MK 7 R OPERATING TIPS/TRICKS
  • 7 months later...
On 07/05/2021 at 01:30, TonyB66 said:
On a UK Mrk 7 is it possible to activate Apple Car Play without having to pay VW to do it for you?
Although it’s possible to do most things without Car Play it’s one feature I wish I had on my car that isn’t activated.
Reading through the post doe tips and tricks for my new golf mk7 R.
Its possible for free, ive done it myself as i diddnt want to pay vw a 500€ fee.
Put in you serial number, see wich version technisat or delhpi and download the software. Its a 10 min install and all functions like voice control, performance monitor, carplay  android auto...
Thought i might share it as it could be usefull for others
@sanderIt might be more useful if you can explain a little more please?
Put serial number in where?
Download software from where?
Thanks.
Thanks.
Basicly you remove your comonent protection of the radio.
this was the step by step guide i had to follow( if your unit is from technisat uou need a different version of the patch.
You can find out here https://mib-helper.com/ by putting in your software train. You can also find sofware versions of your radio bit also all the uptodate navigation maps
mibMST2 activator by Congo & Duke (Official Way)
BEFORE YOU READ FURTHER:
  1. On VW, press and hold MENU button on the display of your MIB2 for 3 seconds and then go to Software Update/Versions and take a look at SW Train string.
    On Audi use the corresponding button combo to open RED menu and then look into Versions info
  2. Make sure train starts with MST2 and ends with D. For example: MST2_EU_VW_P0891D. Only in this case, everything below applies to your unit!
attachments.redirect?id=42c24972-0fd0-4cba-ba7c-c9d231c1ebd2
If your SW Train ends with T (for example MST2_EU_VW_ZR_P0254T) your unit is Technisat/Preh for which you need MIB STD2 PQ/ZR Toolbox).
If you want to see more details about your SW Train, use http://mib-helper.com
#Supported firmwares (trains)
All Audi and VW firmwares of any region with train matching pattern MST2_xx_xx_xxxxxD
Tested and confirmed FW versions: P0120D, P0123D, E0220D, P0225D, P0227D, E0231D, P0314D, P0504D, P0628D, P0631D, P0635D, P0642D, P9122D, P0867D, P0870D, P0876D, P0890D, P0891D, P0879D, P0883D (883, not recommended, as the POI and meta exploint no longer works)
#addFecs: FEC Adding 00030000, 00040100, 00050000, 00060100, 00060200, 00060300, 00060400, 00060800, 00060900, 00070100, 00070200, 00070400, 09400008, 09410008, 094D0008, 094200ee to FEC list
#Installation (use windows pc /no Mac)
  1. Format quality 4Gb+ SD card in FAT32 with the smallestcluster size possible (usually4096 bytes) NO Micro
  2. Unpack Activator onto the SD card (no micro sd card + adapter!)and make sure metainfo2.txt is in the root.
  3. Insert the SD card into SD1 slot,
#Script/Patches CP_off (after use/installing activator by Congo & Duke, then script run working)
from the ReadMe.txt:
This activation also enables the option to automatically run scripts from SD card.
To use that preare SD card with a file called delphi.sh + delphibin.ifs on it. Remove any SD cards from the unit and insert the SD card with the script in slot 1 (SD1) or slot 2 (SD2) then restart the MMI.
On start up unit will wait for 10 seconds in case SD2 is used and execute the script.
As part of the congo activator installation, the UART console input will also be enabled(D-Link).
!As always: use at your own risk! Anyone who modifies/manipulates files on their unit must be aware of the risk of a brick!
There are 3 radio variants "STD2", "STD2Nav" and "STD2Plus" (use the right patches file!!)
Script for Delphi_MST2_CP_OFF patches=> download here with howtodo
