marshy Posted February 13, 2021 Report Share Posted February 13, 2021 Came across something on how to get your start button to pulsate line the mk8 car.Coded mine today and it works Sent from my iPhone using Tapatalk EcosseGolfR 1 Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted February 13, 2021 Report Share Posted February 13, 2021 20 minutes ago, marshy said: Came across something on how to get your start button to pulsate line the mk8 car. Coded mine today and it works Sent from my iPhone using Tapatalk I’ll be trying this tomorrow for sure. marshy 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted February 13, 2021 Report Share Posted February 13, 2021 Did mine back in early 20. Is a Seat coding thing that works on most Vag cars. https://youtube.com/shorts/Ri31L3VcyGUSent from my iPhone using Tapatalk marshy and EcosseGolfR 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 13, 2021 Report Share Posted February 13, 2021 I was curious to see if this would work on a mk7. Tried it and doesn’t work on mine (which is what I expected might be the case). I guess I’ll just have to live without the pulsing until mk8 turns up. 😭 😂 😂 Quote Link to comment Share on other sites More sharing options...
marshy Posted February 13, 2021 Author Report Share Posted February 13, 2021 I was curious to see if this would work on a mk7. Tried it and doesn’t work on mine (which is what I expected might be the case). I guess I’ll just have to live without the pulsing until mk8 turns up. Should work as it works on the wife’s 65 plate GTD!Sent from my iPhone using Tapatalk Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 13, 2021 Report Share Posted February 13, 2021 31 minutes ago, marshy said: Should work as it works on the wife’s 65 plate GTD! Sent from my iPhone using Tapatalk Hmm that’s a bit weird then. I tried it twice as per the coding you posted but and it accepted the changes just didn’t physically change anything, still had the start button lit up solid. Will give it another go tomorrow. I’m not bothered as new car coming in a month (I hope) but was just interested to see if it worked as I think the new owner might like it activated. marshy 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted February 13, 2021 Report Share Posted February 13, 2021 Hmm that’s a bit weird then. I tried it twice as per the coding you posted but and it accepted the changes just didn’t physically change anything, still had the start button lit up solid. Will give it another go tomorrow. I’m not bothered as new car coming in a month (I hope) but was just interested to see if it worked as I think the new owner might like it activated. It works on our GTD too....Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted February 13, 2021 Report Share Posted February 13, 2021 Checked my coding for VCDS and it’s same as Kev’s Go to the KESSY module Acc/Start Auth. @ address hex05Select Security AccessEnter the magic number 20103Select AdaptationChange the channels below to activeENG123036-ENG154826-DeveloperCoding: Search lights-ZAT_illumination_concept_mybeat_clamp58xtENG123036-ENG154827-DeveloperCoding: Search lights-ZAT_illumination_modus_mybeat_clamp58xtSent from my iPhone using Tapatalk Booth11 and marshy 2 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 13, 2021 Report Share Posted February 13, 2021 35 minutes ago, veneeringman said: It works on our GTD too.... Sent from my iPhone using Tapatalk Just me then. 😂 That's going to annoy me now that I know it can work. I’ll try again when it’s light. 8YARWY 1 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted February 13, 2021 Report Share Posted February 13, 2021 Just me then. That's going to annoy me now that I know it can work. I’ll try again when it’s light. Strange, I’ve coded a few different vag range cars with it now and it’s always worked. Did you cycle the ignition off then on ?Sent from my iPhone using Tapatalk Booth11 1 Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted February 13, 2021 Report Share Posted February 13, 2021 Just now, veneeringman said: Did you cycle the ignition off then on ? I can’t believe you’re questioning Becs ability, I see trouble ahead 😂👍 8YARWY, Booth11 and Penguin 1 2 Quote Link to comment Share on other sites More sharing options...
8YARWY Posted February 13, 2021 Report Share Posted February 13, 2021 I can’t believe you’re questioning Becs ability, I see trouble ahead Oh lord I see another Harry Potter episode coming on Sent from my iPhone using Tapatalk gregozedobe, EcosseGolfR and Booth11 2 1 Quote Link to comment Share on other sites More sharing options...
EcosseGolfR Posted February 13, 2021 Report Share Posted February 13, 2021 @veneeringman please don’t mention the Harry Potter incident before the 9pm watershed as there may be children watching 😂 8YARWY and Booth11 1 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 13, 2021 Report Share Posted February 13, 2021 15 minutes ago, veneeringman said: Strange, I’ve coded a few different vag range cars with it now and it’s always worked. Did you cycle the ignition off then on ? Sent from my iPhone using Tapatalk I did both times - ignition off then on but no change, letting car shut fully down in between. I tried doing the coding first with engine running but when didn’t work, I then tried with ignition on but engine not running, still nothing. I’ve no doubts it’s user error if it’s worked in yours and Marshys . My connection to the house wifi was being a bit temperamental and that was after I’d unplugged my Carlink2 dongle as the phone kept picking that up at first but it did connect and accept the changes. Ah well, tomorrow is another day, another date with the dongle. 😂 EcosseGolfR 1 Quote Link to comment Share on other sites More sharing options...
Booth11 Posted February 13, 2021 Report Share Posted February 13, 2021 Now who’s this Harry Potter fellow you speak of?! 🤣 EcosseGolfR and 8YARWY 1 1 Quote Link to comment Share on other sites More sharing options...
