IOS Apps not supported?
Dr'R'
Evening all,👋
Finally got around to connecting my new OBDEleven, IOS version.
Connected, updated, put in password, collected my 100 free credits, all ok.
However, all the apps come back with 'Not Supported':banghead:
Car is '18.
Have used the older Android one, without any problems, and all my previous changes are listed in the OBDEleven App on my IPhone.
Just wondering if anyone else has had the same issue / problem.
Will need to go hunting in the garage to find the older Android one, and see if that still works, as I need to do the rear disc's and pads.........
Thanks in advanced👍
8 minutes ago, Dr'R' said:
Evening all,👋
Car is '18.
Thanks in advanced👍
I’ve got the next gen iOS version of OBDeleven (replaced my original android only version last year) but I’ve only used it for long coding so haven’t actually tried the apps.  If I get chance tomorrow I’ll see if I get the same message.
15 hours ago, Dr'R' said:
Thanks, that would be a massive help if you manage to get the time.👍
I'll have another play tomorrow.
Then garage hunting for my old Android one.....🙄
Hi Dale, I've had a go using the apps now (2nd Gen Obdeleven on iOS) and they are working fine on mine. I tried a few and all actioned the changes (and reverts) so sounds unfortunately like yours has an issue of some kind.  Is it a device you bought new or used?  Maybe try it using your Android device first and see if it works with that.  If not I'd get in contact with obdeleven to see what they say.  You might also have a search on the obdeleven forum for advice https://forum.obdeleven.com/
I hope you get it sorted ok. OUt of interest do you have the Pro version?  If so you could you do the brakes using coding?
You're a ⭐, thanks so much for trying. 👍
Got it new, direct from OBDEleven, ordered it Nov '20.
So got to work early this morning, cleared out the workshop, put car in, closed the doors, put the heater on, and thought i'm going to get this thing working.......
After 45 mins of trying, couldn't even get the damn thing to connect...............:banghead: Strong WiFi signal, or via a strong 4G signal.
Plug it in, it lights up red, press connect, put my 6 digit code in, in then flashes or pulses a white light, and the app is just stuck on 'connecting'
Tech really isn't my fortay.....
Have contacted OBDEleven, will just have to wait for their responce...............
Yes, I have the Pro version, I'll need to hunt for my old Android one........and the old Android phone, 🙄 try that, if it works, then look for the coding sequence.
Thanks again for taking the time out this morning👍
2 minutes ago, EcosseGolfR said:
The old version was white and I think it was android only, I had to purchase a new one last month and it’s black and good for both android and IOS.
Thanks👍
I just need to find the old Android only one....................🙄
Damn!  Have you tried the old chestnut of deleting and reinstalling the OBDeleven app?  Worth a try as I’ve had to do that in the past (with the old version).
That's a good call.👍
I'll give it a try tomorrow.
4 hours ago, Dr'R' said:
Thanks.👍
Yes, running the latest IOS update, what ever that maybe!
I'll delete the app, then reinstall it tomorrow, and see if that sorts it.
Not too surprising, as we're up to iOS 14.4, but sometimes there's an old phone lying around ...
Hang on, I still have the old Android version so haven't tried using iOS, and I prefer to use VCDS, but shouldn't you be connecting via Bluetooth, not WiFi?
Edited by Chris7.5R
