DCC adaptation not working
Dan_Moore
Hi, had the golf r up on jack stands today for some underbody repairs and thought I'd try the dcc calibration while it was hanging there.
I followed a couple of guides online, checked values in adaptations, came out entered the security code etc,
but no matter what I do when I hit the green tick in basic settings for "adapting with deflected wheels" it says "incorrect sequence"
Anyone know what I'm doing wrong or how to fix?
24 minutes ago, AHG said:
I can’t help but am interested in following
is it a mk7 or mk8 ?
It's a 7, I think I need to check the level sensors when it's up to see that they are in the right parameters for it to work. I'll try again tomorrow and update.
  • 1 month later...
  • 2 months later...
Sorry for the late response, but I compiled an updated guide (based on info online and personal experience) to help with the DCC adaption basic setting.
Instructions for performing a basic setting on adaptive dampers (DCC) using OBDEleven
1. You MUST make sure the wheels of the car are fully off the ground before recalibrating. The wheels must sag fully to successfully calibrate. DO NOT PERFORM THE CALIBRATION IF ERRORS ARE PRESENT ON SUSPENSION OR WITHOUT THE WHEELS FULLY SAGGING!
2. Also, you may need a login code to perform this function which can be car-specific. Please refer to this OBDEleven article for directions on how to get this: https://support.obdeleven.com/en/articles/5608799-security-access
3. After the car is on the lift/stands and you have the login code for the control module, do the following:
  - Enter Control Module 14 - Adaptive Suspension.
  - Go to "Adaptions".
  - Select "Adapting with deflected wheels".
  - Take note of the values (to know if the basic setting function works).
  - Go back to the "Adaptions" menu.
  - Go to "Basic Settings".
  - With the car in the air, start the calibration (it won't take long).
  - Enter the security code (from step 2) to continue.
  - Basic Setting should complete successfully.
  - Go back to the values screen to compare the values.
  - If the values are different to before, you are done.
  - If this doesn't work, you may need to approach a VW specialist.
Hi thanks for this, I've just purchased 2 new oe front level sensors as I was getting an error now and again after going over humps or roundabouts that let the front suspension fully extend. The sensors on there now aren't vw ones there ebay copies.
I'll try and fit them next week and follow your guide once I've done it, see if that works.
  • 4 months later...
Do you know how to obtain the login code?
  • 4 months later...
Just an update for anyone experiencing the same problem with a lowered car.
The dcc adaptation can only be performed when the level sensors are in the correct range, mine couldn't get in that range due to the coilovers it would also sometimes throw a cornering light error code.
So I've shortened the arms of the 2 front level sensors by 10mm and everything is good. No more errors and I'm able to complete the adaptation following the guide listed above.
Below is the link for shortening the sensors, I used the cutting and rejoining method at the bottom of the thread and it still works a treat 4 months on from doing it.
https://www.vwvortex.com/threads/kw-dcc-coilovers-installation-and-impressions.7442882/page-3
  • 1 year later...
It does not make sense recalibrating lowering springs. The run out that houses the spring will be the same hight as before when tightening them in to seat them inside. There is no play, as they will touch inside bottom to top. So, when you jack all 4 wheels up your wheels end up in the same position as before hence hardly any difference in calibration number changes All lowering springs do, is reduce compression force by being a little shorter but no shorter than the actual oem fitting that houses the springs. Spring resistence by design will also be less hence the ... drop when you sit the car down on to the ground. All that is needed is wheel alighnment. Anyone stating that recalibrating a DCC did wonders is imagening.
