Scudgie Posted December 3, 2021 Report Share Posted December 3, 2021 Thanks to the link @Booth11 provided, setting up dual Nav display is straightforward. First ensure your bonnet is open then navigate to module 5F (multimedia), hit adaptation and scroll down and open Dashboard_Display_Configuration, then change ability_switch_nav_maps from yes to no. I restarted my infotainment and was able to select maps on both screens from there neilybealy, JonnyG, Wrex and 3 others 3 2 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 3, 2021 Report Share Posted December 3, 2021 Thanks for the great write up John, really useful. Even though I rarely use VW nav maybe I’ll code this just for the hell if it as it really should have been like that as standard. Scudgie 1 Quote Link to comment Share on other sites More sharing options...
Mange Posted December 27, 2021 Report Share Posted December 27, 2021 Didn´t worked for me :)... What do you mean with " ""was able to select maps on both screens from there"" So many option to select maps 🙄... Quote Link to comment Share on other sites More sharing options...
Wrex Posted December 28, 2021 Report Share Posted December 28, 2021 Tried tho but it’s telling to up grade to pro for £24.99 to do it Quote Link to comment Share on other sites More sharing options...
Scudgie Posted December 28, 2021 Author Report Share Posted December 28, 2021 21 hours ago, Mange said: Didn´t worked for me :)... What do you mean with " ""was able to select maps on both screens from there"" So many option to select maps 🙄... I put the Infotainment into Nav mode and then used the view button on the steering wheel to change the dash screen until it showed the Map Quote Link to comment Share on other sites More sharing options...
Scudgie Posted December 28, 2021 Author Report Share Posted December 28, 2021 12 hours ago, Wrex said: Tried tho but it’s telling to up grade to pro for £24.99 to do it What does yor obdeleven profile say about your existing subscription? Wrex 1 Quote Link to comment Share on other sites More sharing options...
Mange Posted December 28, 2021 Report Share Posted December 28, 2021 It WORKS!!!. And so Awesome!. Thanks for saving 1000 Euro! Scudgie 1 Quote Link to comment Share on other sites More sharing options...
Wrex Posted December 29, 2021 Report Share Posted December 29, 2021 10 hours ago, Scudgie said: What does yor obdeleven profile say about your existing subscription? Says: Plan - Basic I have 195 credits but they are for one click apps apparently Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 29, 2021 Report Share Posted December 29, 2021 1 hour ago, Wrex said: Says: Plan - Basic I have 195 credits but they are for one click apps apparently You need Pro activation to do any coding changes such as this one. Basic subscription is only for the pre-set apps. Pro is worth it as it gives you the option to do much more, and importantly gives the you much greater control over what you are changing (with a record of it) whereas with the apps you have no idea what is being changed in the background. Wrex, Mange and Scudgie 3 Quote Link to comment Share on other sites More sharing options...
Scudgie Posted December 29, 2021 Author Report Share Posted December 29, 2021 8 hours ago, Wrex said: Says: Plan - Basic I have 195 credits but they are for one click apps apparently Ah that's crap. Without mentioning where, I don't think you live far from me. If you don't want to fork out for the pro activation, send me a message and I'd be happy to meet and code it for you. Wrex 1 Quote Link to comment Share on other sites More sharing options...
Wrex Posted December 30, 2021 Report Share Posted December 30, 2021 @Booth11 and @Scudgie I do apologise for the late reply, I got called in to work. I used to get an email when I had a reply/message on here but I don’t seem to anymore 😕. @Scudgie thank you, but I’ve already paid the extra for the pro before I saw l your message 😬. I’m going to try tomorrow to add the dual screen nav. I’ll let you know how I get on 👍🏻 Booth11 and Scudgie 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted January 13, 2022 Report Share Posted January 13, 2022 Whilst I had my OBDeleven out for something else, decided to enable this even though I mainly use Google maps via CarPlay. The SFD Unlock process (using Google Authenticator) worked and change accepted. Restarted infotainment system and hey presto, maps on dash (in map view) and infotainment screen. Works a treat! 👍(thanks @Scudgie) Scudgie 1 Quote Link to comment Share on other sites More sharing options...
Scudgie Posted October 1, 2022 Author Report Share Posted October 1, 2022 With using Waze so much, I very rarely use the car's Nav and set my instrument cluster to show the map. When I restart my phone for whatever reason, I also have to open waze before it will show up as an icon in the Car's Android Auto menu. Only once and it's fine thereafter until my phone is restarted again. Obviously can't do that when I'm driving so I used Sat nav yesterday. Tried to put the map in the instrument cluster and nothing came up. Checked this morning using Obdeleven and found that the adaptation I made was reset. My car spent a week or so at the garage in July trying to fix an issue with the heated steering wheel air con menu activation (still not fixed) and I don't know if the garage performed this reset or whether it was done OTA. Obviously the Air Con and Multimedia have their own module(s) so I'm not quite sure why the garage would even check this. Has this happened to anyone else? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted October 1, 2022 Report Share Posted October 1, 2022 1 hour ago, Scudgie said: With using Waze so much, I very rarely use the car's Nav and set my instrument cluster to show the map. When I restart my phone for whatever reason, I also have to open waze before it will show up as an icon in the Car's Android Auto menu. Only once and it's fine thereafter until my phone is restarted again. Obviously can't do that when I'm driving so I used Sat nav yesterday. Tried to put the map in the instrument cluster and nothing came up. Checked this morning using Obdeleven and found that the adaptation I made was reset. My car spent a week or so at the garage in July trying to fix an issue with the heated steering wheel air con menu activation (still not fixed) and I don't know if the garage performed this reset or whether it was done OTA. Obviously the Air Con and Multimedia have their own module(s) so I'm not quite sure why the garage would even check this. Has this happened to anyone else? Yes. You’re not alone John. Since I did the dual map obdeleven tweak aback in Jan my car has been in the dealership for work. I never use the VW. However I’ve just checked now after seeing your post, and yes, it’s reset to previous standard setting like yours has. Mine went in to dealership end Jan for a new battery and had the 1896 update at same time so that work must have reset it. Didn’t reset the Lane Assist tweak I did though. Scudgie 1 Quote Link to comment Share on other sites More sharing options...
Scudgie Posted October 1, 2022 Author Report Share Posted October 1, 2022 7 hours ago, Booth11 said: Yes. You’re not alone John. Since I did the dual map obdeleven tweak aback in Jan my car has been in the dealership for work. I never use the VW. However I’ve just checked now after seeing your post, and yes, it’s reset to previous standard setting like yours has. Mine went in to dealership end Jan for a new battery and had the 1896 update at same time so that work must have reset it. Didn’t reset the Lane Assist tweak I did though. Didn't reset my lane assist or soundaktor tweaks I had the 1896 update OTA so think you might be right about that. Booth11 1 Quote Link to comment Share on other sites More sharing options...
