Mike R Posted August 16, 2017 Report Share Posted August 16, 2017 When in race mode the noise from this is a bit to much for me,can i disconnect the soundakator (or whatever its called) thats under the windscreen trim with no problems & warning lights coming on? Quote Link to comment Share on other sites More sharing options...
Chiefbadger Posted August 16, 2017 Report Share Posted August 16, 2017 Just go to individual and set everything to race but the sound to eco. Voilà! Sent from my iPhone using Tapatalk Mike R 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted August 16, 2017 Report Share Posted August 16, 2017 5 minutes ago, Mike R said: When in race mode the noise from this is a bit to much for me,can i disconnect the soundakator (or whatever its called) thats under the windscreen trim with no problems & warning lights coming on? What year is your car? If it's pre end May 2015 then yes you can disconnect it, or disable it with VCDS or Obdeleven. If it's post end May 2015 (MY16) built car then it will have an option under Individual driver profile mode to turn it down - it's called Interior Engine Sound in the menu - which can be out to Sport (loudest), Normal (mid) and Eco (quietest). This means you can replicate Race using Individual putting everything into Sport except the soundaktor which can be in Eco. Quote Link to comment Share on other sites More sharing options...
PHILC Posted August 16, 2017 Report Share Posted August 16, 2017 I quite like it, it saves me a sore throat trying to make the noise. Cogito, LouCyffer, WILCO-MAN and 11 others 6 8 Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 16, 2017 Author Report Share Posted August 16, 2017 6 minutes ago, Booth11 said: What year is your car? If it's pre end May 2015 then yes you can disconnect it, or disable it with VCDS or Obdeleven. If it's post end May 2015 (MY16) built car then it will have an option under Individual driver profile mode to turn it down - it's called Interior Engine Sound in the menu - which can be out to Sport (loudest), Normal (mid) and Eco (quietest). This means you can replicate Race using Individual putting everything into Sport except the soundaktor which can be in Eco. Its a April 2015....thanks for the info,im going out to disconnect it now & try it. Quote Link to comment Share on other sites More sharing options...
Bob Posted August 16, 2017 Report Share Posted August 16, 2017 8 minutes ago, PHILC said: I quite like it, it saves me a sore throat trying to make the noise. it also drowns out the noise of the fighting kids in the back - and the wife in the front! I kinda like it and missed it when I went 'eco' in individual for the soundaktor setting... PHILC 1 Quote Link to comment Share on other sites More sharing options...
DUB R4XX Posted August 16, 2017 Report Share Posted August 16, 2017 Its a April 2015....thanks for the info,im going out to disconnect it now & try it. What area are you based Mike? Just within a 50 mile area will do, don't post your house number lol Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 16, 2017 Author Report Share Posted August 16, 2017 Well i went out & disconnected it then went for a drive.....not impressed....ive reconnected it....hahaha....it may be a gimmick but the car sounded just like a normal golf without it working 😀 ....i may just look at getting it turned down a bit at some point. Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 16, 2017 Author Report Share Posted August 16, 2017 35 minutes ago, DUB R4XX said: What area are you based Mike? Just within a 50 mile area will do, don't post your house number lol Im in the York area. Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 16, 2017 Author Report Share Posted August 16, 2017 54 minutes ago, Chiefbadger said: Just go to individual and set everything to race but the sound to eco. Voilà! Sent from my iPhone using Tapatalk I will check tomorrow when im in the car but im not sure i can change the interior sound on mine,i dont remember seeing that option in the menu. Quote Link to comment Share on other sites More sharing options...
DUB R4XX Posted August 16, 2017 Report Share Posted August 16, 2017 Im in the York area. Damn I'm up near Glasgow or I would have set it for you. I've found 61.2% is the sweet spot for me. It's there but not fighting with your normal sound off the car and just enhances it slightly Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 16, 2017 Author Report Share Posted August 16, 2017 1 minute ago, DUB R4XX said: Damn I'm up near Glasgow or I would have set it for you. I've found 61.2% is the sweet spot for me. It's there but not fighting with your normal sound off the car and just enhances it slightly Thanks anyway for the offer....i will make a note of the 61.2%..... 👍 DUB R4XX 1 Quote Link to comment Share on other sites More sharing options...
PHILC Posted August 16, 2017 Report Share Posted August 16, 2017 Buy yourself an OBD Eleven you will have masses of fun and be able to set most things to your personal preference There not that expensive but make sure you get the PRO version. Quote Link to comment Share on other sites More sharing options...
Mike R Posted August 16, 2017 Author Report Share Posted August 16, 2017 5 minutes ago, PHILC said: Buy yourself an OBD Eleven you will have masses of fun and be able to set most things to your personal preference There not that expensive but make sure you get the PRO version. Thanks i will have a look,i have a foxwell diagnostic machine thats great for diagnostics but doesnt do settings like this. Quote Link to comment Share on other sites More sharing options...
LouCyffer Posted August 16, 2017 Report Share Posted August 16, 2017 1 hour ago, Mike R said: Im in the York area. If you want it toning down via VCDS, pop me a pm, Mike. I'm within 35miles (ish) of you. I set mine to 20% (default is 100%), and I can honestly say I don't miss the noise at all. You may need 25 posts before you can pm, though.... DUB R4XX 1 Quote Link to comment Share on other sites More sharing options...
