Performance Pack Component Part numbers?
3 minutes ago, Danno said:
Think we're being ignored!
Hi,
I haven't got confirmation of it fitting the Estate.. but if you see this article from autocar:
"The pack, available with three and five-door hatch models as well as the estate variant, has been developed to enhance the 306bhp Golf R’s track pace and boost consistency. The exhaust is only available on the hatchback"
https://www.autocar.co.uk/car-news/new-cars/volkswagen-golf-r-gains-new-track-focused-performance-pack
Actually ignore that...
If you go to the VW website and try to build an R estate and add performance pack it lists the below:
R performance pack
R performance pack including 19" 'Spielberg' alloy wheels, performance brakes, derestricted top speed and performance rear spoiler (spoiler on hatch only)
R performance pack
Ah.  Yeah, that'll answer that then!
22 minutes ago, GrantH09 said:
How do I remove the plates off my break calipers , does the caliper have to be removed ?
It’s probaly easier with the caliper off so the mounting brkt is out of the way but I don’t believe it to be necessary. Should just lever off you’ll see the spring clips on the dowels in some pics on here or if not I can take a pic of a spare set I have in the garage. If you can get behind the flat edge of the trim in the middle that is just hanging in space so you could push from behind with a hook tool or a skinny finger or use a plastic trim removal tool at the joint if it needs a little more pursuation .....
No. Wheel off. Trim tool. Wiggle it between calliper and cover and it will come loose. Less than 2 minutes per side once wheel is off.
27 minutes ago, AFLConsult said:
Had mine last week, easy to fit but make sure you find centre then peel tapes outwards.
Wow, that's super subtle. I like it. Take you long to install?
Might have to consider one of these for myself.
1 hour ago, paulwilkie0 said:
That looks exactly what I'm after, we seem to have the same taste 1f600.png. I want the white/black scheme going on too.
Did you wrap these? It's something I have never done and I really like the way that looks.
No, I bought them off ebay pre-painted Gloss Black and were easy to fit
Here's the link where I got them - https://www.ebay.co.uk/itm/152371509011
I know there from China but I took the risk for £20 and hey pressto they are a perfect fit with the tabs and guides as per the OEM ones (in the right places)
