AHG Posted September 15, 2022 Report Share Posted September 15, 2022 1 hour ago, 8YARWY said: That’s barely audible is that the chirp or did you turn on SignalHorn ? — Quittungston_ueber_hupe Quote Link to comment Share on other sites More sharing options...
8YARWY Posted September 15, 2022 Report Share Posted September 15, 2022 That’s barely audible is that the chirp or did you turn on SignalHorn ? — Quittungston_ueber_hupe It’ll do for me. Don’t want something blaring out especially early in the morning or late at night. It’s subtle enough. Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted September 15, 2022 Report Share Posted September 15, 2022 34 minutes ago, Booth11 said: Good to know Sean. Is the one highlighted in blue in your VCDS the channel you changed on your RS3? From what I glean from [mention=20064]dv52[/mention] Don’s very helpful list for the mk8 it might be: 09 ZV Quittierungen Quittierungston_bei_entriegeln (Acknowledgment_beep_on_unlock) Quittungs_ton_bei_verriegeln (Acknowledgment_tone_when_locking) However, with the 7/75R coding, as well as coding actual beep/tone on unlock and lock, it had a specific coding option to activate it in the menus as above in the first part of Don’s post. From your pics that apparent in the second menu photo. Was that something you coded to appear in the menu? I don’t see the mk7/7.5 channel in the likely equivalent mk8 channels in Don’s list. For the 7/7.5 for chirp on lock/unlock, it’s: 09 Acknowledgement signals Akustische Rueckmeldung entriegeln - Unlock acoustic feedback Akustische Rueckmeldung verriegeln Lock acoustic feedback and then to activate it in the menu: Menuesteuerung akustische Rueckmeldung - Menu control acoustic feedback Wondering if the Menuesteuerung akustische Rueckmeldung has an equivalent in the mk8. I’ve yet to delve into it with my obdeleven but will take a look this weekend. I used this for the MMI menu Quittungston_hmi_einstellbar' option in the MMI to turn beep on/off Pop the bonnet and open SFD (in the RS3 I had too at least) Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 15, 2022 Report Share Posted September 15, 2022 9 minutes ago, AHG said: I think it’s this: — Quittungston_hmi_einstellbar is the same as Menuesteuerung (- menu control) (HMI - human machine interface, einstellbar - adjustable) if to see it as parallel to what I’ve done in my 8V the 6 lines @DV52 mentioned are the ones — If you want chirp instead of horn - leave out line 3 (I think) — If you want it to beep only when closing (what I do) (opening does 2 beeps. lots of noise) - leave out line 1 I’ve extended my Pro plan (for 50€, they raised the fees) hope to try it this weekend (+ sign recog) and will update. Ah I missed seeing that last entry in Don’s 3rd list, I am due an eye test. Yes that does look to be the equivalent for the selectable menu option, thanks. I want the chirp but in both lock and unlock, not the horn. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 15, 2022 Report Share Posted September 15, 2022 Just now, 8YARWY said: I used this for the MMI menu Quittungston_hmi_einstellbar' option in the MMI to turn beep on/off Pop the bonnet and open SFD (in the RS3 I had too at least) Sent from my iPhone using Tapatalk Thanks Sean, yes I see that in Don’s final list now @AHG has mentioned it, I missed it originally. Yes same on the Golf R, the bonnet has to be popped and SFD required for some things. Quote Link to comment Share on other sites More sharing options...
AHG Posted September 15, 2022 Report Share Posted September 15, 2022 How do I open SFD ? I have 2-step with Authenticator Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 15, 2022 Report Share Posted September 15, 2022 9 minutes ago, AHG said: How do I open SFD ? I have 2-step with Authenticator If it has SFD protection, it will require you to generate a code (from the authenticator) and input it. I use Google Authenticator. The instructions are quite clear on the obdeleven app. Bit of info here though taken from Obdeleven website https://www.vwroc.com/forums/topic/40501-sfd-capability-now-added-to-obd-eleven-app/?do=findComment&comment=608210 Quote Link to comment Share on other sites More sharing options...
AHG Posted September 15, 2022 Report Share Posted September 15, 2022 Great I read the instructions by OBD11, and I have the Google, same as you. Just wasn’t sure what “open SFD” meant - thx ! Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Report Share Posted September 16, 2022 @AHG @dv52 @8YARWY Thanks for your input. Tried it this morning and happy to say it worked! Thanks very much @dv52 Don for your deciphering and translating of the mk7/7.5 channels into the mk8 channels. You were spot on of course. 👍 I wanted the chirp (not the horn) on both unlock and lock so did the following: - Popped the bonnet - Central Electrics 09 - ZV Quittierungen Quittierungston_bei_entriegeln (Acknowledgment_beep_on_unlock) Change to Active Quittungs_ton_bei_verriegeln (Acknowledgment_tone_when_locking) Change to Active Quittungston_hmi_einstellbar (Acknowledgment tone_hmi_adjustable) Change to Active This did not require SFD unlock on mine . I did an idiot guide with screen shots which I’ll post up in a separate thread. dv52, AHG and 8YARWY 3 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted September 16, 2022 Report Share Posted September 16, 2022 I’ve moved subsequent chat and troubleshooting posts on this adaptation to the coding thread to save conversations spanning two seperate threads. 👍 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
