FoxyTiger Posted April 3, 2018 Report Share Posted April 3, 2018 Hi, any tips on parking in a space on a road, up a hill, with dsg ? Hadn’t thought about it before, but just tried. Didn’t want to lunge into car in front so drive off to find another road. With autobrake on you have to press accelerator quite a bit before moving (always turn it off when parking in garage so can just creep along). Can’t just slowly release hand brake like a manual one. What does everyone else do ??? Quote Link to comment Share on other sites More sharing options...
AdeA Posted April 3, 2018 Report Share Posted April 3, 2018 4 minutes ago, FoxyTiger said: Hi, any tips on parking in a space on a road, up a hill, with dsg ? Hadn’t thought about it before, but just tried. Didn’t want to lunge into car in front so drive off to find another road. With autobrake on you have to press accelerator quite a bit before moving (always turn it off when parking in garage so can just creep along). Can’t just slowly release hand brake like a manual one. What does everyone else do ??? I temporarily turn off auto-hold in that situation. It's then easy to creep forwards or backwards just by releasing the brake pressure, no need to touch the accelerator. Edit: I might have misunderstood! Shug 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 3, 2018 Report Share Posted April 3, 2018 11 minutes ago, FoxyTiger said: Hi, any tips on parking in a space on a road, up a hill, with dsg ? Hadn’t thought about it before, but just tried. Didn’t want to lunge into car in front so drive off to find another road. With autobrake on you have to press accelerator quite a bit before moving (always turn it off when parking in garage so can just creep along). Can’t just slowly release hand brake like a manual one. What does everyone else do ??? If you need to just disengage autohold so you can complete small manoeuvres, allow creep, then pop it back on at the end. You soon get used to it. I never bother disengaging autohold as have measure of it and can anticipate the delay and lurch and it’s second nature to me to account for that, but if very small parking manoeuvres are needed it’s easy enough to temp switch autohold off. No issues at all parking on hills. Gavras, Shug and rRRRM 1 2 Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted April 3, 2018 Report Share Posted April 3, 2018 11 minutes ago, AdeA said: I temporarily turn off auto-hold in that situation. It's then easy to creep forwards or backwards just by releasing the brake pressure, no need to touch the accelerator. Edit: I might have misunderstood! I turned autohold off temporarily, but then when I released the foot brake the car felt like it started to move back down the hill so reapplied the foot brake as was close to the car behind. Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted April 3, 2018 Report Share Posted April 3, 2018 15 minutes ago, Booth11 said: If you need to just disengage autohold so you can complete small manoeuvres, allow creep, then pop it back on at the end. You soon get used to it. I never bother disengaging autohold as have measure of it and can anticipate the delay and lurch and it’s second nature to me to account for that, but if very small parking manoeuvres are needed it’s easy enough to temp switch autohold off. No issues at all parking on hills. Guess I need to practice small manoeuvres on a hill with no other cars around Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 3, 2018 Report Share Posted April 3, 2018 2 minutes ago, FoxyTiger said: Guess I need to practice small manoeuvres on a hill with no other cars around It’ll come with practice. I park on a hill everyday at work and it’s second nature now. FoxyTiger 1 Quote Link to comment Share on other sites More sharing options...
Parttimer Posted April 3, 2018 Report Share Posted April 3, 2018 I just let Auto hold do its job on hills, never had a problem, only time I turn it off if I am manoeuvring slowly up really close to something or if I don't want the hand brake come on when removing the key. rRRRM 1 Quote Link to comment Share on other sites More sharing options...
VIJAY Posted May 7, 2018 Report Share Posted May 7, 2018 On 7/9/2014 at 14:23, AgentFruit said: With stop/start engaged, half depress brake to engage autohold, come off brake and engine will stay on for duration of that stop. Engine will only stop if brake is fully depressed. Great feature that prevents stop/start from being irritating. I use Race Mode all the time. Start-Stop is deactivated in Race and Sport Mode. Unfortunately, I had my battery replaced and Stop-Start started working in Race Mode also. Start - Stop in Race Mode? Silly😁 Quote Link to comment Share on other sites More sharing options...
chylld Posted May 9, 2018 Report Share Posted May 9, 2018 On 10/04/2017 at 03:44, 75Type2 said: Where I have spacers fitted. I use pencils to retain the spacers in the event they come away from the hub. Will invest in some modified threaded rod for future use, although I'm pretty sure I could buy said product off the shelf. Only skimmed through this thread, but this tip is genius. Was taking my Spielbergs off to weigh them (11.7kg) and the spacers fell off and went clang against the inside of wheel. Would prefer to not run spacers at all but they're needed to clear the APR BBK with stock wheels. 75Type2 1 Quote Link to comment Share on other sites More sharing options...
Millsn Posted May 22, 2018 Report Share Posted May 22, 2018 In android auto you can add new calendar items. They call them events, so tell it 'new calendar event" and it'll ask you a set of questions. You can also ask it "what's next" or "next calendar item" (or something similar) and it'll tell you the next item showing in your calendar RS6BRIT 1 Quote Link to comment Share on other sites More sharing options...
Andy1a2b Posted July 7, 2018 Report Share Posted July 7, 2018 (edited) On 09/07/2014 at 02:10, AgentFruit said: First turn the dial/switch to L, then put the car in reverse, then adjust the mirror to the angle you'd like for reversing. It'll remember this setting. Leave the switch on L, then when you drive forward the mirror should revert to normal. If you select reverse again with the switch still on L the mirror will tilt itself down to its last programmed angle. In future, whenever you're in reverse you can choose whether to have the mirror angled down by selecting L, or remaining normal by leaving the switch in the centre or to R. Great tip , I had this facility on a Passat Estate a few years back and a great help to avoiding kerbing the nearside alloys when parking. Edited July 7, 2018 by Andy1a2b Quote Link to comment Share on other sites More sharing options...
Gavras Posted July 23, 2018 Report Share Posted July 23, 2018 3 minutes ago, FoxyTiger said: does anyone else believe their car satnav's directions ?? mine doesn't like going under motorway bridges, it nearly always tells me to 'take a half left' (whatever that is) & get off the motorway, go up over the roundabout and get back straight on the motorway again, obviously i don't. It also told me get off & then later on get back on the same road 3 times on saturday (on the A46, from M40 to M69). Again i didn't because i knew the way, but what about the areas that i don't know where i'm going ????? anyone had problems, can you get them corrected or updated, 7.5 estate, purchased new this March ? I have the standard Nav on my 7.5 and it's abysmal, really really bad. i would have better luck throwing darts at a map. even the speed limits it display are wrong at times. roads I have driven on for 30 years it says are say 50mph but they have always been 40mph. its the worst Sat Nav I have seen in any car. FoxyTiger and Matrix2020 1 1 Quote Link to comment Share on other sites More sharing options...
FoxyTiger Posted July 23, 2018 Report Share Posted July 23, 2018 54 minutes ago, Gavras said: I have the standard Nav on my 7.5 and it's abysmal, really really bad. i would have better luck throwing darts at a map. even the speed limits it display are wrong at times. roads I have driven on for 30 years it says are say 50mph but they have always been 40mph. its the worst Sat Nav I have seen in any car. Yes mine the standard. Glad it’s not just me that thinks it’s useless, doesn’t help us though 😟 Quote Link to comment Share on other sites More sharing options...
Idylla Posted July 23, 2018 Report Share Posted July 23, 2018 I had the pro on my MK7 and I swear it was nowhere near as bad as the standard on the MK7.5... I never use it anyway, always use Waze on my iPhone and have the map displayed on the digital dash so I can zoom in/out etc hands free Apparently Waze is finally coming to CarPlay in September so will be interesting to see if it negates the need for my phone holder in the car! Quote Link to comment Share on other sites More sharing options...
rjwojcik Posted July 23, 2018 Report Share Posted July 23, 2018 1 hour ago, Gavras said: I have the standard Nav on my 7.5 and it's abysmal, really really bad. i would have better luck throwing darts at a map. even the speed limits it display are wrong at times. roads I have driven on for 30 years it says are say 50mph but they have always been 40mph. its the worst Sat Nav I have seen in any car. Sorry to hear about your woes. So does standard sat nav show speed limits or did you have to buy another option to get this feature? Quote Link to comment Share on other sites More sharing options...
