Valves open in Normal Mode...and VCDS?
Ignition1
Does anyone know of a forum post that explains how to open the valves in driving modes other than Race or DSG Sport mode? I know someone who can VCDS for me, but wondering if there is a trick I can do - (like - switch on Race, shift DSG to Sport, then change drive mode to Normal)...?
Also - anyone know any good VCDS changes I could get done? In my old A3 I had rear DRLs and some random things added on. Wonder if there are many that can be done on the Golf / R?
VCDS can be used to open or close the valves. I don't think you can code the flaps to work any differently to how they do from factory. If you can it's definitely not well documented.
As for other tweaks there's quite a lot than can be activated or changed. My list of tweaks is as follows:
Start/Stop turned off
Full extended rear brake lights
Scandinavian DRLs - Permanently activated rear brake lights as DRL’s
Front DRL set to 100% brightness
Ignition warning Off
Seat belt warning Off
Fan Speed Indicator on Auto HVAC On
Lock / Unlock Chirp Notification
Instrument Cluster - Always On
main thing to remember when doing the flapper mod (either coded or unplugged like i did) is to make sure both flaps are in the open position when doing it.
I used a good torch to look up the pipe to see each flap was open.
You can't do anything other than disable them in VCDS
I'd like to see the 100% DRL's, please :)
Edit:
This is how you have open exhausts the whole time!
Thanks. In my old A3 I used to have the Scandinavian DRLs and Lock/Unlock Chirp.
I wasn't too sure about switching on the Rear DRLs on the R...the lights look very different to the LED "bar" the Audi's have. I do miss having the acoustic lock/unlock.
And I wish the Individual drive mode had an exhaust noise option to open or close the flaps...that would've been perfect. I love the valves open in S or Dynamic, but hate the fact it holds the revs before changing gear. I guess in a manual it's much easier to drive with the flaps open.
How have you done the instrument cluster mate?
