Stop start error
Lemar
Lots of things will prevent start-stop from kicking in, but I don't believe they would give 'stop-start error' message, instead an 'unavailable' message.
Agree with MC71, needs checking.  Had something similar on my 7R, fault traced to faulty pressure sensor.
5 hours ago, dj219957 said:
I got this today at 07.50 also!? Switched off and switched back on and it was fine.
20 minutes ago, Lemar said:
Same as
Mine always cleared itself with Switch on/off as yours will as it's a fault with Start/stop so won't show with Ignition on switch on and systems check.....it may (or may not) show again when you go to Start/stop. To bypass the fault for now jist press the Start/stop button and the fault won't appear.....will more than likely still need a scan and fixing though.
  • 2 years later...
On 01/08/2017 at 21:57, dj219957 said:
so i scanned the car tonight and low and behold a vacuum sensor fault code was triggered occurred while it was at the dealer having a service. Interesting.. Ive cleared the fault and its not come back.
This was a while back I know but did this fault ever return and was there a fix? I've got this start stop error message coming up every time I start the engine, coincidentally straight after it went in for a service. Scanned and error on vacuum sensor showing but cannot clear it
Dan
