kelly Posted May 22, 2017 Report Share Posted May 22, 2017 Hi All, I have a 15 plate leased R which was new in March 2015. The first service indicator came up around 11500 miles at which time I had it done. The second service was done around 21000 when it was indicated. After reading on here it looks as though the sneaky supplying dealer had changed the servicing intervals to fixed and that longlife would have suited me better. The car is now just over two years old on 30500 miles and driver information is warning of the third service in 700 miles. I have until the end of Feb 2018 to run on the lease by which time it'll be three years old and on approx. 41000 as I have worked out I'm doing roughly 1130 miles per month. At this next imminent service I am thinking of switching the car to longlife which will hopefully save me a service at the end i.e. I won't need the 4th fixed service at 41000 because longlife should get me to 45000+. It looks like longlife would be an extra £40 over the fixed service price. I also know that I'm likely to need the DSG service at 40000 but I don't think there's much can be done about that other than trying to get in just under 40000 at the end of the lease. Would that save me the servicing costs around 40000 miles or do VW charge if you're within a set mileage of needing servicing? I could possibly get access to another car for a month that might help bring me just under. Another option to is terminate the lease early but at £300/month two months early terminations is going to approximately cover the servicing costs I guess. What prices are people getting for the 3rd fixed service and if I switched it to longlife what's a good price for that service? What would you guys do please? thanks Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted May 22, 2017 Report Share Posted May 22, 2017 I guess that as it's leased, then the care of the engine doesn't matter so I can understand you wanting to be on long life servicing but my own car gets serviced at 10,000 miles regardless of what the car is saying - no matter how good the oil, it's lubricating qualities will deteriorate over time. As for cost, I don't know as my first service was done by a trusted independent who services in accordance with VAG guidelines and uses the correct parts and oil, in my case Castrol Edge.Sent from my HTC One using Tapatalk BillTheButcher 1 Quote Link to comment Share on other sites More sharing options...
simmy Posted May 22, 2017 Report Share Posted May 22, 2017 I wouldn't have a car on long life servicing, it can't be good to have oil in for 20k Sent from my iPhone using Tapatalk BillTheButcher and camelsac2002 2 Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted May 22, 2017 Report Share Posted May 22, 2017 I take the view that oil is generally cheaper than engine repairs. I always change oil at 12 months/10k miles. I don't think longlife service intervals have any place in maintaining a high performance engine. Motorway rep-mobiles fair enough, but not my R BillTheButcher and camelsac2002 2 Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted May 23, 2017 Report Share Posted May 23, 2017 Agree with both simmy and LouCyffer.Sent from my HTC One using Tapatalk Quote Link to comment Share on other sites More sharing options...
xPETEZx Posted May 23, 2017 Report Share Posted May 23, 2017 I would get the car onto long-life servicing. Its leased, and VW arent going to care either way. With long-life I was told the car uses a sensor to measure the viscosity of the oil, if it drops below threshold the car will alert for a change. So I dont really have any reservations about running the car the way it was intended. Its the same with running in periods. Some people still swear by them. Others say they are no longer needed with a modern engine. Quote Link to comment Share on other sites More sharing options...
TuftyR Posted May 29, 2017 Report Share Posted May 29, 2017 One man's lease R is the next man's second hand pride and joy R forum member! Vehicle sympathy that's what I say! Microbe 1 Quote Link to comment Share on other sites More sharing options...
AlanR Posted May 29, 2017 Report Share Posted May 29, 2017 Is it not the same oil whether it's fixed or long life servicing ,I seem to recollect it is ,so 20k for the oil is possible . Not that I would let it go any longer than 10k anyway . Quote Link to comment Share on other sites More sharing options...
camelsac2002 Posted May 29, 2017 Report Share Posted May 29, 2017 Is it not the same oil whether it's fixed or long life servicing ,I seem to recollect it is ,so 20k for the oil is possible . Not that I would let it go any longer than 10k anyway .Asked my local dealership about this - they recommend servicing every 10,000 miles or annually (to make more money??!!) but when I asked what oil they use, they said Castrol 5w40.Sent from my iPad using Tapatalk Quote Link to comment Share on other sites More sharing options...
