AdeA Posted January 26, 2018 Report Share Posted January 26, 2018 This does not work on my '18... You have to tap the throttle to re-engage the adaptive cruise. Must be a feature they removed on newer models... EricIt works on my Dec' 17 estate. I do seem to have to hold the button for a moment, a very quick press doesn't work. Sent from my SM-G930F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Summons Posted January 26, 2018 Report Share Posted January 26, 2018 Hmmm... 'Long press' I may not have tried. I didn't pay attention those times I tried to resume with the aforesaid button. I will follow up. Eric Quote Link to comment Share on other sites More sharing options...
phil4 Posted January 26, 2018 Report Share Posted January 26, 2018 A bit like the using the up down arrows to zoom the map, in Audio mode, you can use the buttons to browse the files and folders and select other songs to play. A bit like on the main display. Quote Link to comment Share on other sites More sharing options...
_Golfgirl_ Posted January 26, 2018 Report Share Posted January 26, 2018 okay lets get super technical The pointy bit on the bottom of the filler cap is there so that it can be stored in the little hole on the inside of the filler door as you fill the tank, thus eliminating the cap dangling against your paint work! I'm pretty sure I made that as clear as mud! Mine always falls off. It doesn’t seem to fit on as well as the one that was on my Mk 5.Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Parttimer Posted January 27, 2018 Report Share Posted January 27, 2018 21 hours ago, Summons said: Hmmm... 'Long press' I may not have tried. I didn't pay attention those times I tried to resume with the aforesaid button. I will follow up. Eric Just tried the long press and it worked for me on a December car. Quote Link to comment Share on other sites More sharing options...
mikef4uk Posted January 27, 2018 Report Share Posted January 27, 2018 On 24/09/2017 at 20:03, Booth11 said: Is yours a faecelift car? Well documented that on pre facelift (dsg) cars in Race or Individual with S gearbox selected, the gearbox defaults back to D after ignition fully off. The mode remains selected but gearbox defaults to D. Mines a,ways in Individual mode, but always have to put gearbox back into S on startup. You audibly hear the change of exhaust sound as the outer flaps engage. I cant work mine out (R 7.5) in 'individual' with engine in 'race' sometimes with the DSG I get the 'D' and sometimes I get the 'S' Also what I would like to know is I normally use manual in the individual or race mode as I find in 'S' just holds gears when I want it to change and 'D' has more abrupt/harsher changes and can go up and down the box needlesly, I tend to either use Comfort in auto or Individual/Race in manual, to my question: Besides the higher idle between 'S' and 'D' mode which the high idle also transfers over when selected into 'Manual' mode are there any other changes carried over into Manual mode from the 'S' mode? Quote Link to comment Share on other sites More sharing options...
Andygo Posted January 27, 2018 Report Share Posted January 27, 2018 I have an early 7.5 , my son a 67 plate dsg. He was in my car today and noticed that when I press the mode switch on the centre console, my choice of modes are in monochrome, whereas he said his were in colour. When did that change and is there a software update? Quote Link to comment Share on other sites More sharing options...
maccas99 Posted January 29, 2018 Report Share Posted January 29, 2018 On 1/27/2018 at 16:12, Andygo said: I have an early 7.5 , my son a 67 plate dsg. He was in my car today and noticed that when I press the mode switch on the centre console, my choice of modes are in monochrome, whereas he said his were in colour. When did that change and is there a software update? Isn't this the difference between DCC and non-DCC equipped cars? Quote Link to comment Share on other sites More sharing options...
Maynard_Said Posted January 29, 2018 Report Share Posted January 29, 2018 Isn't this the difference between DCC and non-DCC equipped cars?Mines colour and I’m non-DCCSent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
AdeA Posted January 29, 2018 Report Share Posted January 29, 2018 Is there a list somewhere of what the various settings in Individual mode actually do? The manual appears completely devoid of such information! Edit: Sorry, thought this was the quick question thread! Quote Link to comment Share on other sites More sharing options...
cannyjock Posted January 29, 2018 Report Share Posted January 29, 2018 Would love to know this too. Quote Link to comment Share on other sites More sharing options...
ellixtt Posted February 19, 2018 Report Share Posted February 19, 2018 On 29/01/2018 at 17:47, AdeA said: Is there a list somewhere of what the various settings in Individual mode actually do? The manual appears completely devoid of such information! Edit: Sorry, thought this was the quick question thread! When you select “Individual Mode” underneath you can press “Setup” and you can change what you want for example ACC on eco, steering on sport, engine on normal etc. Rather than having everything on Normal when you select Normal Mode you can fine tune it to your liking. Quote Link to comment Share on other sites More sharing options...
cannyjock Posted February 19, 2018 Report Share Posted February 19, 2018 1 hour ago, ellixtt said: When you select “Individual Mode” underneath you can press “Setup” and you can change what you want for example ACC on eco, steering on sport, engine on normal etc. Rather than having everything on Normal when you select Normal Mode you can fine tune it to your liking. The question was though, what do the different options in individual do? For example Drive? Does engine sound only affect the soundaktor? Quote Link to comment Share on other sites More sharing options...
ellixtt Posted February 19, 2018 Report Share Posted February 19, 2018 59 minutes ago, cannyjock said: The question was though, what do the different options in individual do? For example Drive? Does engine sound only affect the soundaktor? It changes the dynamics of the car and how it feels through each one, choosing the engine will change things like exhaust valves opening, etc. But soundaktor will change accordingly. Quote Link to comment Share on other sites More sharing options...
FamousAfroJay Posted February 19, 2018 Report Share Posted February 19, 2018 How do you get the central display to show the boost and G meter and such. Quote Link to comment Share on other sites More sharing options...
