ashleyman Posted November 18, 2016 Report Share Posted November 18, 2016 It's been said by a few that they wish to permanently enable the instrument cluster lights regardless of the position of the light switch. I've managed to enable the cluster lights, along with other cabin lights so that they are enabled in all light switch positions except OFF - then they're off! There doesn't seem to be a way to separate the cluster lights from the cabin lights meaning that if you enable this tweak then your other cabin lights such as button backlights, door LEDs are all activated too. Instructions to do this are as follows: Open Controller - 17-Instruments Click Security Access and enter the code 25327 Click Adaption In the dropdown box you are looking for 'Illumination_algorithm-Scale_switching_algorithm' That setting should be set to 'parking_light' Change from 'parking_light' to 'lds' Press Do It! That should enable cluster & cabin lights in all light positions, at all times of day except for when the lights are OFF on the switch. This mod was successful on my 2016 Golf R and another local 2016 Golf R. Quote Link to comment Share on other sites More sharing options...
baz2011uk Posted November 18, 2016 Report Share Posted November 18, 2016 Cracking find will be doing this also as on Tuesday a drive to London on a very overcast day my cluster lights was on one minute and off the next like a yoyo lol Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted November 18, 2016 Report Share Posted November 18, 2016 Thanks to Ash for the coding last night. One question now though. Will the instrument cluster lights now always be on even when the light switch is set on auto? (Obviously they're off when the light switch is turned off) if so, I'll probably get the coding set back to OE as I actually like the auto switch being able to turn on / off the cluster lights when needed. I need to drive the car in daylight to see what's happening in the mean time. Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 18, 2016 Author Report Share Posted November 18, 2016 Thanks to Ash for the coding last night. One question now though. Will the instrument cluster lights now always be on even when the light switch is set on auto? (Obviously they're off when the light switch is turned off) if so, I'll probably get the coding set back to OE as I actually like the auto switch being able to turn on / off the cluster lights when needed. I need to drive the car in daylight to see what's happening in the mean time. Having just driven the wife to work, the cluster illumination is on and it won't turn off except when you switch to OFF, even in OFF if it detects particular ambient light, it'll turn them on. (This is why I wasn't sure about doing it to your car as I wasn't 100% sure of what the coding actually did. haha) Quote Link to comment Share on other sites More sharing options...
TheBlondeFella Posted November 18, 2016 Report Share Posted November 18, 2016 Thanks for letting me know Ash. In that case I'll get you to take the coding back to OE if that's ok? Quote Link to comment Share on other sites More sharing options...
ashleyman Posted November 18, 2016 Author Report Share Posted November 18, 2016 Thanks for letting me know Ash. In that case I'll get you to take the coding back to OE if that's ok? Yep! Just let me know when... Quote Link to comment Share on other sites More sharing options...
Mike7rlondon Posted November 19, 2016 Report Share Posted November 19, 2016 This looks interesting going to nip out to try this and see if I can add my 2 pence Quote Link to comment Share on other sites More sharing options...
Boj27 Posted July 26, 2017 Report Share Posted July 26, 2017 I've just done this. I have my lights in the OFF position and the dash lights stay on which is just what I was after, although I think this is because of the rear DRL coding instructions I have followed and activated too (this turned on all my interior lights, just not the dash lights). It's perfect now Mitch 1 Quote Link to comment Share on other sites More sharing options...
dv52 Posted July 27, 2017 Report Share Posted July 27, 2017 On 18/11/2016 at 20:10, ashleyman said: Having just driven the wife to work, the cluster illumination is on and it won't turn off except when you switch to OFF, even in OFF if it detects particular ambient light, it'll turn them on. (This is why I wasn't sure about doing it to your car as I wasn't 100% sure of what the coding actually did. haha) Ash: yes, that's exactly what the tweak is meant to do. The new setting is "lds" which is the term that VW uses for the rotary light switch. So, selecting this setting allows the driver to use the lds as a separate switch for this function But remember that there is a photo-transistor in the instrument cluster (between the "7" and "8" numerals on the tacho) that also modulates the dash lighting. So even if the rotary light switch is in the O position, the ambient cabin lighting from daylight will determine the cluster illumination Don Quote Link to comment Share on other sites More sharing options...
ashleyman Posted July 27, 2017 Author Report Share Posted July 27, 2017 On 26/07/2017 at 10:48, Boj27 said: I've just done this. I have my lights in the OFF position and the dash lights stay on which is just what I was after, although I think this is because of the rear DRL coding instructions I have followed and activated too (this turned on all my interior lights, just not the dash lights). It's perfect now If you have 'Scandinavian' lights coded then all the lights will stay on all the time. Quote Link to comment Share on other sites More sharing options...
