Cornering light upgrade
riz92ali
Getting a error cornering code pop up on the display after a few minutes after start up.
Few people in the group reckon it's the bulb that needs replacing. Seems to be a good chance to get some decent ones fitted.
Any recommendations on which one everyone has used and worked well?
Cheers
Cheers
Have you tried the search function ?   Just enter "cornering lights"
Cheers
The best thread for recommendations on replacement cornering bulbs is the one I linked you too previously in your other thread as it has a ton of recommendations and links in, plus photos and fitting advice.  I know it's a long thread but worth a read.
I swapped to Philips Diamond Vision H7 cornering bulbs. They are 5000k so strictly speaking not road legal but these are not primary lights, so myself and many others are happy to take the risk.  They are considerably better than the yellow oem bulbs and a much better match for the xenons.
https://www.amazon.co.uk/gp/product/B0088ORMHE/ref=oh_aui_detailpage_o09_s00?ie=UTF8&psc=1
A few pics.
Oem bulb
Before
After
Some evening/night pics.
Here's a few pics of the Philips Diamond Vision against a wall. As you can see (well I can, lol) it gives off a slightly bluer light compared to the main xenon lamp, but good light output.
  • 2 months later...
unfortunately i have the diamond vision and shortly after started getting the corner light error afs message,
went into vw ,who said i fitted wrong... considering have been changing far more difficult bulbs in last 25yrs know these were simple and easy to do and in no way fitted wrong. anyway they reset everything refitted and no issues until now same problem.. could be temperature related as was cold 1st time..
these are great upgrades and i have a doubt over the housing or connections maybe control module. will be swapping bulbs over next few days to check..
just for clarity this is my 2nd car and only seen 3600 miles of which about 1000miles have been with the diamond visions.
will be able to see/know more tomorrow in daylight. just to be clear i have no reason to doubt its the bulb at fault and thought the upgrade was excellent.
m.j
