Stop Start
aldfort
Do you have a Ghost?
When I had mine fitted the fitter said he could code it out with Ghost.
Now it acts like it's got one of those memory modules fitted,  every time you switch on the ignition and enter your code it reverts to the last setting.
No lights on the dash either,  just "Start/Stop Disabled" on the screen which disappears after a few seconds.
16 hours ago, aldfort said:
Is it still possible to code stop start to off as the default on post 2023 cars?
Mike: Hi.
As Rebecca has advised - with the term "code" in your question, the answer is definitely NO. However, without this limiting word, the answer is YES.  Incidentally and forgive my pedant ways - but it's "Start Stop" (not "Stop Start")
Again, if "code" is not in your question -  there are lots of versions of a physical device that can be retrofitted to a mk8 (AFAIK, not a mk8.5)  to achieve the same outcome . Mr Google is your friend and there are quite a few different sellers on Aliexpress!
55 minutes ago, madmark said:
although i haven't done many miles in my car i have noticed its never stop started since i have had it
so does it stay off if selected ?
Not on the 8.5, you have to re-select each time you start the car. I think it was the same for the 8 as well.
@madmark; Hi.
Although SS is endemic to almost every module in the car - there is actually a phalanx of prerequisites that need to be satisfied before the engine is switched-OFF - like the following
  • The driver is wearing their seat belt.
  • The driver door is closed.
  • The bonnet is closed.
  • The factory-fitted towing bracket is not attached electrically to a trailer.
  • A minimum engine temperature has been reached.
  • The vehicle has been moved since the engine was last switched off.
  • For vehicles with Climatronic: the temperature inside the vehicle is within the pre-set temperature range.
  • The defrost function of the air conditioning system is not switched on.
  • The charging state of the vehicle battery is sufficient.
  • The temperature of the vehicle battery is not too low or too high.
  • The vehicle is not on a steep incline
  • For vehicles with an automatic gearbox: the front wheels are not angled too sharply.
  • The windscreen heating is not switched on.
  • Reverse gear is not engaged.
  • The park assist system (Park Assist) system is not active.
As I said, if any ONE of the conditions above are not satisfied, SS won't work (which is a good thing IMO because I utterly despise this most dangerous feature)!!
7 hours ago, dv52 said:
@madmark; Hi.
Although SS is endemic to almost every module in the car - there are actually a phalanx of prerequisites that need to be satisfied before the engine is switched-OFF - like the following
The planets must align!   As you say this is just as well as it is a hateful feature.
