Mk7 R - [DYI] $10 SEQUENTIAL TAILLIGHTS
WHY.A.H.WHY.A
This is a DIY originally posted by Zed4me on YouTube,  although he had an OEM LED tail light retrofit
IMPORTANT NOTE:
It's really important to undo any VCDS coding done to the LED taillight prior to tackling this DIY.
For us with OEM Taillights here is how it goes
Tools required:
2x 12v NE555 Modules *
Flat head screw driver
Wire cutter
Wire splicer
Soldering iron **
Soldering wire **
Soldering flux **
2 mm red wire
2 mm black wire
2mm green wire
Wire heat shrink
Notes
* I got the NE555 modules from AliExpress I highly recommend these and they are quality ones and got them as a part of group buy
Click Here
** this is optional but highly recommended, the other easily isn't just to twist the wires together but the risk of bulb out is possible.
How to :
Prepare the modules as follows
1- Piece of red wire in "NO" terminal
2-  Piece of green wire bridged between "COM" & "+" terminal
3- Piece of red wire in "Positive terminal"
4- Piece of black wire in "-" terminal
Preparing the Taillight Harness
1-Splice the "brown" wire
2- Cut the "purple/white" wire
** give yourself some space when cutting the wire just in case you want to revert back to stock in the future
Then follow the below diagram when soldering the module to the wiring harness.
Connect the  tail light harness back and , turn on your Hazard lights and start adjusting the timer on the module counter clock wise untill you hear click, a conformation that the module has detected the signal, then continue adjusting to your liking
End result :
Nice one.... modules ordered. Will give this a go, for anyone interested in doing this but not damaging the car wiring, I'm going to try and make a harness up using OEM plugs so it can be plugged in and out should you have problems or want to revert back to stock. I got a list of the plugs required from another vw forum. See attached.9e969bce4ac6ec01e729663119c6c1f8.jpg
Well done mate, thanks!
I just ordered a pair of modules.
Just a question (excuse my lack of knowledge on electronics) - is the intersection where the purple/green > + and terminal 3 > NO spliced in together or separate?
You cut the purple/green wire on the harness in half then connect the lead coming from "NO" to the harness side and connect the leas from the "+" to the other half of the purple/green wire
The only splice is the brown wire were you have to splice it and Solder the lead coming from "-"
I hope I understood your question..
Sent from my A0001 using Tapatalk
That clears it up - thanks!!
Look forward to doing this mod 🙂
Good guide, well done.          Although I can't seem to access the videos.
I must admit I took the easy method and installed ready made adapters some time ago.
Thanks,
Yeah for me the idea of paying $100 for an adapters that costs $20 along with the module was not cutting it, some resellers are taking advantage of us with, these adapters should not cost more that $40 if you want to factor in your profit
I'd be interested, please let me know if you start selling a kit.  Cheers.
Hi "TurboTrev" I won't be selling these in all honesty, by the time I've sourced the plugs, wiring and boards, set them up and accounted for my time, it's probably work out as expensive as some of these looms already available (people stating there a rip off, it's actually the fact your paying for a sparky/tech to assemble the looms and set them up) there's probably no more than £20 worth of parts, it's the time that takes the cost up, plus greed on profit margins.
Also, I wouldn't be able to warrenty anything should the loom cause a fault, I'm simply doing it as another owner/enthusiast that likes DIY projects and doesn't like being ripped off!! If I manage to do it and it works, if it's a simple enough job I wouldn't mind knocking a few kits up for people if they were struggling themselves.
Fair enough Matt, I understand.  Unfortunately, it's well beyond my limited capabilities lol.
To be honest, if I had more time I'd happily knock as many as needed up for anyone on here and probably eBay a few sets here and there too to go towards my own little mods but working shifts, doing a house up, having hobbies and other responsibilities I just don't have the time.
If mine ever comes to fruit and I get round to doing it, and it works well, I'll happily make you one TurboTrev, once I've found a supplier of the plugs, got some cabling and a couple of decent boards, set them up and tested them on the car and I'm happy it works, I can message you and post them out to you, but it could be next year now, so if your in a rush for them, I'm afraid you'll have to bite the bullit and buy a pre-made loom kit.
Here you go,
10Sets female 7N0972704 and 10Sets 3AA972714 male plug Car Taillight Chair connector for ar Tail lamp Volkswagen MAGOTAN golf
http://s.aliexpress.com/Bjuiu2ey
(from AliExpress Android)
