Is this the right OBDeleven for me ? plus they have a sale
Crick
7 hours ago, dv52 said:
@Booth11 and @Crick: Arrh..............gosh!!! Thank you  - I'm more than a tad humbled by your generous (and undeserved) words!
Truth is that there ain't nothing special about this canard-noir - I just happen to have a limited understanding of stuff that may be useful on forums like this.
However,I have absolutely no doubt that both of you know lots of stuff about which I'm completely ignorant and which in a different context I would laud with equal praise!!
So, let's abandon any sense of hagiography because in reality ALL members of this forum community are intellectual equals
Again, thanks!
Members make the forum, no question about that.
No hagiography, but sometimes it’s good to acknowledge valued contribution. 😊
  • 3 weeks later...
So the idea of a cheap device hasn't quite worked out as planned.
@Microbe sent the item very quickly, all is there in the original packaging and has no sign of use. Questions I've asked have been answered so I want to be clear, I'm not blaming him at all here.
I have the login name and the password and I can get past this stage so I'm confident they are correct. The next part of the process though is the 2 factor authentication has been turned on. I'm guessing this 6 digit number changes each time and the code microbe supplied doesn't work. Doesn't have the google authenticator he used previously either. The next option is the 10 digit backup code which he no longer has.
So that's as far as I've got.
There is an option to create a new user but unsure how this would work with a used device. I've sent a message via the webchat on the ODBeleven site but they aren't back till Monday. I'm working nights till Monday morning too.
My car isn't at mine currently as we have building work going on and I despise brick dust and I've arranged to use my mates lift on Thursday to change the DSG oil which I've course, the reader was a vital part of.
Any ideas ? Someone must have bought a used device before and had this issue
Cheers
Crick
Cheers
Crick
To address the 2- step authentication, you need to download an authentication app onto the device you’re using obdeleven on.  Then link it to obdeleven, and each time you need an authentication code, the authenticator app will generate a new 6 digit code for obdeleven.  You can download either Microsoft Authenticator or Google Authenticator, both will work.
You need @Microbe to log in to that user and turn off 2FA with his Authenticator app
Then you can go in and turn it on via your Authenticator
Also, if there is an option to change the email to yours, that would make it all much easier.
Other wise just get a Pro plan online (like most of us) and them you have everything.
The hardware (dongle) is not a part of this whole issue
This is strictly an app/account thing to solve
thanks for the replies
@AHG Microbe doesn't have the authenticator anymore. Is it is simple as reinstall and use it again ?
@Booth11 I've installed google authenticator but I think I'm coming at it from the wrong direction. According to the steps : obd3.thumb.png.61bdd72c0619fc81267f5d9bd7f893d6.png
No.2 - already enabled
No.3 - I cant get the provided code because its already logged in to microbe
I might be able to borrow a VCDS device on wednesday but will have to test it thursday morning before I leave to carry out the oil change at my mates. Not much time to learn a system when I cant even get this one to work 😄
@Crick, so far as I can tell, it’s as @AHG has advised, microbe or someone going in using microbe’s account login, likely needs to go into obdeleven and disable the 2-step authentication first.  Then you can then go into obdeleven and re-enable 2-step authentication using the steps above, and once you’ve downloaded an authenticator app.  If microbe is doing it then he just needs to get the authenticator app again to facilitate that.
It may be an impasse then
If it is locked with 2FA and the 2FA is inaccessible
There is a chance the account is bricked
The company has no incentive to help you
I don't think they allow or support account transfer
Can @Microbe re-establish his 2FA ?
and it looks like we got somewhere ....
With a synchronised effort, following Tonys reinstall of his authenticator we were able to communicate via text with me at work with the dashboard open.
The first code generated (by Tony then text to me) worked to access the account and then another was required to disable the 2 factor authentication. I'm not back with my car till tuesday so can't confirm access till then but I'm hopeful.
I didn't see an option to find the 10 digit recovery code and I've read different information regarding accessing this. Tony does still use the same email address so maybe it will go there if requested. For the moment though, as long as I have access to read the gearbox oil temp I'm happy and will deal with changing the account etc after.
All I'll say is, if your buying one used, make sure you have all the details of the previous user and can at least contact them for questions.
Thanks for all your help Tony - @Microbe
As long as you can now turn on 2FA with your authentication app, and turn on auto-unlock function (or whatever it’s called) on the app, you’re probably good.
The app is where it all happens, the dongle is just a dongle.
And the reply I got from the OBDeleven team following my enquiry :
'Sadly, I can't provide any access to another user's OBDeleven account. Please note that you can create your own OBDeleven account, and use it with FREE plan. If device has PIN, you can disable it via our automated chatbot. Once you open the chat, select 6-Digit PIN and 2FA branch'.
For now I'm not going to change any details or emails addresses or and pins etc. Need it working tomorrow so after that, the pressure is off.
Thanks for all the replies
Crick
