MK 7 R OPERATING TIPS/TRICKS
On 01/04/2018 at 13:23, VWR2018 said:
Thing is - there is the option in the deeper menus to display in bar/psi but VW don’t fit the TMPS to the wheels.
The in-wheel sensors are OK on a new car, but a PITA after a few years as they start to play up.
Never had any issues with the current low-rent system apart from it is unable to detect if your tyre has deflated overnight.
On 29/07/2018 at 11:03, Parttimer said:
Mines been a lot better since the latest update released a couple of weeks ago.
The last update for maps on the VW website is dated 4/3/18. Not sure if this is in UK or US date format, but either way it wasn't a few weeks ago? Is there a way to find out if there is an update without going through the pain of trying it i.e. a version number?
  • 3 weeks later...
At first glance it appears not - right clicking on the link to the update for my region shows http://vw-mapscdn.tdd.adacorcdn.com/DiscoverMedia2_EU1_2718_1030.7z
which is not much like the version 5NA919866 in the car.  However, on closer look the file name shows 1030 at the end, which is the second line on my car's display.  So that suggests I could see if that number has changed since the one in my car.  Perhaps that file name is EU1 for European Countries region 1, map release 27 of 2018?
If I run Discover Care on my PC, it tells me whether there is an update available.  That is the quickest method I have found.  I put a short cut to it in the pop out for apps when I click on the windows button, so it is quick to get to.  The current version for my car is 1030 ECE1 2018/19 which I think refers to European Countries region 1 , map version 2018/2019. So that implies it will remain valid into 2019.
I think that if your car is connected to the internet (mine just achieves that in the garage if the door is open) it can search for updates - but I hesitate to think how long it could take to download.  Using DiscoverCare, it took over an hour to download the file, then a similar time to copy it to the SD card.  At least once the SD card is in the car it is live, unlike my previous car - a Volvo - which then had to copy it across to the car's hard disk before it could work. That could take an hour WHILE DRIVING.
Display on buying the car (7/2017) second hand in April 2018.
After updating in May 2018
After updating again in August 2018.
Screen shot today from DiscoverCare
Edited by FrustratedGolfer
added content about file names, and explanations to the images
Reporting map errors
http://www.vw.com/faq/#colctrl_237
except that there is no such link because here have changed their site!
At present, the place to go is Here Map Creator though you will need to create an account with them to enable editing.
supplied current link
I got my Golf  last week and noticed the map didn't have a new road near me on it. I'd already downloaded the zip file, but wasn't sure of the best way to update the system. Your instructions made it easy and it only took 15 minutes to copy the files to the OE card. Many thanks for your post.
Whilst I'm here, does anyone know if it's possible to insert safety cameras onto the card? That seems to be the only thing I'm missing on the nav.
TIA.
  • 3 weeks later...
On 12/07/2015 at 01:26, Remlapeel said:
You can change the distance on the ACC by pressing the car symbol then using the +/- sign.
on the 7.5, you can keep pressing the car symbol to cycle through the distance options; personally i find that easier.
On 25/02/2018 at 10:17, calvinbui said:
Does anyone know how to pause audio from the steering wheel? I can only do previous/next. Turning the volume down/muting it pauses however.
If you have the bigger screen (without the knobs), you can tap the on/off button once and it will mute/pause for you. I know it's not what you are looking for but it works well for me! of course long press is to switch off/stand by mode to get the analog clocks.
As for me,  have these additions (if they ever matter):
  1. you can have the speed displayed in the center between the 2 gauges, very helpful if you chose different info displayed in the gauges. I can share a pic if you guys want.
  2. i noticed that the numbers in the speedo & rpm gauges illuminate more around the needle and darker on the farther sides. I thought this was neat!
On 26/07/2018 at 09:55, Cammie133 said:
Hi All, I have just had my R delivered. Can you please tell me how to set it up so the nav on the digital dash is facing the direction of travel? Does that make sense?
Hi,
in 2D view you can select the direction of travel using the compass icon in the top right hand corner, in 3D map view it will always point in the direction of travel.
A guy with a gti came into work today and saw my R, he was talking about doing bits and bobs and i noticed one thing he had done to his door seals, in the Gap on the top of the door, he had run some small tube ??? I didn task him about that, but any ideas what that would be for
Just guessing, but probably to reduce rattling/creaks when driving coming from the doors. I never had the issue but apply Sonax GummiFluger on occasion to the seals to keep them lubricated.
I did the same on my old 6R.
Completely eliminated any creaks and rattles coming from the door seals.
I used some form of irrigation tube you can find in hardware stores.
Really, thats an interesting trick.. it doesnt impede the window closing ?
