gregozedobe Posted July 8, 2019 Report Share Posted July 8, 2019 19 minutes ago, slickrick30 said: Yep ive tried the LHS buttons on the steering wheel, it says ACC deactivated when I press anything. I was hoping there was a reset sequence or something Have you tried switching cruise control on (or swapped from the Speed Limiter function) ? I get that msg when I try to set the speed when cruise control is switched off. Quote Link to comment Share on other sites More sharing options...
slickrick30 Posted July 8, 2019 Report Share Posted July 8, 2019 Ill have a poke around again this evening but I dont think it will be as simple as that unforunately, theres an orange light on the dash Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 8, 2019 Report Share Posted July 8, 2019 Ill have a poke around again this evening but I dont think it will be as simple as that unforunately, theres an orange light on the dashPossibly a battery issue, that can cause random faults sometimes...Sent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
slider09 Posted July 8, 2019 Report Share Posted July 8, 2019 I disconnected and reconnected the battery on my car while working on the airbox When re connected i had a few errors but these self celared in a few mins. The adaptive cruise control still isnt working after about a 30min drive. Has anyone else had this problem? Previously no issue with itI had exact same thing after removing the battery to service the DSG. ACC took a couple of trips to reset itself. All the other lights went out on the first short drive. Sent from my iPhone using Tapatalk SpursMadDave 1 Quote Link to comment Share on other sites More sharing options...
slickrick30 Posted July 9, 2019 Report Share Posted July 9, 2019 Just an update, the light was off yesterday evening when I started it. It seems to have fixed itself! Be interesting to know processes the car goes through when the battery is disconnected etc... Im assuming now it takes a few days or hours to take baseline readings for the ACC before switching on slider09 1 Quote Link to comment Share on other sites More sharing options...
SpursMadDave Posted July 9, 2019 Report Share Posted July 9, 2019 Just an update, the light was off yesterday evening when I started it. It seems to have fixed itself! Be interesting to know processes the car goes through when the battery is disconnected etc... Im assuming now it takes a few days or hours to take baseline readings for the ACC before switching onI guess the ACC can take a little longer to adjust than things like the abs etcSent from my SM-G950F using Tapatalk Quote Link to comment Share on other sites More sharing options...
TheAlbionist Posted July 13, 2019 Report Share Posted July 13, 2019 Turns out a great way to disable Stop/Start by the backdoor is to install a dashcam with auto-switchon and a low voltage sensor and not use the car very much. My battery's now handily always just below the Stop/Start threshold when I start it. 😎 Quote Link to comment Share on other sites More sharing options...
Wagon R Posted July 13, 2019 Report Share Posted July 13, 2019 2 hours ago, TheAlbionist said: Turns out a great way to disable Stop/Start by the backdoor is to install a dashcam with auto-switchon and a low voltage sensor and not use the car very much. My battery's now handily always just below the Stop/Start threshold when I start it. 😎 I have a hard wired dual cam w\ battery cut off set at 12.4v. It seems my alternator must be better than yours as S\S still kicks in after 5 minutes driving. I coded it out for the winter months & re-enabled for the summer but it’s still a pain ...unless stuck in motorway traffic with ACC set to eco - then it saves you quite a bit in mpg. Quote Link to comment Share on other sites More sharing options...
tinman68 Posted August 23, 2019 Report Share Posted August 23, 2019 Apologies if this has already been mentioned... If you're using Android Auto, you don't have to tap the microphone icon on the media screen for voice commands, just press and hold the voice button on the steering wheel for a couple seconds.... Edit: This will work regardless of whether you have the VW speech recognition option or not SpursMadDave, L8tes, geemac and 1 other 2 2 Quote Link to comment Share on other sites More sharing options...
PJD Posted November 4, 2019 Report Share Posted November 4, 2019 Something I discovered by chance the other day. If you have Discovery Pro and have the satnav displaying on the virtual cockpit, when you use Android Auto and use the navigation option to set your destination the virtual cockpit satnav will disapear with a message saying something like mobile navigation in use. However if you then cancel your navigation on Android Auto, you will get your navigation back on the virtual cockpit along with the google maps displayed on the Android Auto app. So you can have google maps and VW maps displayed at the same time. Quote Link to comment Share on other sites More sharing options...
Charles M Posted November 24, 2019 Report Share Posted November 24, 2019 I've been using ECO quite a bit on motorway journeys (in conjunction with a PedalBox turned all the way up). If you set up ECO in Individual it seems not to work fully, as it would in ECO mode. It seems that it won't coast/go into neutral when you take your foot off the gas. Quote Link to comment Share on other sites More sharing options...
Clarkie48 Posted December 14, 2019 Report Share Posted December 14, 2019 When de frosting car is there any way of turning heating,blowers up full as well as rear screen on. Had this on my ST where 1 button would turn both front and rear screen on as well as turning heating up full and blowers. Quote Link to comment Share on other sites More sharing options...
Wagon R Posted December 15, 2019 Report Share Posted December 15, 2019 17 hours ago, Clarkie48 said: When de frosting car is there any way of turning heating,blowers up full as well as rear screen on. Had this on my ST where 1 button would turn both front and rear screen on as well as turning heating up full and blowers. Pressing the upper ‘fan’ portion of the left hand temperature controller will switch full power to front screen with a/c - the rest are separate controls... so in a word, No. Blame Ford for selfishly patenting the heated front screen. 😝 Quote Link to comment Share on other sites More sharing options...
NRW Posted December 15, 2019 Report Share Posted December 15, 2019 18 hours ago, Clarkie48 said: When de frosting car is there any way of turning heating,blowers up full as well as rear screen on. Had this on my ST where 1 button would turn both front and rear screen on as well as turning heating up full and blowers. Optional Climate Screen is,imho, better than Ford’s Quickclear. Unfortunately it is an Option tho. Agree it should be standard fit. 👍 Shug 1 Quote Link to comment Share on other sites More sharing options...
Shug Posted December 15, 2019 Report Share Posted December 15, 2019 1 hour ago, NRW said: Optional Climate Screen is,imho, better than Ford’s Quickclear. Unfortunately it is an Option tho. Agree it should be standard fit. 👍 way better than the ford screen, with little wires in the glass. patent must have expired by now, I had this screen in a Mondeo in mid 90s, but SWMBOs Corsa has it VW screen is a laminate conductive layer, so clear, but also has reflective coating so minimises heat gains from sum NRW 1 Quote Link to comment Share on other sites More sharing options...
