still have the old Android version so haven't tried using iOS, and I prefer to use VCDS, but shouldn't you be connecting via Bluetooth, not WiFi? I did think about buying VCDS when I brought the new updated IOS OBDEleven, maybe I should have. 🙄 Do you find using VCDS very user friendly? It was only the easiness of using the Apps on OBDEleven that swayed me to OBDEleven. Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted February 8, 2021 Report Share Posted February 8, 2021 18 minutes ago, Dr'R' said: I did think about buying VCDS when I brought the new updated IOS OBDEleven, maybe I should have. 🙄 Do you find using VCDS very user friendly? It was only the easiness of using the Apps on OBDEleven that swayed me to OBDEleven. VCDS is not too difficult, provided you do your research on what you want to achieve. There's a lot more helpful stuff in the program, as well as generally online, and it's easier to backup and restore changes. I'd certainly advise against relying on the OBD11 apps, as you have very little control over the process and if something doesn't work it can be frustrating to sort it out. With OBD11 coding and with VCDS you'll see immediately if a change fails or is not compatible with your car. Once you've done a few you'll be better informed on how it works, and less likely to cock things up. The only people who will have big problems are the idiots who browse through options at random and think "That looks good, I'll give it a try", without any background information. Given the initial cost of VCDS, and the fact that you've already bought OBD11, I'd recommend getting the Pro update and doing the job properly. Once you get started you'll love it! Booth11 and Dr'R' 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 8, 2021 Report Share Posted February 8, 2021 39 minutes ago, Dr'R' said: I have success...... Deleted the app, reinstalled it...... It now seems to working....😊 Many thanks for all assistance.👍 Glad it’s all working now! 👍 Echo what Chris says above about the Pro version of OBDeleven. Much more control over what you’re doing. Definitely worth the activation upgrade if you don’t already have it. Dr'R' 1 Quote Link to comment Share on other sites More sharing options...
Dr'R' Posted February 10, 2021 Author Report Share Posted February 10, 2021 I do have the Pro version of OBDEleven👍 I need to do rear pads, and was just going to use the 'app' to fully open the EPB, and then the 'app' again to close/reset the EPB. Do you both think this is a bad idea, and that I should code them open and closed? I guess the 'apps' are coded by the bod's at OBDEleven? So I assumed (maybe incorrectly) that they would know what they're doing, and so less chance of me screwing something up by pressing something I shouldn't and getting it wrong ? Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted February 11, 2021 Report Share Posted February 11, 2021 15 hours ago, Dr'R' said: I do have the Pro version of OBDEleven👍 I need to do rear pads, and was just going to use the 'app' to fully open the EPB, and then the 'app' again to close/reset the EPB. Do you both think this is a bad idea, and that I should code them open and closed? I guess the 'apps' are coded by the bod's at OBDEleven? So I assumed (maybe incorrectly) that they would know what they're doing, and so less chance of me screwing something up by pressing something I shouldn't and getting it wrong ? I've no idea about your specific item, but my general aversion to the apps still applies. What if the clever bods' route wasn't truly correct for your car and it didn't quite work, leaving your EPB in some indeterminate state? Personally I would do the research to find the actual changes and use them. If you can only find a VCDS recipe, that shouldn't be difficult to apply to OBD11. Dr'R' 1 Quote Link to comment Share on other sites More sharing options...
Dr'R' Posted February 11, 2021 Author Report Share Posted February 11, 2021 I'll avoid using the app, and just find the coding sequence req to replace the rear pads. Thanks again👍 Quote Link to comment Share on other sites More sharing options...
Chris7.5R Posted February 11, 2021 Report Share Posted February 11, 2021 3 hours ago, Dr'R' said: I'll avoid using the app, and just find the coding sequence req to replace the rear pads. Thanks again👍 Best of luck. Come back if you need any help with VCDS -> OBD11. Dr'R' 1 Quote Link to comment Share on other sites More sharing options...
Dr'R' Posted February 15, 2021 Author Report Share Posted February 15, 2021 Rear pads replaced today, all went well. Thanks again for all the assistance👍 Booth11 1 Quote Link to comment Share on other sites More sharing options...
