Stego Posted January 5, 2019 Report Share Posted January 5, 2019 Hi Wagon R, Thank you so much for your effort! I checked, and it seems I still have version 7, not 7.5 - so I can't find this menu entry. I tried to update it, but with the VW-own download software, there is always some check-sum error for the file, even with different computers. So, I contacted VW, and I hope they answer soon - then I'll see if it works. I'll let you know! Have a good time Stego Quote Link to comment Share on other sites More sharing options...
Wagon R Posted January 7, 2019 Report Share Posted January 7, 2019 On 05/01/2019 at 23:07, Stego said: Hi Wagon R, Thank you so much for your effort! I checked, and it seems I still have version 7, not 7.5 - so I can't find this menu entry. I tried to update it, but with the VW-own download software, there is always some check-sum error for the file, even with different computers. So, I contacted VW, and I hope they answer soon - then I'll see if it works. I'll let you know! Have a good time Stego Try again, @Stego. My Wife’s Polo is a 66 plate it has the older unit, which I think is the same as the one in the Mk7 R. There is a HARD “menu” button at the bottom right of the facia - ABOVE the tuning knob - which is where you’ll find the main menu! press “Setup"! At the very top of the screen that opens when you press "Setup" are the “screen” options. That’s the one you need to look at. EDIT: Follow the image numbers. Quote Link to comment Share on other sites More sharing options...
LapizzR Posted January 17, 2019 Report Share Posted January 17, 2019 Is there any way to increase the brightness of the led's inside the car? Quote Link to comment Share on other sites More sharing options...
Fletch..gti Posted January 17, 2019 Report Share Posted January 17, 2019 Yes going to settings ,then into lights and it’s in there Quote Link to comment Share on other sites More sharing options...
sc52 Posted January 22, 2019 Report Share Posted January 22, 2019 On 09/07/2014 at 02:10, AgentFruit said: First turn the dial/switch to L, then put the car in reverse, then adjust the mirror to the angle you'd like for reversing. It'll remember this setting. Leave the switch on L, then when you drive forward the mirror should revert to normal. If you select reverse again with the switch still on L the mirror will tilt itself down to its last programmed angle. In future, whenever you're in reverse you can choose whether to have the mirror angled down by selecting L, or remaining normal by leaving the switch in the centre or to R. Excellent. Many thanks Quote Link to comment Share on other sites More sharing options...
GolfRWag Posted February 11, 2019 Report Share Posted February 11, 2019 Noticed this today (MY19 7.5 R Wagon/Variant in Oz): In Individual drive mode setting, selecting "race" drive mode for gearbox gave quicker takeoff and upshifts but did NOT provide the usual upshift fart sharpness nor the overrun burble and pops. So I also selected "Race" in Sound in Individual mode and suddenly there it was. In addition to the usual Soundaktor in-cabin vroom vroom it also adjust the pop-fart noises out the back! (I have my Soundaktor turned down to 50% max to better enjoy the exhaust noise when I choose) Clearly, the Sound parameter tells the engine mapping to do something different with fueling and spark in order to add extra tailpipe theatrics to the overall experience. And in the 7.5 wagon there are no flaps to open/shut so its pretty much all software driven real (nice) noise out the back. Quote Link to comment Share on other sites More sharing options...
AndrewJ-R Posted March 6, 2019 Report Share Posted March 6, 2019 Some great tips in here - only had it 2 days but had already been struggling and book did not really help! Quote Link to comment Share on other sites More sharing options...
Shug Posted March 6, 2019 Report Share Posted March 6, 2019 I normally have the screen on, with either satnav or music showing. After 18 months I turned the screen off and found I have a selection of clock faces I can pick. Now the first world problem of which one I prefer... Quote Link to comment Share on other sites More sharing options...
JammyHamster Posted March 28, 2019 Report Share Posted March 28, 2019 Anyone else noticed the car picture (estate in my case) moves right on the head unit as your petrol is used.... Or am I just going mad 😳🤪😵 This also happens on Passat and wife's Golf match! Has anyone got a picture with range zero? Idylla 1 Quote Link to comment Share on other sites More sharing options...
Aidey Posted March 28, 2019 Report Share Posted March 28, 2019 No your not going mad, it does go right as you get emptier Quote Link to comment Share on other sites More sharing options...
Lone Cyclist Posted March 30, 2019 Report Share Posted March 30, 2019 On 16/11/2015 at 21:19, Millzy68 said: To be honest I've only done hundred miles or so but was always ready to take the big hit on fuel consumption. I'm hoping once I force myself to take it out of Race Mode (if that's possible!) it might not be too bad. I'm sure whatever mpg I get, it'll be worth it. Hi On my second R 300miles on a long run considering the performance that's not bad imho Quote Link to comment Share on other sites More sharing options...
Lone Cyclist Posted March 30, 2019 Report Share Posted March 30, 2019 On 01/04/2018 at 10:32, Shug said: Question... Driving in M4 yesterday when suddenly tyre pressure warning light came on. Was approaching exit, car felt fine, so slowed and left motorway. Pulled over once off motorway and all tyres looked okay (realise pressing with finger not scientific but only a short way to destination). When arrived at sons house, borrowed his footpump and pressure gauge and all tyres at same pressure (36 psi). left the car an hour and checked again, all good. reset tyre pressure monitoring, and drove home today, no lights showing. Checked tyres at home and all pressures fine. Guessing an electronic glitch? Anyone else had this? Hi Get this from time to time , just reset and all ok. sensor in the hub seems to measure the circumference of the tyre maybe as the tyres wear this could fool the sensor - go figure! Quote Link to comment Share on other sites More sharing options...
rRRRM Posted March 31, 2019 Report Share Posted March 31, 2019 On 12/03/2018 at 04:12, SMUL3 said: I’ve never turned it off as it saves me messing with the handbrake Sent from my iPhone using Tapatalk When you are stopped, e.g. at lights, I think it reduces the risk of being propelled forward into oncoming traffic if you are rear-ended. Therefore I normally have it on at all times. I was taught to always the handbrake under the same circumstances. Quote Link to comment Share on other sites More sharing options...
Aidey Posted March 31, 2019 Report Share Posted March 31, 2019 Any tips to get my 7.5 manual R to do so Pwp's ?? Had it 6 months now and it pretty quiet..... Quote Link to comment Share on other sites More sharing options...
Wagon R Posted March 31, 2019 Report Share Posted March 31, 2019 2 hours ago, Aidey said: Any tips to get my 7.5 manual R to do so Pwp's ?? Had it 6 months now and it pretty quiet..... Race mode …Manual or Paddles, Downshift and back off throttle at over 3500+rpm. Quote Link to comment Share on other sites More sharing options...
