Winter pack
JORD7R
Mine has. Was built after the changes. Collected on 1st September. It has heated seats, headlight washer and fluid low warning light as standard.
Sent from my SM-G920F using Tapatalk
My 2014 built R (no options) has washer fluid level low warnings fitted. I was surprised as I thought this was a winter pack only item too...
Don't leather seats have heated as standard?
Sent from my GT-I9505 using Tapatalk
Yes they do. That is why the winter pack on a leather car was extremely expensive as the heated setas were already there so all you were getting for your money was heated washer jets.
I read somewhere recently that cars with Xenons which also had headlight washers now had a low washer level built in as part of some legislation but can't find it. This would explain why @Lawrie has this. Which would mean you get even less for the winter pack if you already have leather.
My partner just remarked also that my mk v GTi just seemed to heat the seated part of the seat, whereas my appears to heat the WHOLE seat! Tbh though, I use it rarely, just wear a coat lol..
It became standard at the same time as discover nav. So if your car was built after build week 22 '16 then it should have the winter pack and nav too. Luckily for me I ordered mine a few weeks before the spec change so got both chucked in for free. Which was nice as I was considering both options but didn't.
Can't ever recall when heated washer jets have made any odds to me though, it's fine if you park in a garage and the pipes aren't frozen solid, but parking outside it normally takes 1/2 an hour for the pipes to thaw enough to spray by which time I'm at work anyway.
I read somewhere that cars with Xenon headlights must be fitted with a low washer fluid warning, guess to keep the lights clean so they don't have the chance to dazzle people with excessively dirty headlights!
Yeah you're right, they worded it in the brochure/online configurator to sound like it wasn't included in the standard specification, probably hoping to trick people into speccing it just for the low level warning.
This happened as well , albeit my other Golf is a Mk5 GT Twincharger
I think you may be on to something but we're perhaps imagining deceit when none exists.
I bet they have a standard 'Winter Pack' wording which they use for all models regardless of whether xenons are equipped. If you don't have xenons you need the winter pack to get the low washer fluid warning, if you have xenons you have it fitted regardless.
