neg Posted March 19, 2015 Report Share Posted March 19, 2015 So when the indicator is in use this will dim the DRL on the side the indicator is flashing [09] Central ElectronicsSecurity Access and enter 31347Adaptation Channels 16 Leuchte2SL VLB10-Lichtfunktion G 2 to "Blinken links aktiv (beide Phasen)" 18 Leuchte2SL VLB10-Dimmwert to 35 19 Leuchte2SL VLB10-Dimming Direction GH 2 to "minimize" 16 Leuchte3SL VRB21-Lichtfunktion G 3 to "Blinken rechts aktiv (beide Phasen)" 18 Leuchte3SL VRB21-Dimmwert GH 3 to 35 19 Leuchte3SL VRB21-Dimming Direction GH 3 to "minimize" You can work out from the above you do the coding for each side and the 35 is what they dim too, you could use other values. crude video http://vid1333.photobucket.com/albums/w628/neilgibbs/7R/DRL%20dimming_zpsdyeo9qyw.mp4 sbp, MoMez and pablos007 3 Quote Link to comment Share on other sites More sharing options...
sbp Posted March 19, 2015 Report Share Posted March 19, 2015 Really need to get my hands on/find somebody who can do all these bits for me. A friend of mine has a 135i and uses the diagnostics equipment for that on my Mini - really nice to have the extra bits done but now I need him to buy a VW Quote Link to comment Share on other sites More sharing options...
keano Posted March 20, 2015 Report Share Posted March 20, 2015 Personally I like that the golf doesn't 'need' to dim the lights when indicating... better design in my view. All the cars that have craply designed light clusters that need the leds to dim look stupid - jag Xfs for example, it looks like the light is broken even though I know why its doing it... Useful to post these sorta things still though ninja_geezer 1 Quote Link to comment Share on other sites More sharing options...
andy3141 Posted March 20, 2015 Report Share Posted March 20, 2015 Personally I like that the golf doesn't 'need' to dim the lights when indicating... better design in my view. All the cars that have craply designed light clusters that need the leds to dim look stupid - jag Xfs for example, it looks like the light is broken even though I know why its doing it... Useful to post these sorta things still though I agree, it doesnt look quite right to me. But good of Neg to post the coding. There are many things that can be done with the indicators to customize the look, such as also blinking the drl at the same time as the indicator. Personally though, I think it looks best as standard. Quote Link to comment Share on other sites More sharing options...
neg Posted March 20, 2015 Author Report Share Posted March 20, 2015 I like the fact you can see the indicators better - for oncoming cars but like you say it doesn't need it. Quote Link to comment Share on other sites More sharing options...
MoMez Posted April 8, 2015 Report Share Posted April 8, 2015 I know this is slightly off topic, but it is to do with indicators... Does anyone know how to or think they could code the new audi indicators. I don't know about the front ones but I was thinking more for the rear indicator lights. Like this: http://images.gizmag.com/gallery_lrg/audi-dynamic-indicators-1.jpg Quote Link to comment Share on other sites More sharing options...
neg Posted April 8, 2015 Author Report Share Posted April 8, 2015 Can't be done - different interface. Quote Link to comment Share on other sites More sharing options...
MoMez Posted April 8, 2015 Report Share Posted April 8, 2015 Can't be done - different interface Thanks for clearing that up. Quote Link to comment Share on other sites More sharing options...
pablos007 Posted December 27, 2016 Report Share Posted December 27, 2016 Apologies for resurrecting an old post, but I wondered if this dims the headlights or just the DRL's. Looks like DRL only, and if that's the case, is there a setting that dims the headlights when the indicators flash? Thanks. Quote Link to comment Share on other sites More sharing options...
goRt Posted December 27, 2016 Report Share Posted December 27, 2016 Apologies for resurrecting an old post, but I wondered if this dims the headlights or just the DRL's. Looks like DRL only, and if that's the case, is there a setting that dims the headlights when the indicators flash? Thanks.Xenons are on or off, no in between ;-) Sent from my E6653 using Tapatalk Lawrie 1 Quote Link to comment Share on other sites More sharing options...
pablos007 Posted December 30, 2016 Report Share Posted December 30, 2016 Xenons are on or off, no in between ;-) Sent from my E6653 using Tapatalk Thanks for confirming. Will try the DRL mod when I get chance to hook up the VCDS. Quote Link to comment Share on other sites More sharing options...
Lawrie Posted December 30, 2016 Report Share Posted December 30, 2016 I dimmed mine to 26% using the coding above (but changed the value to 26 not 35) and OBD Eleven: https://vimeo.com/197509068 Quote Link to comment Share on other sites More sharing options...
pablos007 Posted December 30, 2016 Report Share Posted December 30, 2016 I dimmed mine to 26% using the coding above (but changed the value to 26 not 35) and OBD Eleven: https://vimeo.com/197509068 Thanks for sharing. I know some people don't like it, but I think anything that helps people see the indicators earlier is safer. Already done brake lights and pace car indicators with VCDS. Lawrie 1 Quote Link to comment Share on other sites More sharing options...
Silk Posted March 22, 2017 Report Share Posted March 22, 2017 So when the indicator is in use this will dim the DRL on the side the indicator is flashing [09] Central Electronics Security Access and enter 31347 Adaptation Channels 16 Leuchte2SL VLB10-Lichtfunktion G 2 to "Blinken links aktiv (beide Phasen)" 18 Leuchte2SL VLB10-Dimmwert to GH 2 35 19 Leuchte2SL VLB10-Dimming Direction GH 2 to "minimize" For the benefit of any other noobs like me that find this thread, the bold text in Red above is missing from the original instructions in post one. Cdj3.2, DUB R4XX and Booth11 3 Quote Link to comment Share on other sites More sharing options...
ninja_geezer Posted June 23, 2018 Report Share Posted June 23, 2018 will not even find them settings on my Nov 2016 build R. tried the app says not supported. Quote Link to comment Share on other sites More sharing options...
