Funkmeister Posted March 17, 2018 Report Share Posted March 17, 2018 On 08/03/2018 at 23:22, k20evo said: Anyone figured how to get the interior lights to turn on when you turn off the ignition? My MK7 GTD did it, but in my MK7.5R they only turn on when the doors are opened Sent from my Pixel 2 XL using Tapatalk My 7.5 puts the interior lights on when I remove the key from the ignition after turning off the ignition and before the door is opened.. Is yours keyless by any chance? Quote Link to comment Share on other sites More sharing options...
k20evo Posted March 18, 2018 Report Share Posted March 18, 2018 53 minutes ago, Funkmeister said: My 7.5 puts the interior lights on when I remove the key from the ignition after turning off the ignition and before the door is opened.. Is yours keyless by any chance? I am yep, however my MK7 GTD was too and the interior lights came on when turning off the engine. Seems like a MK7.5 thing :/ Quote Link to comment Share on other sites More sharing options...
Matrix2020 Posted March 19, 2018 Report Share Posted March 19, 2018 On 18/03/2018 at 00:32, k20evo said: I am yep, however my MK7 GTD was too and the interior lights came on when turning off the engine. Seems like a MK7.5 thing :/ I am sure you have checked, but I assume you have pressed the light button on the roof console, to enable the lights on when the doors open, that turned mine on when I turn the ignition off. Mines a 7.5, but not keyless. Quote Link to comment Share on other sites More sharing options...
k20evo Posted March 19, 2018 Report Share Posted March 19, 2018 I am sure you have checked, but I assume you have pressed the light button on the roof console, to enable the lights on when the doors open, that turned mine on when I turn the ignition off. Mines a 7.5, but not keyless.Yup comes on when the doors open. Reading online, it seems a lot of the VAG cars with kessy have this same problem.Wonder what made the GTD different thenSent from my Pixel 2 XL using Tapatalk Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted March 28, 2018 Report Share Posted March 28, 2018 On 11/23/2017 at 12:49, Northnoble said: If you double press the lock button on the key (within 2-3 seconds) the car locks and the interior sensors are deactivated thanks, i must try that. i'd locked the car to nip into a shop & then wondered who's car alarm was going off..... mine, the dog was in there. Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted March 28, 2018 Report Share Posted March 28, 2018 On 10/1/2017 at 17:04, Tam said: Can anyone tell me how to turn off the internal motion sensors. I.e. When popping into a shop and leaving the kid in the car (I can see her from the shop window) i've just read on a later post on here that if you press the lock button on your remote twice within 2-3 seconds it locks the door but turns internal motion sensors off. I'll be trying it when the dogs in next time. hopefully it works as it'll be easier than going through the screen menu every time to turn it off. No button on my door pillow either. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted March 29, 2018 Report Share Posted March 29, 2018 3 hours ago, FoxyTiger said: i've just read on a later post on here that if you press the lock button on your remote twice within 2-3 seconds it locks the door but turns internal motion sensors off. I'll be trying it when the dogs in next time. hopefully it works as it'll be easier than going through the screen menu every time to turn it off. No button on my door pillow either. Be aware that leaves your car locked but not deadlocked. If you have left your windows open for ventilation for your dogs (compulsory if the sun is shining) then a thief could reach in through the open window and simply open a door by pulling on the lever twice (assuming your dogs don't rip their arm off as they do it). That's why I use the (very fiddly) infotainment method. Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted March 29, 2018 Report Share Posted March 29, 2018 7 hours ago, gregozedobe said: Be aware that leaves your car locked but not deadlocked. If you have left your windows open for ventilation for your dogs (compulsory if the sun is shining) then a thief could reach in through the open window and simply open a door by pulling on the lever twice (assuming your dogs don't rip their arm off as they do it). That's why I use the (very fiddly) infotainment method. 7 hours ago, gregozedobe said: Be aware that leaves your car locked but not deadlocked. If you have left your windows open for ventilation for your dogs (compulsory if the sun is shining) then a thief could reach in through the open window and simply open a door by pulling on the lever twice (assuming your dogs don't rip their arm off as they do it). That's why I use the (very fiddly) infotainment method. Cheers for that info, don’t think I’ll try that then, will use the menu screen Quote Link to comment Share on other sites More sharing options...
slider09 Posted March 29, 2018 Report Share Posted March 29, 2018 That's why I use the (very fiddly) infotainment method. Or just press the button on the bottom of the b pillar if you have it. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Idylla Posted March 29, 2018 Report Share Posted March 29, 2018 On 13/03/2018 at 14:42, Idylla said: This is my current plan! I've disabled via OBDEleven and while I now have to press the engine stop button - when getting out of the car I'm much happier overall. Quote Link to comment Share on other sites More sharing options...
gregozedobe Posted March 29, 2018 Report Share Posted March 29, 2018 3 hours ago, slider09 said: Or just press the bottom on the bottom of the b pillar if you have it. Unfortunately it seems said button is yet another casualty of VW's recent cost-cutting exercises ( I suppose they have to pay for their USA dieselgate fines somehow ) It is much easier to use the button in my Octavia when I want to temporarily disable the interior motion sensors. Quote Link to comment Share on other sites More sharing options...
Shug Posted April 1, 2018 Report Share Posted April 1, 2018 Question... Driving in M4 yesterday when suddenly tyre pressure warning light came on. Was approaching exit, car felt fine, so slowed and left motorway. Pulled over once off motorway and all tyres looked okay (realise pressing with finger not scientific but only a short way to destination). When arrived at sons house, borrowed his footpump and pressure gauge and all tyres at same pressure (36 psi). left the car an hour and checked again, all good. reset tyre pressure monitoring, and drove home today, no lights showing. Checked tyres at home and all pressures fine. Guessing an electronic glitch? Anyone else had this? Quote Link to comment Share on other sites More sharing options...
Gavras Posted April 1, 2018 Report Share Posted April 1, 2018 8 minutes ago, Shug said: Question... Driving in M4 yesterday when suddenly tyre pressure warning light came on. Was approaching exit, car felt fine, so slowed and left motorway. Pulled over once off motorway and all tyres looked okay (realise pressing with finger not scientific but only a short way to destination). When arrived at sons house, borrowed his footpump and pressure gauge and all tyres at same pressure (36 psi). left the car an hour and checked again, all good. reset tyre pressure monitoring, and drove home today, no lights showing. Checked tyres at home and all pressures fine. Guessing an electronic glitch? Anyone else had this? Had this happen on mine, on one occaision it had dropped 2 psi. i really hate the system and consider it very low rent / cost saving exercise by VW. for the price sector the car is sitting in, it should allow you to see pressures and temperatures real time. far too many false positives with this cheap type of system. Idylla 1 Quote Link to comment Share on other sites More sharing options...
Shug Posted April 1, 2018 Report Share Posted April 1, 2018 1 hour ago, Gavras said: Had this happen on mine, on one occaision it had dropped 2 psi. i really hate the system and consider it very low rent / cost saving exercise by VW. for the price sector the car is sitting in, it should allow you to see pressures and temperatures real time. far too many false positives with this cheap type of system. Agree. Even SWMBOs Corsa has actual pressures displayed on the dash once you scroll through the menus... Quote Link to comment Share on other sites More sharing options...
VWR2018 Posted April 1, 2018 Report Share Posted April 1, 2018 Thing is - there is the option in the deeper menus to display in bar/psi but VW don’t fit the TMPS to the wheels. Quote Link to comment Share on other sites More sharing options...
