golf23 Posted December 22, 2017 Report Share Posted December 22, 2017 Having problems with the head lights not working any ideas Thursday,21,December,2017,18:43:30:26046 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64 VCDS Version: 17.10.0.2 (x64) HEX-NET CB: 0.4407.4 Data version: 20171026 DS283.3www.Ross-Tech.com VIN:License Plate: Mileage: 47268km-29370mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: AU-VW37 (5Q0) Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 52 55 5F A9 VIN: WVWZZZAUZFW091873 Mileage: 47268km-29370miles 01-Engine -- Status: OK 0000 02-Auto Trans -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: OK 0000 10-Park/Steer Assist -- Status: OK 0000 13-Auto Dist. Reg -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 22-AWD -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Headlight Range -- Status: Malfunction 0010 5F-Information Electr. -- Status: OK 0000 A9-Struct. Borne Sound -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine (J623-CJXC) Labels:. 06K-907-425-V1.clb Part No SW: 5G0 906 259 E HW: 06K 907 425 B Component: 2.0l R4 TFSI H13 0003 Revision: --H13--- Coding: 091D00322466050B2004 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_ECM20TFS0205G0906259E 001003 ROD: EV_ECM20TFS0205G0906259E_VW37.rod VCID: B02C4C68EB466DAA8C9-80E4 No fault code found. Readiness: 0010 0001 ------------------------------------------------------------------------------- Address 02: Auto Trans (J743) Labels: 0D9-927-770.clb Part No SW: 0D9 300 012 L HW: 02E 927 770 AQ Component: DQ250-6A MQB H53 4516 Revision: 03253104 Serial number: TFK01407290672 Coding: 0014 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_TCMDQ250021 001001 ROD: EV_TCMDQ250021_VW27.rod VCID: 9F0EBFD486D8E2D2253-80CA 12 Faults Found: 21153 - Gear 1 P072C 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 21154 - Gear 2 P072D 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 21155 - Gear 3 P072E 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 21156 - Gear 4 P072F 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 21157 - Gear 5 P073A 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 21158 - Gear 6 P073B 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 21159 - Gear R P072B 00 [002] - Not Selectable Intermittent - Not Confirmed - Tested Since Memory Clear 10731 - Valve 3 in Transmission Part 1 P174A 00 [002] - Electrical malfunction Intermittent - Not Confirmed - Tested Since Memory Clear 10732 - Valve 3 in Transmission Part 2 P174E 00 [002] - Electrical malfunction Intermittent - Not Confirmed - Tested Since Memory Clear 10657 - RPM Signal from ECU P0726 00 [002] - Implausible Signal Intermittent - Not Confirmed - Tested Since Memory Clear 10740 - Valve 3 in Transmission Part 2 P174E 00 [002] - Electrical malfunction Intermittent - Not Confirmed - Tested Since Memory Clear 10906 - Cooling Oil Valve P179D 00 [002] - Electrical Malfunction Intermittent - Not Confirmed - Tested Since Memory Clear ------------------------------------------------------------------------------- Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb Part No SW: 5Q0 907 379 M HW: 5Q0 907 379 H Component: ESC H31 0571 Revision: 00000000 Serial number: 62104000000870 Coding: 01FA93A15429296D037F070741C66980C92A94C0E08296F7F8 425078C208 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_Brake1UDSContiMK100IPB 033001 ROD: EV_Brake1UDSContiMK100IPB_033_VW37.rod VCID: C6C00AB079C2D31A465-8092 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC (J255) Labels:| 5G0-907-044.clb Part No SW: 5G0 907 044 AF HW: 5G0 907 044 AF Component: Climatronic H03 0907 Revision: 00001K08 Coding: 00120004200100011005000000101000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_ACClimaBHBVW37X 003018 ROD: EV_ACClimaBHBVW37X_003_VW37.rod VCID: EB969B0402E0CE72F9B-80BE Fresh Air Blower Front: Refrigerant Pressure And Temperature Sender: Air quality sensor: No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. (J519) Labels:| 5Q0-937-08X-HV1.clb Part No SW: 5Q0 937 084 AJ HW: 5Q0 937 084 AJ Component: BCM MQBAB H H18 0134 Serial number: 01011422200407 Coding: 03001A42C24122F30BA44080B10C0728100000000000000000 0000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_BCMCONTI 013000 ROD: EV_BCMBOSCH_013.rod VCID: 804CDCA81B663D2A3C9-80D4 Control Unit For Wiper Motor: Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB Component: WWS 140724 042 0551 Serial number: 140728095114 Coding: 0E4DDD Rain Light Recognition Sensor: Subsystem 2 - Part No SW: 5Q0 955 547 A HW: 5Q0 955 547 A Labels: 5Q0-955-547.CLB Component: RLHS 037 0059 Serial number: S4Y14M08D15H16M56S01 Coding: 00A8DD Sensor For Anti Theft Alarm System: Subsystem 3 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172 Component: Sensor, DWA 005 0315 Serial number: 000000000ZY142021PE1 Alarm horn: Subsystem 4 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605 Component: Sirene, DWA 004 0311 Serial number: 00000000000030496900 No fault code found. ------------------------------------------------------------------------------- Address 10: Park/Steer Assist (J791) Labels:| 5Q0-919-294.clb Part No SW: 5Q0 919 294 E HW: 5Q0 919 294 A Component: PARKHILFE 8K H03 0048 Revision: -------- Serial number: 39311421303342 Coding: 0071051011 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_EPHVA18AU3700000 002024 ROD: EV_EPHVA18AU3700000_002_VW27.rod VCID: BD32655C2C1490C217F-80E8 No fault code found. ------------------------------------------------------------------------------- Address 13: Auto Dist. Reg (J428) Labels:| 5Q0-907-572-V1.clb Part No SW: 5Q0 907 572 D HW: 5Q0 907 572 D Component: ACC Bosch MQB H05 0304 Serial number: 14081476511372 Coding: 001C1300FE0739 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_ACCMRRBoschVW372 001015 ROD: EV_ACCMRRBoschVW372_VW26.rod VCID: B83C74480336B5EAC49-80EC 1 Fault Found: 1541 - Sensor for Automatic Distance Regulation; Incorrectly Positioned C1103 00 [008] - - Intermittent - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 2 Reset counter: 37 Mileage: 47254 km Date: 2017.12.21 Time: 16:23:51 Control Module temperature: 30 °C Voltage terminal 15: 14.5 V Vehicle speed: 7.47 m/s Acceleration: -0.12 m/s² ------------------------------------------------------------------------------- Address 15: Airbags (J234) Labels:| 5Q0-959-655.clb Part No SW: 5Q0 959 655 AA HW: 5Q0 959 655 AA Component: AirbagVW20 014 0386 Serial number: 003MLR07YDGE Coding: 98CCC000000000005C0000CF00C800000065 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_AirbaVW20SMEVW37X 002130 ROD: EV_AirbaVW20SMEVW37X_VW37.rod VCID: FF4E5F54669842D2453-80AA Belt Pretensioner left: Subsystem 1 - Part No SW: 5G0 980 945 B HW: 5G0 980 945 B Component: BeltPretRevFL H35 0341 Serial number: 34169677B18081440676 Coding: 333135 Belt Pretensioner right: Subsystem 2 - Part No SW: 5G0 980 946 B HW: 5G0 980 946 B Component: BeltPretRevFR H35 0341 Serial number: 34169676B14081471123 Coding: 333135 Side Sensor Driver Front: Subsystem 3 - Part No SW: ----------- HW: 480 001 408 14 Component: SideSensor_Df 001 0887 Serial number: 35767000000B6A95B01 Coding: 2D2D2D Side Sensor Passenger Front: Subsystem 4 - Part No SW: ----------- HW: 480 001 408 14 Component: SideSensor_Pf 001 0887 Serial number: 358670000001CC48B01Z Coding: 2D2D2D Side Sensor Driver Rear: Subsystem 5 - Part No SW: ----------- HW: 480 401 108 14 Component: SideSensor_Dr 001 6149 Serial number: 3516502A516DB8150152 Coding: 2D2D2D Side Sensor Passenger Rear: Subsystem 6 - Part No SW: ----------- HW: 480 401 108 14 Component: SideSensor_Pr 001 6149 Serial number: 3526502A916DB8022357 Coding: 2D2D2D Front Sensor Driver: Subsystem 7 - Part No SW: ----------- HW: 480 401 408 14 Component: FrontSensor_D 001 6149 Serial number: 3556502AF16DB814C10M Coding: 2D2D2D No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel (J527) Labels:| 5Q0-953-549.clb Part No SW: 5Q0 953 507 DD HW: 5Q0 953 549 C Component: Lenks. Modul 002 0110 Revision: -------- Serial number: 12081404220841 Coding: 0C10 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_SMLSKLOMQB 017001 ROD: EV_SMLSKLOMQB_VW37.rod VCID: FBB6AB4472805EF269B-80AE No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments (J285) Labels:| 5G0-920-XXX-17.clb-SRI3 Part No SW: 5G1 920 958 HW: 5G1 920 958 Component: KOMBI 304 4270 Coding: 27AD08082F80260001882A011400000000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_DashBoardVDDMQBAB 009037 ROD: EV_DashBoardVDDMQBAB_009_VW37.rod VCID: EE90921031F23B5ADE5-80BA No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway (J533) Labels:| 5Q0-907-530-V1.clb Part No SW: 5Q0 907 530 T HW: 5Q0 907 530 F Component: GW MQB High 128 1188 Revision: -------- Serial number: 0002389841 Coding: 030100042B085900EF00027E1C0F0001000105000000000000 0000000000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_GatewLear 011016 ROD: EV_GatewLear_011.rod VCID: C2C816A055EAEF3A6AD-8096 Alternator: Multi Function Steering Wheel Control Module: Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N Labels: 3C8-959-537.CLB Component: E221__MFL-DC1 H10 0038 Serial number: 29140001661890084315 Coding: 2DFFFF Battery Monitoring Control Module: Subsystem 3 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E Component: J367-BDMHella H03 8043 Serial number: 8069684103 No fault code found. ------------------------------------------------------------------------------- Address 22: AWD (J492) Labels:* 0CQ-907-554.clb Part No SW: 0CQ 907 554 D HW: 0CQ 525 130 Component: Haldex4Motion H52 7081 Serial number: HA1-00027.06.14 Coding: 0001 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_AllWheelContrHA1VW37X 002011 ROD: EV_AllWheelContrHA1VW37X.rod VCID: C6C00AB079C2D31A465-8092 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver (J386) Labels:| 5QX-959-X93-42.clb Part No SW: 5Q0 959 593 B HW: 5Q0 959 593 B Component: TSG FS 020 0025 Serial number: 30071402091043 Coding: 003F0220D001048000001000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_DCUDriveSideEWMAXKLO 006003 ROD: EV_DCUDriveSideEWMAXCONT.rod VCID: C0CC1CA85BE6FD2A7C9-8094 Drivers Door Rear Control Module: Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_DRV 005 0005 Serial number: 00000000000003469937 Coding: 1D0000 No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist (J500) Labels:| 5Q0-909-144.clb Part No SW: 3Q0 909 144 F HW: 3Q0 909 144 F Component: EPS_MQB_ZFLS 503 5043 Coding: 8103 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_SteerAssisMQB 010031 ROD: EV_SteerAssisMQB_010.rod VCID: B5227D7C14244882DFF-80E0 No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. (J387) Labels:| 5QX-959-X92-52.clb Part No SW: 5Q0 959 592 B HW: 5Q0 959 592 B Component: TSG BFS 020 0025 Serial number: 29071402090272 Coding: 003F0020DE01048000801000 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_DCUPasseSideEWMAXKLO 006003 ROD: EV_DCUPasseSideEWMAXCONT.rod VCID: BFCE1F54261882D2053-80EA Passengers Rear Door Control Module: Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A Labels: 5QX-959-81X-V1.CLB Component: FOND_FHSG_PSG 005 0005 Serial number: 00000000000003511766 Coding: 050000 No fault code found. ------------------------------------------------------------------------------- Address 55: Headlight Range (J745) Labels:| 7P6-907-357.clb Part No SW: 7P6 907 357 D HW: 7P6 907 357 A Component: AFS-ECU H07 0090 Revision: -------- Serial number: -------------- Coding: 02AE01000B000200 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_HeadlRegulVWAFSMQB 001120 ROD: EV_HeadlRegulVWAFSMQB.rod VCID: C0CC1CA85BE6FD2A7C9-8094 Right Headlamp Power Output Stage: Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB Component: LeiMo rechts H01 0002 Coding: 2E0000 2 Faults Found: 5276144 - Power Output Module for Left Headlamp U4E3B50 F0 [137] - Not Coded MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 2 Fault Frequency: 1 Reset counter: 248 5275953 - Power Output Module for Left Headlamp C1081 31 [137] - No Signal MIL ON - Confirmed - Tested Since Memory Clear Freeze Frame: Fault Status: 00000001 Fault Priority: 6 Fault Frequency: 13 Reset counter: 252 Mileage: 47249 km Date: 2017.12.20 Time: 15:06:05 ------------------------------------------------------------------------------- Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-STD1.clb Part No SW: 5G0 035 820 A HW: 5G0 035 820 A Component: MU-S-D-ER 041 0421 Serial number: V5C01908141084 Coding: 02730000FF00000021111201000800001F0207060100010001 Shop #: WSC 01357 011 00200 ASAM Dataset: EV_MUStd4CPASE 002039 ROD: EV_MUStd4CPASE_VW37.rod VCID: 9F0EBFD486D8E2D2253-80CA Operating And Display Unit 1: Subsystem 1 - Part No SW: 5G0 919 605 HW: 5G0 919 605 Component: ABT_Std_Radio H60 0030 Serial number: VWZ8Z9PS203BK4 No fault code found. ------------------------------------------------------------------------------- Address A9: Struct. Borne Sound (J869) Labels: 4H0-907-159.clb Part No SW: 5G0 907 159 B HW: 4H0 907 159 A Component: SAS-GEN 2 H07 0006 Serial number: 140617202269 ASAM Dataset: EV_SoundActuaGen2AU64X 003010 ROD: EV_SoundActuaGen2AU64X.rod VCID: AD12551CFC740042A7F-80F8 Quote Link to comment Share on other sites More sharing options...
phazer Posted December 22, 2017 Report Share Posted December 22, 2017 Sorry I can't help with the problem, but you might want to remove your VIN from the VCDS log. Quote Link to comment Share on other sites More sharing options...
dazie00 Posted December 22, 2017 Report Share Posted December 22, 2017 Dv52 is the expert vcds guy on here , send him a nice message and he may be able to help you out . Stobsie 1 Quote Link to comment Share on other sites More sharing options...
golf23 Posted December 22, 2017 Author Report Share Posted December 22, 2017 thank you guys Quote Link to comment Share on other sites More sharing options...
Stobsie Posted December 22, 2017 Report Share Posted December 22, 2017 You need a post count of 25 before you can PM a member best bet is put this in the VCDS section or I'm sure a mod @Booth11 will move it for you and I'm sure he'll spot it. Booth11 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted December 22, 2017 Report Share Posted December 22, 2017 Moved. 👍 Stobsie 1 Quote Link to comment Share on other sites More sharing options...
dazie00 Posted December 23, 2017 Report Share Posted December 23, 2017 @dv52 any joy with this ?? Quote Link to comment Share on other sites More sharing options...
stonefish Posted December 30, 2017 Report Share Posted December 30, 2017 I don't know about VCDS, but I'm pretty sure Vag Can Pro can code sub modules. Quote Link to comment Share on other sites More sharing options...
8YARWY Posted December 30, 2017 Report Share Posted December 30, 2017 55 has been superseded by module 4B on the FL R. I know this because VCDS couldn’t find a 55 Headlight module only a new 4B one. VCP opened it fine. Quote Link to comment Share on other sites More sharing options...
