Gavras Posted July 23, 2018 Report Share Posted July 23, 2018 6 minutes ago, rjwojcik said: Sorry to hear about your woes. So does standard sat nav show speed limits or did you have to buy another option to get this feature? It just shows speed limit by default, nothing special. Quote Link to comment Share on other sites More sharing options...
mortys Posted July 23, 2018 Report Share Posted July 23, 2018 On 26.1.2018 at 07:44, gregozedobe said: When I'm driving along with ACC set to 73kmh (close to actual 70kmh), if I press the "+" button to add 10kmh when I pass an 80 speed sign the ACC goes to 80kmh, not the 83kmh I was expecting (ie it goes to the next 10kmh increment, it doesn't add 10 to the current speed). It's slightly annoying, but my work-around of pressing the "RES" button 3 times gets me back to the actual speed I want (displayed 83kmh = actual 80kmh) without too much drama. I guess it is just another example of "nannyism" sneaking in to our cars (where the designers think they know better than the drivers). I know "first world problems" Acc + and - will give you 10km/h increments based on round numbers 10,20,30,40,50,60,70,80,90 (and so on). If you want to go somewhere in between the round numbers you need to use set/res to increase/decrease in 1km/h increments. This is how i supposed to work. Quote Link to comment Share on other sites More sharing options...
PJM85 Posted July 23, 2018 Report Share Posted July 23, 2018 Just picked up a brand new R 7.5, loving the car but is there a way to display the road speed limit on the active info screen when in navigation mode? Also I was under the impression that speed cameras would be highlighted on the display but I haven’t seen this yet. My car is totally standard. Thanks! Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 23, 2018 Report Share Posted July 23, 2018 Played around with different settings in Individual mode, everything in sport except the engine in eco. Start car, into Sport on the gearbox and no soundaktor but valves open and everything else in Sport. Feels and sounds really good, and then back in eco mode it doesn't do the free wheeling bit.Exactly how I have mine set up Sent from my SM-G935F using Tapatalk Quote Link to comment Share on other sites More sharing options...
Gavras Posted July 24, 2018 Report Share Posted July 24, 2018 23 hours ago, rjwojcik said: Sorry to hear about your woes. So does standard sat nav show speed limits or did you have to buy another option to get this feature? As requested. Speed is in top left. this is from the Nav and is not always accurate. rjwojcik 1 Quote Link to comment Share on other sites More sharing options...
rjwojcik Posted July 24, 2018 Report Share Posted July 24, 2018 11 minutes ago, Gavras said: As requested. Speed is in top left. this is from the Nav and is not always accurate. Appreciate it. Very similar to what I'm used to in my GTD Mk7. You know you're going the wrong way 😉 Quote Link to comment Share on other sites More sharing options...
Gavras Posted July 24, 2018 Report Share Posted July 24, 2018 2 minutes ago, rjwojcik said: Appreciate it. Very similar to what I'm used to in my GTD Mk7. You know you're going the wrong way With VW Sat Nav you are never really sure if you are going the right way or wrong way. dual carriageway and roundabout FoxyTiger and Matrix2020 1 1 Quote Link to comment Share on other sites More sharing options...
Cammie133 Posted July 26, 2018 Report Share Posted July 26, 2018 Hi All, I have just had my R delivered. Can you please tell me how to set it up so the nav on the digital dash is facing the direction of travel? Does that make sense? Quote Link to comment Share on other sites More sharing options...
Steven Heeley Posted July 26, 2018 Report Share Posted July 26, 2018 Press the symbol n on the screen Cammie133 1 Quote Link to comment Share on other sites More sharing options...
Cammie133 Posted July 26, 2018 Report Share Posted July 26, 2018 Thanks Steven. That’s better Quote Link to comment Share on other sites More sharing options...
Modena Posted July 27, 2018 Report Share Posted July 27, 2018 I saw this asked, but not answered. In a keyless variant, how do I get the interior lights to switch on when I turn the ignition off? They come on when I open the door, but even cheap cars have this feature of turning them on when ignition is stopped....??? Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted July 27, 2018 Report Share Posted July 27, 2018 On 26/07/2018 at 09:55, Cammie133 said: Hi All, I have just had my R delivered. Can you please tell me how to set it up so the nav on the digital dash is facing the direction of travel? Does that make sense? Keep pressing the north button in top right hand corner. one way north is always pointing up on map, and car drives different directions on the map. the other way north moves around but on the map your car always drive upwards. if that makes sense. thats if you believe the directions the satnav is taking you, mostly I don’t 😟😟😟 Quote Link to comment Share on other sites More sharing options...
Parttimer Posted July 29, 2018 Report Share Posted July 29, 2018 On 23/07/2018 at 17:31, Gavras said: I have the standard Nav on my 7.5 and it's abysmal, really really bad. i would have better luck throwing darts at a map. even the speed limits it display are wrong at times. roads I have driven on for 30 years it says are say 50mph but they have always been 40mph. its the worst Sat Nav I have seen in any car. Mines been a lot better since the latest update released a couple of weeks ago. Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted July 29, 2018 Report Share Posted July 29, 2018 21 minutes ago, Parttimer said: Mines been a lot better since the latest update released a couple of weeks ago. How do you do an update ? Or do you have to go into a vw dealer for it ? Quote Link to comment Share on other sites More sharing options...
Parttimer Posted July 29, 2018 Report Share Posted July 29, 2018 8 minutes ago, FoxyTiger said: How do you do an update ? Or do you have to go into a vw dealer for it ? Go to the VW web site, https://webspecial.volkswagen.de/vwinfotainment/int/en/index/downloads/maps-download#/ Follow the links for your model. I always download the zip file to pc and extract it on there, then copy the files over to your existing SD card. Don't forget to back up the current files though. FoxyTiger 1 Quote Link to comment Share on other sites More sharing options...
