MK 7 R OPERATING TIPS/TRICKS
I think the only reason VW/Audi have it now is because the patent expired on Fords.
VW's one is far superior to the mid 90s screens - as mentioned by Shug because it doesn't have a load of wavy lines all over it!
It also clears really quickly.
I'm happy that I specc'd it, and would do it again, but do wish it had a physical button to operate it - you have to enter the menu system to do it. Same for climatronic...
  • 1 month later...
3 hours ago, voorhees said:
My Ford work colleagues seem to done before me so unsure whether the climate screen is quicker :(
Haha, yes.  Their Heated Seats are quicker too!
But best not to dwell about it on here.....nor on the fact they have little wavey wires in their ‘ Screens that make the screen look smeary at times.
  • 1 month later...
Two I’ve learnt in the short time I’ve had the car.
When you’re in a left lane on cruise control and the car sense that you’re going to undertake someone and applies the brakes.
Before it  slows you down, tap the accelerator and the car carries on like normal.
When in eco it coast las which is sometimes ok and sometimes really frustrating. So for example, if you’re coming off a slip road and don’t want it to cost just press the down paddle and it will re-engage the last gear it was in and hold it until you press the brakes or accelerator to then it resets and coasts next time you let off.
Edited by Rwagon
I had the annoying "No-Undertaking" coded out at my last service.  It's annoying enough when a dimwit decides to drive in the overtaking lane at well below the speed limit, without my own car deciding to get in on the act and add to the irritation.
Note for non-Australians:  It is perfectly legal here to undertake someone on a multi-lane highway (as long as you don't exceed the speed limit while doing so).
  • 2 weeks later...
Please elaborate.  Can you tell exactly how they did it.
4 hours ago, golf7.5r said:
Using VCDS
Module 13 Adaptive Cruise Control - ACC
long coding
byte 02 (bit 5 ticked)
overtaking_right_prevention set it from active to not active
That's what I told my indy to code.
If you need a security code you could try 20103 or 14117 or 47115
If you also want to get rid of the annoying nagging safety msg that keeps on displaying on the infotainment screen (consider others, drive safely, respect speed limits etc),
 set byte 23 to hex00 in the module at address hex5F
We don't get that in the UK - must be because you drive upside down that you have to take more precautions :grin:
More likely they know you are all a mob of hoons who always speed, break all the road rules etc all the time, so it would be a waste of time..... ;)
When I first got my R I thought it must know when I've been speeding because the msg kept appearing all the time.
  • 3 weeks later...
Here's probably the simplest, least expensive, lamest tip ever, but it works like a charm for the spatially challenged like me as I find the reversing camera distortion screws with my brain.
Start the vehicle, select reverse. View the image in the infotainment screen, measure the distance between the guidlines up the top, find the centre, make a small neat mark on the screen at that point.    Use the mark as a "sight" to aim and aid reversing.
Now practising self-isolation, I've found you can only wash the car so many times in a day.
  • 2 weeks later...
On 20/12/2019 at 07:22, jamesonhurst said:
Is there anyway of turning esc off and not having every single bright orange warning light on the dash visible??! 😎
I believe OBDEleven can cure the esc if you want it off permanently. Haven’t tried it myself I just remember the option being there.
Why do you want to turn ESC off ?  Just turning traction control off is enough to allow launch control.
