IanT Posted December 13, 2020 Report Share Posted December 13, 2020 On 16/11/2020 at 11:15, Booth11 said: I bet you wished they you didn’t have them fitted the mess they make on a clean car. 😂 (obviously coding off is the answer). Yeah I always turn my lights off completely before I pull the lever to stop that mess, and then the lights back to auto straight after. Same on my last few Audis Something I learnt yesterday about my car after 28 month of ownership - If you're in 'P' and you open the drivers door the e-brake comes on automatically.... You live and learn eh 🙃 Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 13, 2020 Report Share Posted December 13, 2020 1 minute ago, IanT said: Yeah I always turn my lights off completely before I pull the lever to stop that mess, and then the lights back to auto straight after. Same on my last few Audis Something I learnt yesterday about my car after 28 month of ownership - If you're in 'P' and you open the drivers door the e-brake comes on automatically.... You live and learn eh 🙃 Haha better late than never. 😁 I haven’t touched the e-brake since I first got the car. I absolutely love that but of tech. Which is ironic as it was one of the things I was most dreading when switching from a mk6. 5 minutes ago, IanT said: Yeah I always turn my lights off completely before I pull the lever to stop that mess, and then the lights back to auto straight after. Same on my last few Audis I used to do similar before I got OBDeleven and coded the headlight washers off completely, but I used to switch to sidelights to pull the windscreen washer lever (for windscreen washing) to avoid the dreaded headlight washers activating, but only where it was safe to do so. In the end I wanted done with them completely so went the coding off route. Quote Link to comment Share on other sites More sharing options...
IanT Posted December 13, 2020 Report Share Posted December 13, 2020 1 minute ago, Booth11 said: Haha better late than never. 😁 I haven’t touched the e-brake since I first got the car. I absolutely love that but of tech. Which is ironic as it was one of the things I was most dreading when switching from a mk6. I used to do similar before I got OBDeleven and coded the headlight washers off completely, but I used to switch to sidelights to pull the windscreen washer lever (for windscreen washing) to avoid the dreaded headlight washers activating, but only where it was safe to do so. In the end I wanted done with them completely so went the coding off route. I haven't touched the e-break either since day one and use the hold assist but when I opened the door (I can't remember why I did it) I heard that unmistakable 'eeeeuw' noise and the e-brake light had come on. A safety feature I guess? Quote Link to comment Share on other sites More sharing options...
TonyB66 Posted May 6, 2021 Report Share Posted May 6, 2021 On a UK Mrk 7 is it possible to activate Apple Car Play without having to pay VW to do it for you? Although it’s possible to do most things without Car Play it’s one feature I wish I had on my car that isn’t activated. Quote Link to comment Share on other sites More sharing options...
GZOLA25 Posted May 24, 2021 Report Share Posted May 24, 2021 On 05/07/2015 at 17:27, Rebbitt123 said: i find pulling the dsg stick towards you enabling s mode from d is a bit less jerky when going to overtake,still drops down a few gears,i use this way a lot!! Yep, only had my car a few days but I keep pulling the gear stick back to get that extra power. 👍🤘 Quote Link to comment Share on other sites More sharing options...
Tiger's Wood Posted August 6, 2021 Report Share Posted August 6, 2021 On 07/05/2021 at 00:30, TonyB66 said: On a UK Mrk 7 is it possible to activate Apple Car Play without having to pay VW to do it for you? Although it’s possible to do most things without Car Play it’s one feature I wish I had on my car that isn’t activated. You need to have the car-net option enabled for your Nav (used to be an optional extra that you paid for, also came with some cruddy web connectivity that I never used, think I paid 100 quid at the time) ... don't think it's possible to enable by anyone except a dealer. Also, it wasn't even an option on earlier cars/nav units. I think it came in somewhere around Q2 2016 as I had to check when I was ordering my R that it was available and it just had started to appear. This was when the Disco Nav wasn't even standard - if you have a later car that came with it as standard I wouldn't be surprised if the Car play/Android Auto is standard too. Quote Link to comment Share on other sites More sharing options...
Jace Posted August 6, 2021 Report Share Posted August 6, 2021 On 07/05/2021 at 00:30, TonyB66 said: On a UK Mrk 7 is it possible to activate Apple Car Play without having to pay VW to do it for you? Although it’s possible to do most things without Car Play it’s one feature I wish I had on my car that isn’t activated. I've just ordered a Carlinkit dongle for mine , turns it from wired cable connection to a wireless, plus I can use it in my wifes "Match" wagen which we use when we do the longer run's. https://www.aliexpress.com/item/1005001763316407.html?spm=a2g0s.12269583.0.0.5c785e2fVT7qQW Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 6, 2021 Report Share Posted August 6, 2021 1 hour ago, Jace said: I've just ordered a Carlinkit dongle for mine , turns it from wired cable connection to a wireless, plus I can use it in my wifes "Match" wagen which we use when we do the longer run's. https://www.aliexpress.com/item/1005001763316407.html?spm=a2g0s.12269583.0.0.5c785e2fVT7qQW Great bit of kit to convert wired CarPlay to wireless, had one on my mk7R. You still have to actually have CarPlay function already though (or have it activated by VW or similar), and on mk7 only MIB2 cars (MY16 - built from end May 2015 onwards have the capability and even then some cannot have it activated as depends on the head unit. Quote Link to comment Share on other sites More sharing options...
TheGent Posted December 1, 2021 Report Share Posted December 1, 2021 Sorry i got to 10 pages then went snow blind. . . . . . is there a page for vagcom mods specifically ? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 1, 2021 Report Share Posted December 1, 2021 21 minutes ago, TheGent said: Sorry i got to 10 pages then went snow blind. . . . . . is there a page for vagcom mods specifically ? Have a look in the forum VCDS and Obdeleven sections. Still a lot to trawl through but at least it’s specific to coding etc. https://www.vwroc.com/forums/forum/29-vcds/ https://www.vwroc.com/forums/forum/84-obdeleven/ TheGent 1 Quote Link to comment Share on other sites More sharing options...
orb ytl Posted October 2, 2022 Report Share Posted October 2, 2022 On 16/11/2020 at 11:09, NRW said: Thinking about discovering things....confession time here. I had a Mk6/GTI for near 7 years, and only latterly did I kerching that it had headlight washers fitted as standard. I knew of the places on the bumper for the nozzles - I’d just assumed that because aI did not tick a box for headlight washers that mine would come without. 😳 did all mk6 gti have headlight washers? if so i owned one for 7 years and never knew that lol that must mean my mk7 R has them too? Quote Link to comment Share on other sites More sharing options...
NRW Posted October 2, 2022 Report Share Posted October 2, 2022 1 hour ago, orb ytl said: did all mk6 gti have headlight washers? if so i owned one for 7 years and never knew that lol that must mean my mk7 R has them too? Afaik - the headlight washers operate every 3rd time you use the windscreen washers, on 7.5R. You can code them out with OBD11. Nit sure how long they’ve been standard fit on a GTI - mine was a late one, bought new in May 2012. The Hesdlight washers can make a bonny mess on a newly washed, polished & waxed car😳 Quote Link to comment Share on other sites More sharing options...
NJS Posted October 2, 2022 Report Share Posted October 2, 2022 Headlamp washers on both my MK 7 and MK 7.5. They are coded to wash every 3 or 5 times that's true. It is nuisance the mess they make of the front of the car. If you code them out make sure to code them back in for the MOT. NRW 1 Quote Link to comment Share on other sites More sharing options...
Demise Posted December 16, 2022 Report Share Posted December 16, 2022 Learnt more things than I expected in here, despite the other half already having a Tiguan with DSG. All I will say to people starting from page 1, have a few cups of tea ready! Wagon R 1 Quote Link to comment Share on other sites More sharing options...
Madelvic Posted August 19, 2023 Report Share Posted August 19, 2023 On 06/08/2021 at 15:17, Jace said: I've just ordered a Carlinkit dongle for mine , turns it from wired cable connection to a wireless, plus I can use it in my wifes "Match" wagen which we use when we do the longer run's. https://www.aliexpress.com/item/1005001763316407.html?spm=a2g0s.12269583.0.0.5c785e2fVT7qQW Bought a few from China - one failed within days and no replacement/refund In my opinion (and experience) better from Amazon. A little dearer but no issues with returns Quote Link to comment Share on other sites More sharing options...
