Booth11 Posted February 25, 2017 Report Share Posted February 25, 2017 Disable stop/start 1) Select Control unit 19 2) Select Adaptation 3) Select Stop start limit voltage 4) Change value to 12 (default is 7.6) 5) Press the green tick to confirm, or slide to confirm Lawrie, mcj and Heaton 3 Quote Link to comment Share on other sites More sharing options...
Rich_D Posted March 1, 2017 Report Share Posted March 1, 2017 There is another method where you change the coolant temp to something it will never achieve Quote Link to comment Share on other sites More sharing options...
slider09 Posted March 19, 2017 Report Share Posted March 19, 2017 There is another method where you change the coolant temp to something it will never achieve Won't that causes issues though? Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Rich_D Posted March 20, 2017 Report Share Posted March 20, 2017 Won't that causes issues though? Sent from my iPhone using Tapatalk No, there are certain target conditions the car needs to achieve for stop-start to function, battery voltage and coolant temp are the 2 ways you can disable stop-start with VCDS by changing the target conditions to something the car won't see, so drop voltage to say 11v or temperature to say 150c. Those targets won't alter how the car runs or affect the voltage or temperature, they are just values the car won't see and therefore it won't auto stop-start. slider09 and john mcclean 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted March 20, 2017 Author Report Share Posted March 20, 2017 I believe on some earlier cars you couldn't disable the stop/start via the voltage method, so changing the coolant temp setting was the only way to do it. Quote Link to comment Share on other sites More sharing options...
MC71 Posted May 24, 2017 Report Share Posted May 24, 2017 It appears I have to use the other method mentioned (coolant temp) as I'm unable to deactivate it Start/stop as mentioned via the OP method on my 64 plate......any ideas where to look for the coolant temp method? Quote Link to comment Share on other sites More sharing options...
1534walla Posted May 24, 2017 Report Share Posted May 24, 2017 3 hours ago, MC71 said: It appears I have to use the other method mentioned (coolant temp) as I'm unable to deactivate it Start/stop as mentioned via the OP method on my 64 plate......any ideas where to look for the coolant temp method? Strange voltage method works fine on my 64 plate registered oct 14 Quote Link to comment Share on other sites More sharing options...
MC71 Posted May 24, 2017 Report Share Posted May 24, 2017 5 minutes ago, 1534walla said: Strange voltage method works fine on my 64 plate registered oct 14 I'll keep trying, maybe one of those things that'll take a few goes to work on my car but already tried half a dozen times. Quote Link to comment Share on other sites More sharing options...
Limey Posted July 23, 2017 Report Share Posted July 23, 2017 Anybody else get the stop/start symbol over the gear selection on DSG? Dave Quote Link to comment Share on other sites More sharing options...
dj219957 Posted July 23, 2017 Report Share Posted July 23, 2017 it will says its not available when you are stopped yes. best mod ive done was to turn that crap off. AndyNo1 1 Quote Link to comment Share on other sites More sharing options...
Limey Posted July 23, 2017 Report Share Posted July 23, 2017 52 minutes ago, dj219957 said: it will says its not available when you are stopped yes. best mod ive done was to turn that crap off. OK, cool. Hadnt noticed it when moving and that's why Dave Quote Link to comment Share on other sites More sharing options...
slider09 Posted July 24, 2017 Report Share Posted July 24, 2017 Autowatch Ghost users do not need to disable through OBDEleven / VCDS. Stop start can be reversed through AWG, so it's OFF by default and you press the button to turn it ON. Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
KeithRann Posted August 7, 2017 Report Share Posted August 7, 2017 I disabled mine through the APP, would it have been better to have long coded the change? Also, is it possible (assuming not) to have the start/stop disabled on start up but enable when you press the start/stop button? Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 3, 2018 Author Report Share Posted April 3, 2018 26 minutes ago, kopiter said: Has anyone tried to revert this to Enabled by setting the value back to the default? I've just tried it and get something like "(31) Function not working" in the green bar at the bottom of the app - help!? I’ve reverted it back by putting the voltage setting back to 7.6v when it had to go in to have a new battery fitted. Had no issue putting it back to default. This was only a few weeks ago. Quote Link to comment Share on other sites More sharing options...
Booth11 Posted April 3, 2018 Author Report Share Posted April 3, 2018 1 minute ago, kopiter said: Did you set the value to "7.6" or "7.6 V"? I think just 7.6 iirc. After the new battery was fitted I’ve again switched it back now to 12 as I can’t tolerate Stop Start at all. I don’t remember adding a V. Quote Link to comment Share on other sites More sharing options...
