Abt12 Posted January 16, 2018 Report Share Posted January 16, 2018 2 hours ago, Mainframe said: Thats assumes downforce force is even all over the item.. I'd have thought Elevated Rear trailing edge would be pressed downmore, levering the front leading edge upwards in the process? .....am reading the ( excellent) Adrian Newey book at moment. Will see what he says 3m tape holds on far more stuff than you'd imagine, and has ridiculous strength if you pick the right one for your substrate. Typical automotive mounting tape has a 40lb/in breakaway peel strength - so on a 5' long spoiler that's over a ton of vertical force to get it going! On a wing I'd assume you're going to get most of your force at the front end from moment loading, but even then, it's not a big spoiler so the moment arm is tiny. As long as you properly prep the surface (no wax, sealants, or coatings, clean and dry, wiped with IPA or panel wipe) that spoiler isn't going anywhere without a solvent or some strong fishing line (and then an adhesive removal wheel!) Rob2k68 and Gavras 1 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 16, 2018 Report Share Posted January 16, 2018 Agree with the good posts above - also won't the tape be in shear rather than peel ? 😂 Quote Link to comment Share on other sites More sharing options...
Abt12 Posted January 16, 2018 Report Share Posted January 16, 2018 8 hours ago, Rob2k68 said: Agree with the good posts above - also won't the tape be in shear rather than peel ? The sheer breakaway is so much higher that the dominant removal force will be front edge lift. That tape is stupid strong. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 16, 2018 Report Share Posted January 16, 2018 I’ve just ordered a spoiler lip to match my PP front discs and silver caliper trims. Mainframe 1 Quote Link to comment Share on other sites More sharing options...
mark118 Posted January 16, 2018 Report Share Posted January 16, 2018 Do you need to declare the spoiler lip to Insurance? I am going to have a go on Sunday at fitting it. Quote Link to comment Share on other sites More sharing options...
Mainframe Posted January 16, 2018 Author Report Share Posted January 16, 2018 9 minutes ago, mark118 said: Do you need to declare the spoiler lip to Insurance? I am going to have a go on Sunday at fitting it. If you wanted to (I wouldn't as its an oem bit), you could send them email along with OEM part number, stating you have fitted it. Quote Link to comment Share on other sites More sharing options...
Mainframe Posted January 16, 2018 Author Report Share Posted January 16, 2018 11 hours ago, Rob2k68 said: Agree with the good posts above - also won't the tape be in shear rather than peel ? I was never suggesting shearing or coming off - was just interested in where tape mount points are, and intimating could these move/rock? No doubt that tape is strong - and flexible. How much flex, give or any fore/aft movement was point. 🤓 Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Mainframe Posted January 16, 2018 Author Report Share Posted January 16, 2018 @mark118 post pics and tape-story when yer done ! Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 16, 2018 Report Share Posted January 16, 2018 2 hours ago, Mainframe said: I was never suggesting shearing or coming off - was just interested in where tape mount points are, and intimating could these move/rock? No doubt that tape is strong - and flexible. How much flex, give or any fore/aft movement was point. Was meant in jest as much as anything ;o) We use a similar tape to hold bumpers to the inner substrate rather than moulding in features that may cause visible sink marks on the surface. Pretty sure VW have tested it to death 👍 Mainframe 1 Quote Link to comment Share on other sites More sharing options...
E-V-A-N-S Posted January 25, 2018 Report Share Posted January 25, 2018 On 16/01/2018 at 15:01, Rob2k68 said: I’ve just ordered a spoiler lip to match my PP front discs and silver caliper trims. Have you recieved this yet Rob? I was going to order the srs-tec one but remembered reading this topic then about the performance pack one. Rob2k68 1 Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted January 25, 2018 Report Share Posted January 25, 2018 18 minutes ago, E-V-A-N-S said: Have you recieved this yet Rob? I was going to order the srs-tec one but remembered reading this topic then about the performance pack one. No mate not yet - still on back order I’m told so no ETA either ;o( Quote Link to comment Share on other sites More sharing options...
E-V-A-N-S Posted January 26, 2018 Report Share Posted January 26, 2018 12 hours ago, Rob2k68 said: No mate not yet - still on back order I’m told so no ETA either ;o( Ah ok, thats a shame. Hopefully it wont take too long. Quote Link to comment Share on other sites More sharing options...
luvadubdub Posted February 6, 2018 Report Share Posted February 6, 2018 On 2017-09-18 at 13:20, Rob2k68 said: DIY PP caliper trim ..... I've got the oem silver trim waiting to go in. How do I remove the current ones? Do I have to remove the callipers? Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted February 6, 2018 Report Share Posted February 6, 2018 I've got the oem silver trim waiting to go in. How do I remove the current ones? Do I have to remove the callipers?No need , they just lever out use a plastic trim removal tool going from the inside edge of the old trim rather than against the caliper.Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
Rob2k68 Posted February 6, 2018 Report Share Posted February 6, 2018 I've got the oem silver trim waiting to go in. How do I remove the current ones? Do I have to remove the callipers?Got a pic ? - I’d quite like to see one.Sent from my iPhone using Tapatalk Pro Quote Link to comment Share on other sites More sharing options...
