Grip
phil4
20 minutes ago, fatherted said:
I still get wheelspin when pulling out if a junction and giving it a few beans.
It's not as bad as a FWD car but still not as great as people seem to make out. Maybe I'm expecting too much.
All 4 wheels really spinning or just the front ?
If your haldex is clogged by the infamous "frog spawn" then you won't get proper drive from the rear wheels, and most cars doesn't seem to give any errors either :(
As said previously, mine just grips and goes.  I have noticed a small spin at the rear wheels, but very infrequently and only for a foot or two when I am being very enthusiastic with the throttle with a sharp turn from a standstill on a wet road.
Just the fronts. It's only a month old so hopefully Haldex isn't clogged yet but will keep an eye on it.
Mine does what you've described too. First time it did it I was aiming for a tight gap with cars closing from both directions.
Turning right pulling out of a 90 degree side junction with damp roads, thought it'd be fine with Haldex. Went for the gap and the inside right wheel probably spun for about 2 or 3 revolutions, just enough time to think this is going to hurt, and the car had moved just far enough to get t-boned. Then felt the power move to the back wheels and got shoved out of the junction, definitely not very graceful as I had just lifted slightly to try and find some traction(fwd style) so the car just lurched forward and then declerated almost immediately. Never saw any lights flashing on the dash as my attention was being taken by the car I thought was going to t-bone me.
Not sure if all 4 wheels need to lose traction to get TCS flashing or not??
So probably not a clogged Haldex, but IIRC there are other Haldex faults that can stop power going to the rear wheels.  Sounds like a warranty fix is needed to me.
33 minutes ago, Ferret said:
I don't get any spin at all on my 7.5.
The Haldex system is predominantly a front wheel driven setup which only sends torque rearwards when it detects the front wheels slipping. Have you ever accelerated hard out of a slippery junction with steering lock added?? Mine only seems to do it when the roads are damp and cold but definitely loses traction on the inner wheel for 1/4 second or so, then get a definite shove from the rear. I often have my window open too so hear the wheel spin up.
Shame it seems to be dry for the next few days, but I'll try it when I next get a chance. There's a specific junction I use where I'm limited on view and occasionally get a speeding vehicle appear over the crest of a hill when I'm committed to pull out and suddenly apply throttle which results in the wheel spinning.
Hope my system isn't faulty, don't like going to the dealership for general maintenance let alone having them take my car for a test drive for them to thrash the car 😢
A bit of wheelspin is normal when you have a bit of steering lock on
Hope my system isn't faulty, don't like going to the dealership for general maintenance let alone having them take my car for a test drive for them to thrash the car 1f622.png
Haldex GEN5 is proactive as well as reactive. Anything over 30% throttle (IIRC) the system is sending some power rearwards.
I heard it's a massively improved system over previous generations, didn't know about the 30% throttle/power rearwards scenario. Just can't comprehend how Ferrett says he doesn't get any spinning.
So I don't think I've ever put foot to the floor and applied a lot of lock to pull out of a junction, I've definitely pulled out fast though.
I don't have windows open so maybe missing it, but no kick.  Also my previous car was front wheel drive so used to feeling it.  Pretty sure all the wheels are being driven whenever I've needed it.
I know categorically that it doesn't slip when I launch, have you tried that?
Mine is DSG too, would be manual if there was the option on the estate. Sadly not though, although the Leon Cupra ST has a manual option I think?
I've tried launching with traction control completely off when it's been cold, wet, and the roads gritted just to see what it did. The front wheels hopped 2 or 3 times but it was being driven by the rear wheels at the same time. May try it again in a couple of weeks when I have worn in some Pilot Sport 4 tyres which are being fitted Wednesday, the standard Bridgestone's seem to be at there weakest in cold and damp conditions. Don't like launching too often, just seems brutal.
I think the wheel spinning out of the junction occurs because I suddenly stab at the throttle when I see a car appear and have steering lock applied, it isn't full throttle probably 3/4 with coldish tyres. Probably shocks the computers which need a brief second to figure out what's happened.
Yeah I have the estate on bridgestones too, I don't rate them much either.  Noisy and horrid in the snow.
If I get chance I'll experiment some on try to get the front to slip, window open of I can bear the cold.  Definitely done 3/4 and lots of lock, but maybe I'm a touch gentler as used to front wheel drive...
Only time I can get the car to do anything other than grip is greasy roundabouts (initially understear, from coming in to hard) and flooring it with lock up hills, but both always feel like all 4 wheels letting go.
