Service warning reset
BlackG7R1972
Sorry if this seems like a basic question, but i'm not very tech savvy.
I have an old OBDeleven box that I haven't used for about 5 yrs, it seems to be working, and have updated the app on my Android phone.
But I cannot find a menu that allows me to reset the service warning, which I would have thought would have been one of the most commonly used and simple function on the app.
Can any one help please ?
  • Replies 4
As said you can do this without obdeleven.
Is yours a mk7?  If so, have a look at these posts for how to do it on a mk7.
https://www.vwroc.com/forums/topic/23212-reset-service-in-how-mode/?do=findComment&comment=374390
https://www.vwroc.com/forums/topic/30720-how-to-reset-oil-change-now/
@BlackG7R1972: Hi - to add to the sage advice already provided and if you are keen to re-energize your OBD11 coding skills (always an excellent thing! 😉)  - then this is what to do:
The procedure described below is for something that VW call "FIX SRI" which is the system used in most cars - FIX SRI simply means that the period between oil change is the earlier of a fixed distance traveled (usually 15,000 Kms), or a fixed time interval (usually 365 days).
The complete SRI re-setting procedure has two separate parts which should be completed in the sequence shown below:
  1. Reset the traveled distance and day counters
  2. Reset the warning message on the Dashboard
For part 1  - follow the steps in my pictorial instructions below.
For part 2 - do this
  1. Go to the Dashboard module (see first picture above)
  2. Scroll down the screen and select Adaptation (see second picture above)
  3. Enter  "ESI" into the search box and select ESI: Resetting ESI
  4. Change value to no warning
  5. Exit OBD11 and cycle ignition key
