Soundakator App Issue
lorne_ranger
New to OBD Eleven, been messing about with apps the last few days before I start getting into adaption and long coding etc.
On the sound actuator on my facelift Mk 7.5, I've used the app and changed this to off, but the next time I plug in the OBD Eleven, connect and check the setting, it's back at original, done it 3 times now and every time I go back in and check it's back on original.
Tried the OBD Eleven forums but no responces so far.  Any ideas?
Does changing any of the driving modes overwrite it being turned off?
You probably won't want to hear this, but the general advice you'll get from many experienced coders is NEVER use the apps, as they don't give you any clue as to what's been done and can be a real bugger to undo the changes. Proper coding (get the Pro licence) is much safer and involves you in what you're doing to your car. The other advice is ALWAYS make one change at a time, make a permanent record of what you did, and test it thoroughly before making any further changes. The simple souls, who dive in and throw in any change that sounds interesting, so often screw things up badly. Here endeth the lesson. 🙂
A9 Structure Borne Sound => Adaptation => Volume of structure-borne noise actuator => change 100.00% to 0.00%
Cheers.
I got the pro version with a 1 year subscription, so will give that change a try.
Aye I don't want to do any complex changes, just subtle easy ones.l, and be able to scan and read any fault codes.
6 hours ago, lorne_ranger said:
So I checked A9 module and % is already set to 0.00%.
The app still shows set to original.
So will stick to the adaptions and coding, like you said, then I can be sure what I'm actually changing, and see what the original settings were should anything go wrong!
When you're more comfortable with this, if you send me an email I'll give you my list of quite useful (and safe!) changes that I made during my 2 years with the 7.5R.
  • 1 month later...
On 29/12/2021 at 04:35, Booth11 said:
@lorne_ranger  There’s also plenty of tried and tested safe coding tweaks in this very section that members have kindly shared on the forum, so well worth a look as that is the purpose of this section.
Thanks, Managed to find the proper coding on here and sort it.  Going down the coding change myself route other than the apps, as I want to understand what I'm actually changing better.
Turned out the Soundakator had went off, it's just the one click app is crap and shows it on even though it's off.
  • 1 month later...
  • 4 weeks later...
Opposite problem here
(S3 8V, similar to 7.5R)
Changed structure borne soundaktor to 0% successfully a couple of months ago (through adaptation), and was missing it, (car is too quiet) so turned it back to 100% and it doesn’t work.
The OBD11 app shows its at 100% and all, but when driving the sound doesn’t come on.
Tried output test but it was unavailable - red light here.
Did a key off/on reset but still output test not available.
Nothing was done physically since the turning off, so I have no idea what I’m doing wrong here (or what went wrong).
Any suggestions ?
