FL Lights
Percycars
Mk7 xenons were a step down from the mk6 xenons, mainly due to the lens shape dispersing the light over a wider area for some bizarre reason. Let's make the lights look sexier but bollocks to the ability to actually see at night. Aesthetics over function.  Just another example of if it ain't broke let's fiddle with it until it is. I improved mine back to acceptable by changing bulbs. I can't comment on mk7.5 as I'm still on mk7.
6 hours ago, BobbyT said:
The Bi-xenons on my current CC are superb, I would have thought the Golf would of been the same?
I'm looking forward to seeing how the LED type are on the Golf.
For me, and I’ve had two MK7 Golfs with bi-xenon headlights, the power was never the issue, it was that they were set quite low and as such, they don’t illuminate that far down the road.
I did a detailed post of the dynamic LEDs a bit back.
They are pretty good but with issues. After a bit more night driving I would update my review to say these are certainly not as good as the Mercedes variant. They are not as quick as I would like in reacting to traffic. Generally ok with reacting to oncoming traffic but the other night on a windy back road I had to turn the dynamic function off as following a car it would keep the main beams on too much and not track the car in front when it reappeared into view after a corner.
The worst thing (and I would love if someone can tell me a fix) is to turn off dynamic main beam, you have to go to normal main beam (push away on left stalk) and then go to dipped beam (pull on left stalk). This is poor design as it means the car in front gets flashed before it can be turned back to dipped beam. Pretty stupid.
Still, on a less windy road, they are good.
Put your headlights into manual not auto and that disables DLA.
I'm very impressed with DLA and love the way the full beams go past the car in front, not had any noticeable delay in covering other cars.
Sent from my SM-G950F using Tapatalk
Fair one, I used VCDS to raise the CC's a little
On ‎21‎/‎12‎/‎2017 at 02:12, gregozedobe said:
I have the active matrix LED headlights on my 7.5R.
Dynamic Light Assist and Matrix LED headlights are 2 different systems. I have DLA on my car.
My owners manual says the dynamic lights work at 37mph. I believe the Matrix system works at 20mph. I don't know why there is a difference.
I think this is Dynamic Light Assist - https://www.youtube.com/watch?v=EOSLMs5Pma8
This is Matrix LED - https://www.youtube.com/watch?v=xYSix5r38qY
Interesting.
My wife has a 3 year old Audi A3 with Xenons, which I thought would be the same as the Mk7. I always thought they were slightly better than my Mk6 Xenons. Though that may have been due to the static cornering lights.
Now I have a Mk7.5 with LED and dynamic light assist. By comparison with the A3, new LED lights are definitely a lot whiter. Though I believe this may be causing a perception that the lights don't reach as far. I think this is because everything close to the car is so bright. By comparison to near objects, the distance looks darker.
I was wondering that too. Thanks.
I am still wondering what Dynamic Lights look like to other drivers. Then it occurred to me that the lights probably help the other drivers too. My car will be lighting up the roadside for everyone.😎
I raised my led headlights by 2 turns last night , made a huge difference , can drive at speed now without wondering what's up ahead.
one thing I have noticed about the new headlights is when you move off , the beam pattern changes , the car spreads the light sideways , when I cam to a stop in traffic , I noticed my headlights on the rear of the car in front of me , that looked like a side moving shutter on the head lights moving inwards towards the car , so next lot of traffic I stopped again and it did it again , I have bog standard led lights.
anyone comment what it is?
